jbrentd
Are those beams going in for a mezzanine?
Yes sir!Are those beams going in for a mezzanine?
Indeed sir!Crowns up.
Well if I’m going to get that from anybody, I would prefer it to be from you. Someone I trust, appreciate and respect!Somebody says it on EVERY frame I've been involved with using dimensional lumber joists.![]()
I appreciate that John! I think me and the engine hoist can handle it. It worked well with the smaller beam.don't hurt yourself. I can be there in about 7 hours.![]()
Be careful.I appreciate that John! I think me and the engine hoist can handle it. It worked well with the smaller beam.
No need for you to feel that way. You’ve got Shorty. I don’t think you could use anymore character!More character ! I'm starting to feel inferior.
Maybe some different character........No need for you to feel that way. You’ve got Shorty. I don’t think you could use anymore character!![]()
I used a drywall lift to set a 12 ft header one time, talk about fun! Nice building by the way.
Thanks! The drywall lift was my fallback position.I used a drywall lift to set a 12 ft header one time, talk about fun! Nice building by the way.
Thanks JG! The predominant species is pine. The 2x10’s were almost too nice for structural use. But the joists will be visible from below on half of the mezzanine.The shop is looking really good! I really like that accent (?) wall.
I'm curious, what species is your dimensional lumber down there? Up here it's mainly spruce and has nowhere near the woodgrain to it that yours does.
Thanks for the encouragement John! After talking with a good friend of mine, who is much better versed in construction than I am, he thinks my stairs will come out from under the mezzanine by about 2’. I’m not too keen on that idea. I think it will be a trip hazard for me. He has suggested a stair case against the back wall leading up to the face of the mezzanine, going over my sink and hot water heater. I am thinking this over.The joists are all in! Now I get to build the stairs. I have seen it done a few times but I have never been the T square jockey. I have been watching some videos on the subject. Some are more helpful than others. I need to make some measurements and do the calculations. I would like to have a landing at the top of the stairs but with just over 9’ of run I don’t think it will be feasible.
It's not too difficult. My first time, I messed up. Second try the lightbulb came on and the whole concept became clear. Learned more when I got to work with seasoned framers. And a pair of framing square knuckles helps a lot. Do a practice run with a piece of 1x. I'm betting you're more than capable.
A pull-down staircase won't work for you ? Re-frame a section of the deck ? I 've installed a couple of nice metal ones in the past.So at 3:00 am it occurred to me that I can’t place the stairs along the back wall. There is only 17” between the truss and the top of that beam.
My thoughts now are to use the original place in the middle of the mezzanine and build a landing at the top and a landing at the bottom and turn the stairs right to keep everything under the deck.
In case it’s not obvious in the above picture, the stairs will come down the left wall with a landing inside of the 6x6 post. Then the stairs would turn to the right and land on the floor under the mezzanine.
Or, build a complete staircase, maybe a little steeper than normal, hinge or pivots at the top, pulley and counterweight to operate it ? It could drop straight down along that left wall, hinged on the outside beam.
