Above 1200 Sq/FT DFB's Garage
D
D.F.B
Australia
The Mustang has been on errand duty for several weeks. So today I wanted to give it a wash and swap out the XR6.
For the wheels and tyres, I went with Brake Buster, HydrO2 and Atom Mac. I then washed with Carpro Reset and a Microfiber Madness DeliPad. Drying Aid was Amplify, including the door jambs, engine bay, wheels and exhaust tips. Glass was via Tru Vue, then OG Tire Dressing for the rubber.
For the interior, I wiped down with a little Griot's Interior Cleaner. I also wanted to reapply ColourLock Leather Shield to the driver's seat, steering wheel, centre console lid, hand brake, gear selector, and driver's door panel. I didn't scrub with a leather cleaner beforehand, just a quick wipe with Griots was enough.
Clean once more, ready for a rest under its cover.
D
D.F.B
Australia
The China Syndrome –
How does the cheapest chainsaw on Amazon stack up?
I don't normally do this sort of thing — I'm a brand snob to the core. I learned the hard way that buying cheap is a one-way ticket to disappointment. Not buying the tool you actually want only leads to regret, and quite often you end up going back for the more expensive option anyway, compounding the cost. So, buy the tool you want, then look after it.
So, what am I doing buying the cheapest chainsaw currently listed on Amazon? Mostly curiosity — how bad could it be? My current collection covers the bases pretty well: a battery-powered MS 140C for quick cuts and pruning, an inherited 009L and 028 AV Super, and the big dog, the MS 500i. What I don't have is a top handle — ideally balanced for pruning and tree work. So, I'm killing two birds with one stone: filling that gap in the collection, but honestly, mostly to see what you actually get for such a small outlay.
Exploring The Amazon
A quick search turned up a candidate from H-YEEU. Yeah, I've never heard of that brand either — and chances are, in a year's time H-YEEU will be replaced by another meaningless name on the exact same chainsaw. That's just how it works.
For the grand sum of $71.99 with free shipping, you get a saw with this snappy name:
"25.4CC Gas Chainsaw with 10-Inch Bar – High-Performance 2-Cycle Handheld Saw for Firewood, Tree Trimming & Landscaping (900W, 9800 RPM, LowVib Technology)"
https://www.amazon.com.au/dp/B0GTQ7B8XH?smid=A5RYBF8CDL2XL&ref_=chk_typ_imgToDp&th=1
During my research I came across a lot of cheap garden tools like this, and what stood out was the quality of the product descriptions. I'm not sure who writes this stuff, but it's certainly not someone who gives two hoots about chainsaws or gardening. It reads like it was written for the wilfully uninformed. They're especially adamant this saw is up to the task of pruning — shrubs in particular:
"This chainsaw is extremely sharp for cutting branches, twigs, shrubs, shrubs, and trees. Suitable for sawing, pruning, pruning, pruning wood. It is an ideal tool for gardening, woodworking and landscaping."
The product images are good for a laugh too.
I'm not sure how much "logging" you'll be doing with a 10-inch top handle chainsaw.
Wohah, that's a big notch being cut. Notice how they've flipped the image to have the clutch side facing the cut.
An imported chain? What does that mean? Imported from where? India? Thailand? It certainly wouldn't be from Germany or the USA.
"Oil can choose ordinary oil".........ok then.
Good to know the machine can "prevent burning".
That sounds like a high tech starting system, my $2000 500i doesn't come with a frost resistant starter, ripped off!
All of which does make you wonder — if they can't string together a coherent product description, how safe and effective is this thing actually going to be?
D
D.F.B
Australia
Unboxing & What You Get –
So what does $71.99 get you? The core of the unit is a 25.4cc 2-stroke engine that delivers 0.9 kW and a top speed of 9800 rpm. The engine is fed by “air injection centrifugal air cleaning”, and is started with a “heat and frost resistant steel sheet spring rope wheel”…………in English that’s a recoil starter rope. H-YEEU also say the saw was “designed with LowVib technology to significantly reduce vibration and user fatigue during extended use”. You get a 10-inch bar with “automatic oiling” that “protects the chain”. Actually, they claim it has an adjustable oiler.
I'm under no illusions that this $72 chainsaw is going to be the best there ever was. The problem with cheap tools is that so many people buy them and then convince themselves they're fine — it's easier than admitting you were just too tight to buy the right one. That might come off as harsh or elitist, but it's true.
Nobody buys these things because they want to. They buy them because they think they have to.
I've watched others go down the "that'll do" path plenty of times, and it usually ends with me being the one who has to actually use the thing. You end up resenting both the tool and the person who bought it — especially when you know full well they didn't actually save any money. Not when someone's paying me by the hour to wrestle with gear that barely works.
So yes, my opening take is a harsh one — but I've earned it.
