Table Saw Repair
RoninB4
Under My House
Deleting reply, no need to add gasoline to fire. 40 years in professional machine shops, nothing to win here.
Walkers
Cave Creek Az
Can this be repaired? Blade arbor on a Craftsman belt drive table saw where the smaller pulley mounts. Haters should know, I bought it this way.
I looked at one on eBay, it looks as though replacing the the shaft is reasonably easy. Might have to have grooves for the c clips cut in, or keyways cut, but otherwise pretty easy. IIRC McMaster sells shafts with keyways in it in varying lengths.
Meursault74
Southern California
I get it, but I also know when to give it up as well.
I hear people saw all the time "This has chemicals added to it, or this has a chemical smell" I understand what they mean, but it's pointless to argue that EVERYTHING is a chemical.
PoorUB
Fargo, ND
Things change, language isn't a solid, never changing thing.
For example, in the 1950's if you asked your buddy for a *** you would get something completely different than today!
Whitworth
If I were the OP and had access to a lathe, I'd turn it down to the next nominal size, example 3/4 to 5/8 to 1/2, etc. and then buy a pulley that fits the bill. Most of those old small saws just had a set screw bearing against a flat, and a single sheave pot metal pulley.
Otherwise, semantics, semantics, sheave, pulley, whatever. I was an engineer, I knew an engineer, I married an engineer, I coulda, I woulda, I shoulda.
larry4406
Northern Virginia
Since you have no connection to this machine, and might be willing to dump it, anything wrong with welding a round groovy thing (pulley, sheave 🤣 ) to the shaft and calling it done? If you have to replace the shaft at a later fail date, then cut the round groovy thing off.:dunno:
  • Like
Reactions: RTM
seber
Deep East Tx.
Pulley a wheel with a grooved rim around which a cord passes. It acts to change the direction of a force applied to the cord
PCustoms
VT
So a pulley is meant for rope, is that why a pushey doesn't exist?
  • Like
Reactions: RTM
nadogail
Coronado, CA
If the OP just wants to make the saw functional, rather than restore it, there are many options. With a belt drive alignment should be close but is not critical. i have used a product labeled Quick Metal along with and JB Welds and set screws to fill in the gaps while the epoxy dried.
That was before I discovered JB Weld.
Bert_
NW Iowa
Here is what mine looked like. Looks like I filled the grooves then filed it smooth before putting the pulley back on with more JB weld to hold it permanently.
It's held up fine for 3 years now. Just used the saw yesterday.
sparkness
Long Island, NY
1. method is to add additional set screws to your pulley and dial it in till runs true. I have had success with this on a multi step pulley.
2. add jb weld with metal and finish till running true
3. make a new shaft, they are simple and can be made for little money
