dang, thought I replied the other morning, guess it got lost in hell.
Mine is just a plain set screw, screwing directly to the shaft visible thru the hole. I believe the shaft is split above and below the bearing. When the top shaft is locked, the quill is extended by unthreading from the bearing. But that would imply losing the flywheel effect, which does not seem right.
Looking at yours, I’d assume the quill advances by extending out the fine thread, which I’m guessing might even be 2x the coarse thread.