D
D.F.B
Australia
First Impressions -
At first glance, this saw has everything you'd want and expect. Look closer and things start to unravel.
The plastics are brittle garbage — that thin, shiny kind that feels cheap and poorly fitted from the moment you touch it. The fuel and oil caps will crack in no time, and the retaining tabs inside the tank are too short, making filling a chore. Amusingly, they include spare throttle and choke levers in the box. Make of that what you will.
Products like this are aimed squarely at the novice, hence the bag full of tools, including an abysmally bad sharpening file.
It's up to the customer to finish the assembly, the dogs are threaded into plastic with self-tappers. Yeah, that's going to last. And check out the amount of tolerance factored into the bottom bolt hole.
This saw has an outboard clutch and chain brake, which isn't my preference, but I've dealt with that before on the 009L. And this is where my patience ran out.
With an outboard clutch setup, you'd typically expect a front-mounted chain tensioner on the saw body. So why — WHY — would they fit a side-mounted tensioner to the clutch cover? Getting the rear of the cover seated, slotting the brake band over the clutch, clearing the bar stud, and aligning the tensioner into the bar slot, all at once, was a nightmare. It took far longer than it should have. If it's that hard for someone with chainsaw experience, how on earth would the novice fare?
Worse, once the bar was installed, the cover wouldn't sit flush — the bar is simply too thick. That's not just an annoyance. That's a safety issue. At this point, I was starting to genuinely hate this thing.
As mentioned earlier, this saw is supposed to have an adjustable oiler — like a pro-grade Stihl. Sure enough, there's an oil adjustment symbol on the underside of the saw. No slot to actually turn it with a screwdriver, though. Not surprised.
Once assembled — which the marketing material promises is quick and easy — I filled it with oil and fuel. H-YEEU recommend a 25:1 mix, which I ignored. It's not 1990, so I ran my usual Stihl HP Ultra at 50:1. With the carb primed and choke on, the engine popped on the third pull. One more pull with the choke off and it was running. It took a moment to settle, but quickly found a smooth idle.
And then the kicker: the chain brake doesn't work. The engine will accelerate straight through it. That is not okay. You can forgive cheap plastics. You cannot forgive that.
Am I being harsh? Yes and no. I'm coming from German and Swedish tools built to a certain standard, and I'm aware that colours my view. But here's the thing — people who buy cheap tools often have no idea how large the gap really is between something like this and a Stihl or Husqvarna. And I don't just mean how it looks and feels, but functionality, usability, work efficiency, and above all, safety.
At $72 versus $700, you can't reasonably complain about material quality. Better plastics, rubberised grips, and precisely fitted parts cost money — that's just the reality. But you can absolutely complain about safety. If Stihl and Husqvarna are held to a safety standard, everyone selling into the same market should be too. A non-functioning chain brake isn't just a quality issue, it's a dealbreaker.
As for the price gap itself, it's multi-faceted. Yes, you pay a brand premium — that's true of any consumer product and always will be. But the rest of that gap buys you a genuinely better tool in every meaningful dimension: better materials, safer operation, easier maintenance, and longer service life. Add dealer support — servicing, spare parts, warranty — and the picture gets clearer still. Where do you take this saw when it breaks down? Are parts even available? No. You bin it and start again. And if it fails catastrophically and puts you in hospital, who's picking up that bill? Someone in a warehouse in China? Amazon?
From here, I'll be putting it through its paces and seeing how it stacks up against the other saws in the collection.
D
D.F.B
Australia
hmm seems brave given your concerns, good luck
The plan was to buy it, make some content with it, then sell it off cheap. However, unlike the Chinese and Amazon, I wouldn't feel comfortable selling it to someone with a defective safety feature. In reality, it should be returned.
D
D.F.B
Australia
Comparison with the Competition -
My first look at the H-YEEU immediately brought ECHO to mind — specifically the CS-2511 TES and CS-280 TES. In my opinion, ECHO make the best petrol-powered top handle saws on the market, so at least H-YEEU had the good sense to clone the right ones.
https://www.echo-australia.com.au/en_au/products/chain-saws/top-handle-chain-saw/cs-280tes_37
Other high-end sub-30cc top handles worth mentioning are the Stihl MS 151 TC-E and the Husqvarna T525.
https://www.stihl.com.au/en/p/chainsaws-ms-151-tc-e-petrol-chainsaw-102617#ms-151-tc-e-102617
https://www.husqvarna.com/au/chainsaws/t525/
I'll acknowledge that this Amazon saw probably isn't in direct competition with saws from Stihl, Husqvarna, or ECHO. Anyone considering a sub-$100 chainsaw is unlikely to be weighing it against something seven times the price. But these clones are clearly influenced by what the established players are building, and being a spreadsheet guy, I thought it would be interesting to see exactly how the H-YEEU stacks up on paper.
