Problem with having the crimper on the end is leverage. There is more leverage on the inside.
But isn't there some loss in the flexing of the cheap metal? When the crimp jaws are closer to the pressure being applied at the handle, you'd think it would be stronger than way out on the end. I'm no physics major, just wingin' it here.The leverage is not determined by which side of the pivot the crimping happens on. It's just the distance from the pivot.
I think klein had a set with 2 ahead of the pivot. Just not that style.
Now we're getting somewhere. I do like that one. If there is one with 3 (or more) dies ahead of the pivot, that would be even better.I think klein had a set with 2 ahead of the pivot. Just not that style.
This one:
Crimping and Cutting Tool for Non-Insulated Terminals - 1006 | Klein Tools
Klein Tools Crimping and Cutting Tool is designed for crimping non-insulated solderless terminals and connectors. Wire cutter in nose specially hardened for durability. Tapered nose allows you to work in confined spaces.www.kleintools.com
rhinotools.com.au
The 909 is very nice. It's also rebadged by Cornwell iirc. My second favorite.I've tried a bunch of them. Ratcheting, non-ratcheting, Snap-on PWCS7ACF ... the best one I've found so far is the Channellock 909. Gives consistent solid connection, even when using the cheapest terminals. I only use the "non-insulated" position on both insulated and non-insulated connections because it produces the best results.
Those are nice. Forgot knipex may have them.Knipex make 5 different versions, all relatively inexpensive but really great quality compared to cheap imitations (they are twice as thick don't flex and everything lines up perfectly as you would expect)
I've ditched my ratchet crimpers as they are just too bulky for automotive work, I prefer these for reach and "feel"
I use the version with the insulated crimper at the nose in front of the pivot (which work great on heat shrink splices) but this version might work better for you (I might end up buying all 5 versions I like them that much)
It's always going to be a compromise with multi purpose tools but just pick the version that suits you best.
Mine have metric strippers, since I work on Eurotrash, might be a deal breaker for you,
If you go to the bottom of the link you can swipe across and compare all 5 versions and pick what you need
Crimping Pliers
Zum Kabelschneiden, Abisolieren von Adern und Crimpen von unisolierten Quetschkabelschuhen nach DIN 46234, Mit Gewindelöchern zum Abschneiden von Cu- oder Ms-Gewin...www.knipex.com
Thomas and Betts is where these come from insulated and non-insulated styles
Good to know.Thomas and Betts is where these come from insulated and non-insulated styles
The OP is cocksure that he wants a stamped sheet metal tool over a far superior forged Klein, Sta-Kon, etc. I have several similar pairs that I have given away because I never use them.
Thanks. I like the 97 21 215 C. Do you have personal experience with that model? darkzero said above that his experience was not good.Knipex make 5 different versions, all relatively inexpensive but really great quality compared to cheap imitations (they are twice as thick don't flex and everything lines up perfectly as you would expect) ...
The Bluepoint that I modified is one of those types. It has been working fine for my needs but the only thing I use it for is crimping red & blues. Everything else on it is useless to me, I hate the strippers below the pivot & I hate tools that have the crimper below the pivot.The OP is cocksure that he wants a stamped sheet metal tool over a far superior forged Klein, Sta-Kon, etc. I have several similar pairs that I have given away because I never use them.
Perhaps functionally they are fine, I didn't even bother to try em. They just looked & felt so cheap to me, even the Knipex logo was chipping off on one of them. The handles didn't even feel like their comfort grips (didn't care about that though). Again I don't like strippers or crimpers below the pivot but the strippers on those being marked in metric bothered me too, the crimper part not so much.Thanks. I like the 97 21 215 C. Do you have personal experience with that model? darkzero said above that his experience was not good.
Weird that a European tool would be metric...but the strippers on those being marked in metric bothered me too, the crimper part not so much..
Yeah who wudda thunk?Weird that a European tool would be metric...![]()
