Does this wire crimp tool exist?
5ubtle
Spartanburg, SC
I have several crimp tools similar to this:
It has 3 crimping dies for "open barrel, uninsulated crimps", but they are between the pivot and the grips.
Does a similar tool exist that has those 3 crimping dies in front of the pivot (like so)?
CoogarXR
Problem with having the crimper on the end is leverage. There is more leverage on the inside.
But they make them.
Actually, I prefer a "ratchet crimper". It has the crimp action on the open end, and it won't release until the crimp is complete. I have this Xcelite model that I use quite a bit:
CoogarXR
The leverage is not determined by which side of the pivot the crimping happens on. It's just the distance from the pivot.
But isn't there some loss in the flexing of the cheap metal? When the crimp jaws are closer to the pressure being applied at the handle, you'd think it would be stronger than way out on the end. I'm no physics major, just wingin' it here.
5ubtle
Spartanburg, SC
Thanks for the response. I have that crimper also. I am looking for non ratcheting.
assassin10000
I'm not a fan of that style crimper. Get a set of kleins or channel lock crimpers (I've had both, and a south wire as well).
I actually prefer my matco ones but its 2.5x the price. It has a relief that works well with insulated connectors that the others don't.
assassin10000
Thanks for the response. I have that crimper also. I am looking for multiple crimping dies ahead of the pivot.
Quote Reply
Report Edit
I think klein had a set with 2 ahead of the pivot. Just not that style.
This one:
5ubtle
Spartanburg, SC
This one:
Now we're getting somewhere. I do like that one. If there is one with 3 (or more) dies ahead of the pivot, that would be even better.
assassin10000
5ubtle
Spartanburg, SC
assassin10k - That's it. Thank you.
Now, if only I could find that one at fixfirm available in the US for about $25 (or less). The PA-01 looks great, but I'm not sure I want to spend $50+ on one.
dnschmidt
Phoenix, AZ
The only thing weird about them is that the bare terminal dies are on the front and the insulated dies are behind the pivot which is opposite from normal. Other than that they seem pretty normal. Look on the Ideal website.
Vaco, Klein, and ProAmerica all make (or made) those.
Klein 1001 wire tool
Proamerica 5032 9-inch crimping plier with cutter
* Klein makes ALL KINDS of different models. Not just the 1001.
VACO was purchased by Klein over a decade ago, so any VACO is going to be old stock. Check ebay - there's tons of VACO on there.
BK
Tool Using Animal
I've tried a bunch of them. Ratcheting, non-ratcheting, Snap-on PWCS7ACF ... the best one I've found so far is the Channellock 909. Gives consistent solid connection, even when using the cheapest terminals. I only use the "non-insulated" position on both insulated and non-insulated connections because it produces the best results.
assassin10000
The 909 is very nice. It's also rebadged by Cornwell iirc. My second favorite.
The only one I like better is the Matco.
Unless we're talking open barrel connectors. I have the engineer pad-11 (+12 & 13 dies too) for those.
richfinn
Leeds, Yorkshire, England
Knipex make 5 different versions, all relatively inexpensive but really great quality compared to cheap imitations (they are twice as thick don't flex and everything lines up perfectly as you would expect)
I've ditched my ratchet crimpers as they are just too bulky for automotive work, I prefer these for reach and "feel"
I use the version with the insulated crimper at the nose in front of the pivot (which work great on heat shrink splices) but this version might work better for you (I might end up buying all 5 versions I like them that much)
It's always going to be a compromise with multi purpose tools but just pick the version that suits you best.
Mine have metric strippers, since I work on Eurotrash, might be a deal breaker for you,
If you go to the bottom of the link you can swipe across and compare all 5 versions and pick what you need
assassin10000
Those are nice. Forgot knipex may have them.
Also saw these:
vssjim
McLean Va.