I included not only the ECHO, Stihl, and Husqvarna benchmarks, but also the battery-powered Stihl MS 140C from my own collection, plus another contender I'll cover shortly. The pattern is clear enough — the higher quality tools deliver more power, higher revs, and less weight. The Amazon saw's 25:1 mix requirement is worth noting too; either it's playing it safe for occasional users, or the engine quality is poor enough that it needs the extra oil just to survive the warranty period. The battery Stihl is interesting because its electric motor produces the same power output as the 25.4cc H-YEEU — which says something about both.
(Prices are in AUD)
This H-YEEU is the same saw rebranded and sold under countless names at wildly varying prices — Huyosen, Aowei, GTP, Patelo, Vevor, Temu, to name a few — ranging from $115 to $180. You'd be pretty annoyed discovering you paid $180 for a $72 chainsaw.
Bunnings are in on it too. The exact same saw is sold there under the Cheetah name — a product Victa supplies to Bunnings to hit a price point without putting the Victa badge on something like this. Granted, you get a 12-inch bar, but is otherwise identical. So how much does Bunnings charge for a $72 chainsaw? $155. How does the jingle go, "lowest prices are just the beginning" — well, clearly not in this case. It also tells you just how much margin is baked into this stuff when Amazon can sell the same saw for less than half of what Bunnings does.
One more discovery after working through the owner's manual — the chain is supposed to be Oregon, which is probably the best component on the saw. The manual also recommends 10W-30 motor oil for bar lubrication, which in my view is too thin; it won't stay on the chain at full speed. For reference, the LD-M7 spark plug crosses with an NGK BPM7A or Champion CJ8.
Coming up next — what entry-level saw would I actually recommend? It might not be what you're expecting.
customh
East Bethel, MN
If you're true to your roots it'll be a Stihl. Not sure what our definition of "entry-level" is though :ROFLMAO:
My opinion would be to buy a decent battery saw first, unless you're cutting a pickup-load of firewood. I'm curious to see what you recommend though!
D
D.F.B
Australia
Spot on! (y)
PhantomEB
Medicine Hat, AB, Canuckistan
Meh, nothing wrong with various saws. I have a Homelite that’s getting overhauled and living in the camper until I get my Quad, then a Stihl in the back of the bronco and a Husqvarna in the enclosed trailer. Ryobi cordless for around the house is in the shed.
D
D.F.B
Australia
It's taken a month and lot of dead ends, but I finally have a new(er) set of wheels for the Rover Craftsman.
Last time I bought Rover wheels, I had several outlets offering exactly what I wanted.
This time, I had a lot of trouble getting what I needed.
So, new OEM Rover wheels are getting thin on the ground. No problem I thought, the aftermarket will have me covered. GA Spares have supplied aftermarket Rover wheels for decades now, but even they are getting harder to find now. This is where it got confusing.
The OEM part numbers I needed were A03337 or A10620 for the 6.5-inch fronts, and A03320 or A010621 for the 7.5-inch rears. That then translates to GA Spares with WWP6827 and WWP6829..............which are NLA as well. But then I found another set of numbers for wheels that look exactly the same, WWP1522 for the fronts and WWP1523 rears. Great, lets go!
While the second set of numbers, WWP1522 and WWP1523, are indeed available still................. the signature Rover hub caps do not fit. That's because the "sidewall" are taller on the OEM spec, the later versions are low profile, meaning the hub cap isn't big enough to cover the spokes. Of course, I found this out AFTER messing about with at three suppliers.
Incorrect on the left, OEM on the right.
Now, if I wasn't so particular in staying OEM (or OEM-like), I could just run those new wheels without the hub caps and call it good. But that's not how I roll. So, I tracked down some used wheels meeting the correct A03337/A03320 or WWP6827/WWP6829 spec. Fast forward a month, I now have two rears and four fronts to choose from.
Being used, they have a few nicks and scrapes, and were naturally quite dirty. But, they have tread and came with bearings and rear dust caps. I decided to give them a good clean using Shine Supply Wise guy and a tyre brush, then hit them with the pressure washer paired using the turbo nozzle.
From here, I did my Tarminator trick to clean the "sidewalls", then wiped down with IPA. Clean and dry, I applied some Solution Finish to restore the black "sidewall" and treads.
The difference between new and used in terms of blackness is marginal after treatment with Solution Finish.
Overall, they came up great for used mower wheels. I have some NOS chrome hubcaps to complete the look once fitted to the mower.
D
D.F.B
Australia
Bought a new TV today. I went up a couple of sizes but showed restraint in not buying one of the massive trophy TVs people seem obsessed with lately. Not sure if it's just me, but I find them disorienting.
