Above 1200 Sq/FT Finally build my, long needed, shop
Michael B.
Huntsville Al
Today I finished hanging the joists over the room. That’s a total of 15 or about half. Then I built the triple 2”x12”x19’9” beam. That things is going to be a beast to install! It weighs approximately 500lbs. After building the beam I cut and installed the two 6x6 posts the beam will sit on.
Oh, it appears the beam has passed inspection 😉
Michael B.
Huntsville Al
The shop is looking really good! I really like that accent (?) wall.
I'm curious, what species is your dimensional lumber down there? Up here it's mainly spruce and has nowhere near the woodgrain to it that yours does.
Thanks JG! The predominant species is pine. The 2x10’s were almost too nice for structural use. But the joists will be visible from below on half of the mezzanine.
Michael B.
Huntsville Al
The joists are all in! Now I get to build the stairs. I have seen it done a few times but I have never been the T square jockey. I have been watching some videos on the subject. Some are more helpful than others. I need to make some measurements and do the calculations. I would like to have a landing at the top of the stairs but with just over 9’ of run I don’t think it will be feasible. A6BFF3C5-B9C2-419D-9083-C7B4748A484C.jpeg16A6F613-0755-484B-BB6D-17333F984921.jpeg
Toolfool
Tallahassee, FL
It's not too difficult. My first time, I messed up. Second try the lightbulb came on and the whole concept became clear. Learned more when I got to work with seasoned framers. And a pair of framing square knuckles helps a lot. Do a practice run with a piece of 1x. I'm betting you're more than capable.
Jeff Ivers
Oklahoma
Have you got a large framing square and a set of brass "stair buttons"? Makes setting up the runners quite easy. Assuming you go with a 10" tread depth and about 7" for riser height, a 9' run will not likely be enough without creating a landing part way up the stairs.
Michael B.
Huntsville Al
Thanks for the encouragement John! After talking with a good friend of mine, who is much better versed in construction than I am, he thinks my stairs will come out from under the mezzanine by about 2’. I’m not too keen on that idea. I think it will be a trip hazard for me. He has suggested a stair case against the back wall leading up to the face of the mezzanine, going over my sink and hot water heater. I am thinking this over.
Michael B.
Huntsville Al
So at 3:00 am it occurred to me that I can’t place the stairs along the back wall. There is only 17” between the truss and the top of that beam.
My thoughts now are to use the original place in the middle of the mezzanine and build a landing at the top and a landing at the bottom and turn the stairs right to keep everything under the deck.
In case it’s not obvious in the above picture, the stairs will come down the left wall with a landing inside of the 6x6 post. Then the stairs would turn to the right and land on the floor under the mezzanine.
Toolfool
Tallahassee, FL
A pull-down staircase won't work for you ? Re-frame a section of the deck ? I 've installed a couple of nice metal ones in the past.
Or, build a complete staircase, maybe a little steeper than normal, hinge or pivots at the top, pulley and counterweight to operate it ? It could drop straight down along that left wall, hinged on the outside beam.
Michael B.
Huntsville Al
John I would have very steep stairs with no landing and it would cut the mezzanine in half if I ran it with the current joist layout.
