Fleet is Ford, GM and Toyota.
I second this method.Motive brake bleeder adapters to fit different models
The only catch is that depending upon your application, pressurizing the reservoir may be a royal pain. For example, OEM Honda twist-lock lids just don't hold pressure and I haven't found any aftermarket adapters that fit well. Some are ridiculously tight to the point that they will break the plastic reservoir while others instruct you to clamp a flat plate down hard on top of reservoir lip using a chain (lol).
Wrong size for most applications.check out the CTA 7030 and 7043 adapter for Honda.
Not a great idea to use PTFE tape.For home use this is cost effective and reliable, I have two 200ml Syringes. I have one for sucking fluid out of brake calipers and reservoirs (the dirty version) and another for back bleeding hydraulic clutches by "injecting" fresh fluid in to the slave cylinder (the clean version). They cost around £3 each!!!!
Silicone grease works pretty good for sealing threads if you get bored using PTFE tape![]()
I did buy a CTA 7032 for my Prelude but it is so insanely tight to get on/off that that I only test fit it once because I was afraid the reservoir or locking tabs would snap. Spec listed on the website is 74mm but the plastic on the adapter measures 74.8mm and the o-ring brings it up to over 76mm.
An enthusastic third. I'm a DIYer, and usually have not had a second person to pump the pedal. I had the little bottles with brake fluid, but I hated not being able to see what was happening as I pumped. I then graduated to a vacuum pump, and that worked better, but it was a lot of pumping. Next, I tried the air-operated vacuum version, and that was a huge improvement. But then I learned about the Motive, and bought one, and it's by far the best method I've ever used. Pump it up and the fluid & air just spits out like gangbusters. It's very easy to get a good, firm pedal with the Motive.I second this method.
That will work a lot of the time, but if there’s any air in the system, you need to move some fluid to squish that air out.i now i sound like i was joking but no, i really just crack the valve and go watch tv, let it drip, gravity
Slow, BUT IT DOES WORK !Gravity bleed
Disagree ! The air will come out !That will work a lot of the time, but if there’s any air in the system, you need to move some fluid to squish that air out.
Agree to disagree. Had some stubborn motorcycles that needed to have a lot of fluid moving to get the air out.Disagree ! The air will come out !
The only problem with this idea is that Power Probe doesn't make or sell these anymore. Great idea though.I started with mity vac and it was terrible. I then tried vacuum bleeders but they always pull air from the threads so you don't really know buy looking at the tubing if all the air is out, you just have to assume.
I tried a friends motive and it was pretty good but if you put brake fluid in the resivor its a mess when your done and absorbs water if you don't put it back in the bottle until next time. If you just use it as a pump for air it works well but why pump when you have an air compressor.
I ended up buying a power probe cap for my vehicles and it has all the advantages of a motive bleeder without the manual pumping. Do have to stop, depressurize and add fluid if you do it this way typically after your done with the rear axle but its clean and easy.