I went shopping for an LG or Samsung and landed on a 43-inch LG QNED evo AI QNED80. I'd considered the 50-inch and briefly wondered if I'd made the wrong call, but once it was out of the box at home, I was glad I stayed modest. An unprompted $150 discount was a nice bonus too.
https://www.lg.com/au/tv-soundbars/qned-evo-tv/43qned80bsa/
I've mentioned before my hatred of "smart" TVs — especially when my parents are involved, because they always manage to hit something wrong on the remote and lock the whole thing up. Guess who gets called to fix it? And I still don't understand why I need an LG account just to make the TV work, but I suppose that's how it is these days.
Thankfully, setup was mostly smooth sailing — connecting to Wi-Fi and loading up YouTube, Netflix etc. This is where LG insists you create an account, otherwise it won't let you load apps like YouTube. Another pointless hoop to jump through that's really just about harvesting your contact information.
I also connected my external sound system. I'm not a soundbar person — they basically just make the TV sound how it should out of the box and rarely deliver the experience you were hoping for. Some are better than others, but they simply can't replace a proper audio setup, even if it's more expensive and complicated to get going.
In this case, I have set of PSB AM5's and SVS SB1000 Pro sealed subwoofer. The AM5's are powered bookshelf speakers, meaning they have a built-in amplifier. I ditched the supplied speaker cables for quality replacements with proper spade connections, same for the sub.
https://www.psbspeakers.com/products/alpha-am5-powered-bookshelf-speakers?variant=46656991101113
https://www.svsound.com/products/sb...jBVi3yRYxhOa1pJ-TJQd9mm9R7VPErf5wHfJx0WOG-llM
While you can connect the PSBs to a TV via optical cable, I've had some weird feedback issues with that method. You can also connect via aux or Bluetooth, but you lose quite a bit of punch. So instead, I run a Bluesound Node digital player, which takes audio from the TV via HDMI and processes it through to the PSBs via optical for higher-quality lossless sound. Simplistically, the Bluesound Node is suitable for powered speakers like the PSB AM5's, while the Bluesound Power Node would be for passive speakers, effectively the amplifier.
The Node is also a much better way to connect via Bluetooth when streaming music from your phone or a music app. Rather than your phone acting as the source and driver, it becomes a remote — the Node does the heavy lifting. On top of that, the Node opens up a wider range of tuning options through the BluOS app. The sub is also tunable via the SVS app. Lastly, if you have an older audio system or amplifier, the Node is a great way to modernise it with Bluetooth connectivity.
For those that don't know, Bluesound and PSB are made by N.A.D.
The one I have - https://www.bluesound.com/products/...TcP_RLap6eQKZcrH4KdgEAEGRAmhCauG8JE3llpPo2jLM
The current model - https://www.bluesound.com/products/node?_pos=5&_sid=23a397eeb&_ss=r#specifications
Not predicable at all.................
Just a tip, if you have the ability to do so, always choose a white finish on stuff like this as it hides dust and fingerprints.
And thank goodness — one less Sony in my life. I'm not sure if I'm just unlucky, but every Sony device I've bought has been a massive disappointment, if not an outright disaster. I have no problem paying a premium for a genuinely good brand, but I have a big problem paying top dollar for cheaply made junk with a premium badge slapped on it. Some barely made it to the warranty period; some were faulty right out of the box. That frustration hits hardest at the end of a long day when you just want to flop on the couch and unwind — not spend half an hour wrestling with your fancy TV or overpriced noise-cancelling headphones.
Anyway, not garage or detailing related, but something I've been working on recently.
D
D.F.B
Australia
New wheel day for the Craftsman!
There were three things that were counting against this set of wheels.
1. The tread was virtually toast, one having a weird slash on it. I can hear you asking, why does that matter, it's not a car. Well, the worn tread causes the uneven cutting.
2. The wheel bearings were toast.
3. They looked jacked up, from the scraped hub caps and sidewalls, the paint overspray, the lack of tread.
As always with Rover wheels, the hardest part is dealing with those stupid press-fit retaining washers, be that removal or installation. Hate them!
The new secondhand wheels are the later type with horizontal rather than vertical treads. The bearings on the original wheels were completely toasted. I had planned to use the bearings the secondhand ones came with, but they were borderline — and since I'd come this far, I figured I may as well use new ones.
Bearings - NBR UGB0818F
Each axle was cleaned with a scotch-brite and lubricated with a small amount of marine grease. On one of the rear axles, I had file and sand some light burs that were preventing the new bearing from fully seating. The new retainers were then installed with an old socket and hammer. Sometimes you get lucky and they go on without argument, sometimes you end up making several attempts.
The final step was fitting some brand new chrome hubcaps. I got a bunch of these for $0.20 each, they must be clearing them.
https://powermowers.com.au/products/cmp6618-hub-cap-for-wwp6618-ww6623?_pos=3&_sid=1bdb1f613&_ss=r
Following that, I gave the whole mower a scrub down with Shine Supply Wise Guy, then a rinse with the pressure washer. I then applied HydrO2, then Meguiar's Hyper Dressing and a hit with the blower to dry it off.
