650’ pull
wyliesdiesels
Modesto, CA
Just curious...
Say we are starting with a gate located 650ft (or more) from the residence (and power source), but nothing has been done. No conduit, nothing installed yet.
What would be the recommended solution from the experts? I just recently visited a residence where the outer gate was easily a half-mile from the dwelling, with no adjacent structures/improvements/poco lines close by. As I punched in the gate code I was wondering how in the heck would they get power out here?
a good suggestion has already been made. DC gate opener ran on batteries, with a charger that operates on a trickle charge and/or solar.... The batteries are the primary supply so no huge in-rush on the AC line. The AC line only powers the charger and solar can supplement the AC feed.
kbuhagiar
Escondido, CA
So it would still require running an AC feed a great distance from the dwelling?
kaffine
Henderson, NV
Just curious...
Depends on what all I want out at the gate. If I just want a gate opener then I'm going with a solar panel and batteries.
If I want a camera and intercom to the gate and or other security sensors ect, then I'm more likely to trench and pull power from the house. Also depends on if I have to trench water/sewer/gas from the street anyways. It is still possible with solar and batteries and a microwave link for the data.
My driveway is 180feet but it is ~500 from the street to the house. I had to replace the water line so when I had the trench open I put two conduit runs 2.5" because I got a good deal on it. I will put a security camera and driveway sensor in at some point.
Noltz
Ontario, Canada
@ 500' you could run a 2A load with 12 AWG. I'm still curious if anyone knows what the receptical rules are when the circuit is not rated for 15A. Can I just put a duplex outlet with a label on it "2A MAX" like they do for light fixture wattage ratings.?