Thomas and Betts is where these come from insulated and non-insulated styles
Steve_P
I have Vaco and Ideal stripper/crimpers like what OP is looking for. The Vaco has red handles, is for metric, and is ~25 years old; the Ideal has yellow handles and is for inch/AWG. I never use them (I didn't buy either of them). I much prefer a set of dedicated Klien strippers and a dedicated crimper - in my case, the Channellock 909. I've almost totally moved on from Channellock to Knipex, NWS, etc, but I love my CL 909 crimper and linesman plier.
assassin10000
Good to know.
And it was cheaper through Matco when I bought them than most online shops. Probably one of the few times the truck was a better 'deal'.
darkzero
SoCal
I was on the same boat but I gave up looking for something I liked for the price I was ok paying.
When I came across the Knipex that had the 3 non insulated closed barrel crimpers in front of the pivot I was excited and cause I wanted something with a screw cutter for metric screws.
I ordered these. I was very disappointed in them especially for the price, returned them & ordered a second one, it was no better. They were by far the worst quality Knipex tool I have ever purchased. They're not made in Germany, which I wouldn't have cared if they were decent quality, but they weren't. I believe they are made in Taiwan but they sure didn't seem like it. I swear the black part on the ones I got were painted, flaking in some areas & the markings were silkscreened. Seen other reviews that were consistent.
I just went back to using my Bluepoint that I modified and my Thomas & Betts that I've been using for 20 yrs now.
darkzero
SoCal
This is the style I believe what the OP is looking for as was I. It's the one I was talking about in my prev post. Very disappointed in them & couldn't believe they bear the Knipex name.
Walkers
Cave Creek Az
The OP is cocksure that he wants a stamped sheet metal tool over a far superior forged Klein, Sta-Kon, etc. I have several similar pairs that I have given away because I never use them.
5ubtle
Spartanburg, SC
Knipex make 5 different versions, all relatively inexpensive but really great quality compared to cheap imitations (they are twice as thick don't flex and everything lines up perfectly as you would expect) ...
Thanks. I like the 97 21 215 C. Do you have personal experience with that model? darkzero said above that his experience was not good.
darkzero
SoCal
The Bluepoint that I modified is one of those types. It has been working fine for my needs but the only thing I use it for is crimping red & blues. Everything else on it is useless to me, I hate the strippers below the pivot & I hate tools that have the crimper below the pivot.
My good ol trusty Thomas & Betts that Matco sold me are far superior but surprisingly I find myself using my Bluepoints more.
darkzero
SoCal
Perhaps functionally they are fine, I didn't even bother to try em. They just looked & felt so cheap to me, even the Knipex logo was chipping off on one of them. The handles didn't even feel like their comfort grips (didn't care about that though). Again I don't like strippers or crimpers below the pivot but the strippers on those being marked in metric bothered me too, the crimper part not so much.
They seemed like they were knock offs or something to me. Are fake Knipex even a thing? Never heard of fake Knipex. I'm a fan of Knipex & I love all the Knipex that I own but the 2 that I got were disappointing for what they charge for them.
darkzero
SoCal
Weird that a European tool would be metric... 🤔
Yeah who wudda thunk? ;)
I wasn't implying that I didn't know, didn't care about the strippers anyway. The new crimpers I got recently are metric too but again don't care. Only wanted the Knipex for the crimper & metric screw cutter (which I'm not a fan of using anyway). What I didn't expect is something from Knipex to be so poor quality cause I've never experienced that before. But then again even made in USA don't mean shiet anymore. Now I know.
hans109h
Upper Midwest
So expensive, but so worth it. I never had a need for good crimps, or so I thought, until I started building antennas and working with coax for amateur radio. That's when I got myself a DMC crimper. I think they are typically for aviation, but they have interchangable dies similar to the ratcheting styles.
The price tag probably reflects the fact they they are used for mission critical tasks. I was lucky to get mine at an auction where everyone else must have thought it was a fancy nutcracker!
richfinn
I'll post up some pics of my version so you can decide on quality, like the guy says he never actually tried using them, just didn't like the look??