For a 40-year old mower, it doesn't look too bad.
For now, I'm calling this one finished.
D
D.F.B
Australia
Now that I've officially finished the Craftsman project, it's time to look over what I spent on it to bring it to spec.
First, a little explanation on how I buy used mowers. My process involves a daily scroll of Facebook Marketplace. When I find something up my alley, I'll follow through... but it has to meet my requirements.
There are two types of sellers on this platform. The first is someone who has just bought a new mower and is trying to get rid of the old one. This person is happy to get some money for something they want out of the garage. The second seller is doing this with the intention to make money. They acquire a mower on the cheap, clean it up, fix anything major, then flip it. These mowers are either bought at a tip shop for $10 or retrieved from the side of the road for nothing. Then they list them for $100–$200. It's a very lucrative endeavour, especially when very few parts are needed.
There is nothing wrong with either type, but the key is knowing what type of seller you're buying from. Over time, you start to recognise the regular mower flippers and which are one-off sales. From what I've noticed, the flippers are selling entry-level mowers — ones the previous owner didn't care for and therefore left on the side of the road or dumped at the tip. Think entry-level engines and banged up, rusting steel bases. If the previous owner didn't see value in the mower by letting it go for nothing, how much life is really left in it?
The ones you want to buy from are the one-off sellers. In wanting to exchange some money, they obviously see value in what they're selling. These mowers are usually higher-end models with bigger engines, an alloy chassis, and more life left in them. You pay a little more, but you get a better starting point and a more honest transaction.
So it's safe to say I'm normally very selective in what I take on. I don't want to pay money for someone else's neglect or misuse, or for work I'd only end up redoing myself. I also don't like to haggle, so I choose very carefully and pay the asking price — everyone's happy.
Which leads me to this Rover Craftsman. At first glance, it looked honest — a little banged up, but nothing I couldn't deal with. On this occasion, the seller came to me, which was probably a mistake on my part; he made the effort to turn up, so telling him no thanks would have been awkward. Having said that, I was happy enough to pay the asking price after it fired up and ran smoothly. Turns out the guy had left one of the local mower shops and was fixing up mowers on the side — so in effect, I was paying a little more for that apparent expertise. In hindsight, I paid too much after finding some hidden faults. But that's how it goes sometimes.
The most obvious issue was the lower oil seal, leaking like a sieve. To me, this really should have been addressed by the seller. As a mechanic, he would be well aware of the implications of leaving a seal in that state — and he knew it was an issue, because the underside of the deck was spotless while the blade carrier was soaked in oil. Again, this comes back to the desire to maximise profit rather than always doing right by the customer. If it were me selling that mower, I wouldn't feel comfortable handing it over with such a major issue without either admitting to it or pricing accordingly.
So with that, let's look at what this mower needed to be a functional machine.
The oil in it was brand new, but with the leaking seal I drained it to contain the mess during the seal removal process — hence the oil change. The handlebar locks were toast and absolutely needed attention. I decided to include the throttle parts because the original throttle wasn't working very well. The fuel cap was leaking, and the governor spring had been tampered with. The wheel bearings were totally necessary, as was repairing the catcher. Other items like the plug and axle bushes were common service replacements.
Now let's look at what I actually threw at it — and this is the difference between what most would consider a working mower, and one that a nutjob like me considers worthwhile.
Many of the additional items were "because I can" and "because I want to" replacements. I could have got away with new bearings in the wheels, but that didn't address the cosmetic faults. The starter handle was purely cosmetic. The head and valve clean wasn't necessarily needed, but worth doing. The blades still had life in them, but I was concerned about the disc and the aged bolts — hence a total replacement of the cutting hardware. New wheels and hubcaps were mostly cosmetic. The muffler was indulgence.
So, just over $500 for a 40-year-old lawn mower worth $150, tops. While this mower has needed the most remedial work of any I've done, that doesn't make it financially viable. But... what price do you put on learning how to remove and replace a crank seal? Or the process of hunting down the right parts — especially ones considered NLA? How do you value the enjoyment of working on something and seeing the fruits of your labour? How do you value sentimental contentment?
I always come back to the same argument: what does the total cost of buying and restoring this old mower get you when shopping brand new?
Firstly, I’m not even going to bother looking at the various no-name stuff sold through hardware stores, Aldi or Amazon. So, lets look at three machines from established players.
