Scissor truss question
markomarko
Regarding my scissor truss gable end engineering plans. Is my gable end scissor truss being delivered with a flat bottom piece of lumber on it? It’s being delivered Monday and I’m trying to wrap my head around it. I circled the piece in question.
CraigStu
Blacksburg, Va
Why would there be a scissor truss on the end wall. Seems like a standard truss matching the roof line and a standard wall would be a he11 of a lot easier.
mike93lx
Richmond, VA
That makes it hard to properly brace the trusses and tie in the ceiling. Check out the link I provided above.
The Gable framing needs to match the ceiling profile
Firebrick43
West central Indiana
M
markomarko
Another thing I just thought of. If I balloon frame, what’s keeping the exterior walls from kicking out since there’s no double top plate under the scissor truss?
PCustoms
VT
Huh?
Double top plate isn't about walls kicking out, it's about proper load transfer from roof to wall framing.
You have 8+ feet of 2x material continuously framed up and attached to the truss, which is tied back to the rest of the roof trusses. Why would the wall "kick out"?
mike93lx
Richmond, VA
Huh?
You have 8' feet of 2x material continuously framed up and attached to the truss, which is tied back to the rest of the roof trusses. Why would the wall "kick out"?
And there is almost no downward load on that wall.
@markomarko it feels like you are getting way ahead of yourself on this build. You have trusses showing up but don't know how to frame the walls. How was the building designed?
PCustoms
VT
firebirdparts
Kingsport, TN
That’s not a truss pictured, so it’s very weak. That is why you need that brace.
Just to be clear, I am intending my response to be on topic. I am not making commentary on balloon framing but rather delivery
