looking for some diy shelf /cabinet ideas for garage long wall
merim123
NW BURBS CHICAGO
Trying to figure out what I want to do with my long wall on my garage. This is the parallel wall to how the cars are parked. I have about 20' that is usable. Ceiling is only 8.5' tall, so not a lot of room. I was thinking some kind of grid made with 2x4 or something along those lines. Cabinets are flimsy I think, want to put some car stuff on them and need to carry the weight.
Any ideas/thoughts/pics?
mypov
Redman - Just wanted to let you know that I thought your shelves look great! I used the idea and built a set for my boss - he was really happy with them. Thanks for the idea! Were those cabinet shelves (the upper ones) in your pics difficult to make? It appears that it would be fairly simple to add some face trim and then some doors (if one wished). Anyway, nice handy work...
Cheers.
Merim - there were too great threads for you to look at, simple search finds them out. Something like storage ideas, genius storage ideas, or shop storage...Hours of browsing, lots of pics, and examples for ideas. Best of luck. Maybe if you took some pictures to give the impression of space you have to work with - could inspire more thought provoking ideas as well.
Cheers.
kbs2244
God looking shelves.
I like mine painted white.
It makes finding things easier.
Something I learned a long time ago was to paint all the wood before cutting and building.
It is so much easier than trying to get paint into the corners of those boxs you just built.
You can get both sides of the sheets and all four side of the sticks so everything will be covered.
The only thing left is the small stuff where your cuts were made.
redman43
Lake Stevens, WA
Cheers.
Thanks. I assume you mean the units above the workbench. It was all pretty straightforward since I used a Kreg jig to do the pocketholes. I don't think I would have even attempted it without that $100 jig. The hardest part was cutting everything square and to the same dimensions without a table saw. I had to do it all with a circular saw and then trim it with a flush cut bit in my router. Face frames and doors should also be a pretty straightforward task, but I haven't had the opportunity to do it yet.
Dan'sGarage
Merim123,
Here's what I did with my long wall...I installed a closetmaid system with vertical standards over a framed pegboard (look at the last set of pictures). This allowed me to make the shelves adjustable and still have pegboard for items in between. I plan on having deeper shelves (18" x 16') acrossthe top for larger tools and gear. This also places them above the cars. I will use smaller shelves like 12" and 8" deep shelves down below to house parts, cleaning supplies, etc
Something similar might work for you as well for your long wall. Mine is still a work in progress and once it's complete I'll post more pics. Anhyow, here's the link.
http://www.garagejournal.com/forum/showthread.php?t=106770
lowbucktruck
Foothills, Northern California
Merim123:
You didn't mention how deep the storage could be (without impacting your cars). When I planned my long wall storage, I parked a car inside first and got out the tape measure, to figure out how deep the storage could be, and still be able to open the car door safely. I decided on no more than 20 inches deep. Of course, in my case that was the passenger side... so I could still back the car out of the garage first.
If you are going to be storing car parts (which may be heavy), you might want some kind of metal shelving system that can handle the weight, and can be anchored to your wall. I built my own from Steelworks slotted angle uprights and steel shelves (which are adjustable).
http://wedo.hillmangroup.com/viewitems/metal-shapes/plated-steel-slotted-angle?
Like a really big Erector set. :)
Porcupine
Canada
Another good idea for adjustable shelving would be to check out the Heavy Duty Galvanized shelving system from Lee Valley. You can get different lengths of rails and shelf brackets that are rated for 300lbs each (supported brackets), and they come in different lengths. I was going to make my own shelves out of 2x4 and plywood, but I wanted the flexibility of being able to adjust them at any point in the future. Since I can get differrent lengths of brackets, I can make my shelves shallow or deep. In my case, I cut a sheet of 3/4 plywood into four sections for shelves about 12 inches deep. There are several great ideas on this site for shelving and storage which you can check out.
merim123
NW BURBS CHICAGO
thanks for all the posts, comments guys. I'll get some pictures of the wall and the room I have. I don't want to go all the way to the floor, I do want to do something like redman did. I do like doors though and closing it off from view.
I built some cabinets on the parallel wall that are 24x48 with 24" doors. They are a little too big, but not far off.
you can see them here in the background in white
the wall we are working with is about the same dimension without the door opening and no windows.
MG David
Warwick UK
Depending on what you do in your garage it may be worth having doors to enclose all or some of your shelves. This will reduce the amount of dust etc landing on your tools and parts. Jobs like grinding, sanding and paint spraying will generate alot of dust.
Ramblur
Central FLA
Well not my long wall but parallel to the cars. I scored this 2' wide pallet racking for a C-note at an auction. I believe its 1500lbs. per shelf.
merim123
NW BURBS CHICAGO
that's a killer score on the shelving!
jazz - have you built that yet that you have some pics to share?
alabamavolvo - thanks for the links, the cleats look interesting in giving you ability to change.
hunt4cleanair
Hey lowbuck
I like this stuff. I'm doing an engine resto and have starters, compressors, alternators and carbs laying around the garage and realized I need some "upper" storage to store these larger type items. I like the idea of a flexible storage shelfs.
I went to the site but they said they sell only to distributors. How can I go about deciding what I need and how to get it? What does your system look like? thanks
elevator joe
MN.
2x4 frame with sliding doors on a pole barn track. holds a lot of stuff,doors cover it all up....?
DIYKiah
Harnett County, North Carolina
I know this thread is rather old but if you have an average garage with studs behind the drywall then check out DIYGarageShelf and their line of garage shelving kits. They are really easy to install and much more affordable than most stuff you will find out there!