Bushranger – For around $500, your only choice here is the $459 46TL4M Mulch & Catch (Bushranger really need to work on their product names). This one uses the old 18-inch Rover steel chassis and powered by a 139cc Loncin engine. For $499 you can also have the SupaSwift version. Pass on both.
https://bushrangerpe.com.au/products/lawn-mowers/46tl4m-mulch-catch-lawn-mower
https://supaswift.com.au/products/lawnmowers/supaswift-777amc-18-push-mower
Masport – At this price point you are looking at 16.5-inch and 18-inch steel decks fitted with crappy wheels, and 123 to 139cc Chinese AL-KO Chonda’s. At least here you would have a dealer network behind you. I’ve never been a fan of the steel Masport’s, so again, pass.
https://masport.com.au/category/outdoor-garden-products/petrol-lawnmowers/other-petrol-models/
Victa – There are four sub $500 models, none of them I would choose. Of those, the V144 uses a real Victa chassis, but it has that crappy Chinese engine. The other three are just rebadged junk. So, the real entry point is the $539 Corvette 100 or Super Mulcher with the 140cc Briggs.
https://www.victa.com.au/products/lawn-mowers/victa-2691845-18-corvette-100-steel-base-push-mower
https://www.victa.com.au/products/lawn-mowers/victa-18-super-mulcher-petrol-lawn-mower-2691982
But what about a new Rover? Doesn’t exist anymore. Actually, that Bushranger and SupaSwift are about as close to a new Rover you can buy these days. Of those above, I’d favour the Bushranger or Victa Corvette 100.
But the common theme here is that all of the models shown above come from China — from the Chinese Honda knock-off engines to the steel chassis. The Rover Craftsman was made in Eagle Farm, Brisbane. The engine was made in the USA. The chassis is aluminium. The catcher flap is steel, not plastic. The height adjuster quadrant is steel, not plastic. The wheels have double ball bearings; the Victa has a single ball bearing and plastic bushing. So even though it's 40 years old, the Rover still has plenty of years left in it. I'm not confident you'd be saying the same about one of those Victas, Masports or Bushrangers at that age.
Before -
After -
So, that’s my story and I’m sticking with it. I’ve had fun with this one, and that’s all that matters.
D
D.F.B
Australia
Aren't those washers a pain?
Soooooo, just found out that I've been fitting them wrong for 25-years. I can't believe I didn't pick up on it sooner as it's been staring me in the face all along.
This is how I've been fitting them -
This is how they are supposed to go, as per these factory fitted on these examples -
So, I've been fitting them upside down. Don't feel like an idiot. :rolleyes: :unsure:
Geoff289
Melbourne, Australia
I've only wrestled with those washers a couple of times but no doubt I made the same mistake. What turns out to be the correct orientation seems a bit counter intuitive to me but that might be an aesthetic issue with the lip around the circumference facing out not looking as neat to me. Anyway, you'll be right next time.
kitdoctor
Sunshine Coast, Australia
My orientation is to always start my research when buying a major item for a Japanese, then European (e.g. German, Swiss) and then North American product. Taiwan is another option (e.g. for good quality tools). Of course sometimes there is no choice but to accept a Chinese product.
D
D.F.B
Australia
Wise man!
D
D.F.B
Australia
Enjoying some seat time in old blue at the moment.
The XR6 turned 18-years old at the end of May, and I took delivery of it a few weeks later on June 13th, 2008. From placing the order in April to delivery, as an impatient 21-year-old, it felt like I waited forever to have the keys in my hands. But oh, how things are different now. Back then, if the dealer didn't have the spec you wanted in stock, you could easily factory order you one. The waiting time for a factory order was weeks, not months or years like it is now. For context, I waited 12-months for my first Mustang in 2017, and 2-years for my S650 Mustang.
The reason for a factory order? Well, the dealer didn't have what I wanted, nor did I want to compromise for something they had in stock or in the production schedule. From my point of view, why spend all that money and not get what you exactly wanted. The sticking point was the blue coloured seat trims, Option 5A, and the 6-speed ZF automatic (Option A). I also ordered items like Premium Sound (Option 54) and side curtain airbags (Option 6Z) as standalone options instead of blended into option packs such as the Luxury Pack (Leather trim, premium sound with larger colour screen, dual-zone climate control, Bluetooth and iPod connectivity, carbon-style trims, & 19-inch wheels), the Tech Pack (Bluetooth, iPod connectivity, ) and Safety Pack (curtain airbags, adjustable pedals, alarm).
With the Luxury Pack, I didn't like the 19-inch wheels, nor the standard 17-inch items, I wanted those signature 18-inch Y-spoke wheels (Option 2R). I also wanted the blue cloth trim instead of leather. Combined with those grey interior finishes, the "basketweave" black leather contributed to a plain, cheap, dungeon-like appearance. At the time I didn't see the need for the Tech Pack, and I only wanted the airbags from the Safety Pack. Hence the À la carte order.
See if you can spot the error on this Ford Verification Letter -
Luxury Pack Interior -
Standard XR-spec Interior -
19-inch XR wheels -
18-inch XR wheels -
17-inch XR wheels, which were proportionally way too small -
I just wish I stretched a little further and got the Turbo engine, if I had, this vehicle would be worth 3 times the price.
