RoninB4
Deleting reply, no need to add gasoline to fire. 40 years in professional machine shops, nothing to win here.
I looked at one on eBay, it looks as though replacing the the shaft is reasonably easy. Might have to have grooves for the c clips cut in, or keyways cut, but otherwise pretty easy. IIRC McMaster sells shafts with keyways in it in varying lengths.
I get it, but I also know when to give it up as well.Deleting reply, no need to add gasoline to fire. 40 years in professional machine shops, nothing to win here.
-You're in denialI get it, but I also know when to give it up as well.
it's pointless to argue
How did you use JB Weld before you discovered JB Weld?... along with and JB Welds and set screws to fill in the gaps while the epoxy dried.
That was before I discovered JB Weld.
1. method is to add additional set screws to your pulley and dial it in till runs true. I have had success with this on a multi step pulley.