D
D.F.B
Australia
No doubt I'm not the only one who was being spammed with ads for this brush across multiple social media platforms. After I noticed a few positive comments from people I trusted, I thought I'd give it a go. For $30 and a few bucks for shipping, it was worth a shot, my hope was to replace the EZ-Detail brushes in my arsenal.
Elyra Viking Wheel Barrel Brush
Well....................my delivery from Chiiiiiiiiina arrived today. This is what turned up in an unlabeled box made from the thinnest carboard I've ever encountered.
Tell me, does that brush look like the one promised in the marketing content? The handle is wrong, and the brush material is not even close to the same. Instead, this is just a microfiber brush. Actually, it's so thick and bushy that it doesn't fit between the wheel barrel and brake rotor, you know, like the marketing suggested it would.
I don't know who I'm more annoyed at, them for taking my money and sending some random brush they found in a warehouse somewhere, or me for breaking my own rules and buying a social media brand product. I've done that in the past, only to discover that all of the effort goes is the marketing material, not the product itself.
Let's be real here, no mater who "Elyra" claim to be, it's just some faceless marketing company selling cheap sh.t to social media consumers. And I fell for it too. I'd ask for a refund, but who do I contact in China for that? The only way to contact them is via email, and how do I prove they sent me the wrong brush if there is no way to send an image with it. They know exactly what they are doing.
My advice, you know the advice I chose to ignore myself, NEVER EVER buy products marketed on social media and nowhere else. Buy from proven, established brands with actual ethics and customer satisfaction as the priority.
Not happy!
moab11
Thunder Bay, Ontario
I'd still email and complain to see what they do/say. Doesn't cost anything at least.
Still ***** that they pulled a switch, like you said 90% marketing, 10% product.
D
D.F.B
Australia
Old Blue collected an unusual number of bugs the other day, well it was "bugging me" so it needed to be addressed. The longer bugs sit on paint, the more likely they are to leave permanent etchings behind. Acidic proteins and enzymes can eat right through ceramic coatings, waxes, and sealants down into the clearcoat, permanently etching the finish. At that point, you might wonder what the point of the coating or wax is in the first place. In reality, the protection buys you time before the etching sets in. Bug removers don't remedy the damage, they simply break down the bug itself, not the etching. Polishing the etchings out doesn't work either. In other words, don't sleep on it.
The car otherwise wasn't very dirty, so I went with Armour Detail Supply Hero rinse-less wash. Before that, I foamed the wheels with Bilt Hamber Touch-less, then scrubbed the tyres and rinsed. Drying Aid was a light amount of ADS Adapt, also used on the door jambs and engine bay. Tyres were treated with OG Tire Dressing, glass via Traceless (trying to use that **** up), interior ADS Pilot.
I also treated the steering wheel, gear shifter and handbrake with ColourLock Leather Protector.
ChadTexas
Amarillo Tx
I enjoy the wash updates. I have been using ADS Hero as well and it works great.
I did give up on SiO2 sealants. I got tired of my towels getting clogged.
Keep up the good work!
D
D.F.B
Australia
Amazon Chainsaw First Cuts –
Considering some of the things I found during assembly and first start, I was a little hesitant to put this saw to use. But curiosity prevailed, so I set up the sawhorse and camera and got to it.
Let's acknowledge that as a top handle saw with a small engine, big cuts really aren't its forte. For the most part, top handle saws are for pruning and arborist work, where light weight and maneuverability rule. Still, I was keen to see how it would do.
This is the smallest capacity and least powerful chainsaw I've used to date. You can see the lack of torque in the video, with the engine stalling relatively easily despite only cutting pine. The short bar and lack of meaningful dogs mean you have to constantly feed the saw, rather than using the dogs to pivot off the timber and let the weight balance feed the cut. Again, that probably isn't an issue for its intended use.
The lack of power also makes for a slow cut — I ran my old Stihl 009L through the same log, and the H-YEEU was almost three times slower. I'll have a video on that comparison soon.
Even though I have 25:1 fuel mixed for the Victas, I just used my usual 50:1 mix with Stihl HP Ultra synthetic oil. The manufacturer recommends 25:1, but I'm running this saw like any of my others — no special treatment. Bar oil was Stihl SynthPlus.
So, has the Amazon H-YEEU chainsaw redeemed itself? Yes and no. Considering I was using it well beyond what it was designed for, it did the job fine — but I'm not someone who's satisfied by "fine." On one hand, it did what I asked of it. On the other, its usage is really limited to light garden pruning; push it harder than that and you're working beyond its limits, and that's when accidents happen. The lack of a functioning chain brake is hard to ignore as well, and only adds to that risk.
So, if you're after a saw for a range of jobs — garden work, the occasional camping trip, firewood — I'd still say look elsewhere. A slightly larger, more powerful saw would be quicker, easier, and safer, all things considered.
And if this saw really is limited to light pruning, a battery saw would do that job just as well, without the hassle of fuelling and maintaining a two-stroke engine. I can't believe I'm saying this, but a battery saw is the better option here.
The real question is: who is this saw for? It's not well made enough for professional use, even though its capability would otherwise suit the role. It isn't versatile enough for the occasional user. And for light duties, a battery-powered saw is simply the better choice.
Which leaves me thinking this little saw has no real purpose — and in the coming years, I suspect you won't find anything like it for sale at all. Battery power will take over, and small petrol saws will be left to professional users, with a price tag to match.
D
D.F.B
Australia
An Unfair Comparison?
After much nagging, in the early 2000s I dragged my Dad down to the local Stihl dealer to buy a chainsaw. Back then, we had a potbelly stove to heat the garage over winter. We'd either buy pre-cut and split firewood, or go with the neighbour next door to cut and collect — he supplied the saw and cut the wood, we provided the truck and manpower to load it all up. I'd stand there and watch in awe as the neighbour ran his Stihl 028 Super, which I now own. Under the guise of "we need one too," I convinced Dad to buy a chainsaw.
I've told this story before, but I walked out of the Stihl dealer that day excited, yet quietly disappointed. You see, I wanted something that looked like that awesome 028 Super. Instead of taking home a 017, 018, or 023, Dad decided on the 009L. Its form factor was completely different to the rest of the MiniBoss range — it just didn't look like a Stihl, and that mattered to 14-year-old me. For one, it's neither a true top handle nor a true rear handle. And aside from the small air filter cover, it also lacked the swathes of classic Stihl orange.
Looking at that old brochure I dug out of the collection, I would have been happy with something from the Woodboss range, the 023 or 025 for example. I would have been delighted if Dad ponied up for the 038 Magnum, which was the big brother to the 028 and carried the same old-school form factor and exposed cylinder fins.
The 009 traces its roots back to 1980, before being updated to the 009L specification. The 009 had a 36.6cc engine, which then grew to 40.8cc for the 009L. For such a small chainsaw, both capacities were actually quite stout — for context, the 017 only had a 30.1cc engine. On top of that, it had two piston rings instead of one, and a full magnesium case rather than the plastic sled of newer models. The main drawback of the 009's age was that it predated anti-vibration technology, something you really notice next to modern saws.
In terms of application, the 009 was too heavy and bulky for top handle tasks like pruning or arborist work — the true top handle MS190T and MS200T did that much better. But with such a big engine, the 009L was actually a decent firewood or camping saw. I remember at the time a friend commenting on how tiny it looked, then he ran it and went "oh... it's actually got some grunt." Our 009L came with a 14-inch bar instead of the standard 12-inch, which again helped with cutting larger logs.
Long story short, I still have that old Stihl. I've barely used the 009L since getting a battery-powered MS140C, inheriting the 028 Super, and buying my dream chainsaw... the mighty MS500i. Over the years, it's had one spark plug, a couple of air filters and chains, a replacement oil cap, and I recently rebuilt the carburettor and replaced the fuel filter.
So, how does this old Stihl compare to a new Amazon saw? I realize I'm not comparing apples to apples here — the engine capacity favours the Stihl significantly, and there's a 4-inch difference in bar length. I'm also comparing a brand new saw with one that's well run in. Nonetheless, I was curious to see what the actual performance difference would be...........
The on-paper power figures don't tell the full story of the 009L. For example, the 018, which sold side-by-side with the 009L, produced similar power from its 31.8cc engine, and the similarly sized 023 produced more power. But it's the lower-revving, high-torque nature of the 009L that set it apart from other saws in the Stihl lineup — and ultimately, that's what made it nearly three times faster cutting than the Amazon saw. Again, hardly a direct comparison, but an interesting one to see play out.
Take the cut speeds with a grain of salt — they were roughly timed with my phone, but the pattern is clear.
Note how both ask for 25:1. During its firewood years, I ran the 009L at 25:1, as that's what my line trimmer used too. When I started buying other Stihl tools, and ultimately moved to synthetic HP Ultra, I switched to running it at 50:1. The 25:1 ask on the 009L would date back to it being an older design, even by 2001 when it was new. The Amazon saw's 25:1 recommendation is either because it's poorly made and needs the extra lube, or to stay on the safe side for non-mechanically minded users......... or both.
As I alluded to in the previous post, using a saw beyond its capabilities can actually be more dangerous than using something larger and more powerful — the same concept as a blunt knife being more dangerous than a sharp one. I guess what I'm saying is: be absolutely honest with yourself and the salesman when buying a chainsaw, and don't settle for something under your requirements. The $100 saw will do the job, but the $500 saw will do it quicker, easier, and... safer.
