PSA: Kidde recalling MOST plastic handled fire extinguishers
rlitman
Long Island
The recall appears to cover most of their plastic handled fire extinguishers (including some that were previously recalled), plus their gauge-less pushbutton extinguishers.
Apparently, they've got an issue with them failing to work. They're on the hook for replacing nearly 40 million extinguishers.
https://www.cpsc.gov/Recalls/2017/k...astic-handles-due-to-failure-to-discharge-and
if you're in the US (the recall extends to Canada too), you can get to the forms here:
https://inmarmarketaction.com/kidde/Kidde284US/
edit:
Video with the best description of what is and is not recalled:
Moderator edit: I've made this a sticky and will leave it here till the end of the year.
ford33
Chicago, IL. USA
Re: PSA: Kidde recalling all plastic handled fire extinguishers
I just checked my home and I have two that are on the recall list.
This is a very large recall. Some of the extinguishers go back 20+ years.
Fill out the online form with extinguisher model number, serial number and date code. When you submit the form, they will send a replacement extinguisher and a return box for the old unit.
No cost to you.
Consumer Products Safety Commission has attributed one death of a motorist who died as a result of a failed extinguisher. Hundreds of reports of failed extinguisher to CPSC.
dave89iroc
outside Detroit, Michigan USA
No cost to you.
42 years, the list starts in 1973
Ign
Butte Peak ND
Kidde's whole marketing campaign and image has been on how "safe" they are, or make us safer I guess you'd say.
My dark humor finds this mildly amusing.....
nh_yota
Seacoast New Hampshire
I think I have a few of those in my house.
On a related note - can anyone recommend a good but affordable "professional" fire extinguisher for a home/basement/garage? I see the Amerex brand around my office so they must be half-decent enough for fire protection companies to sell.
R
rlitman
Long Island
Amerex makes good stuff that's not disposable.
I read somewhere that Kidde extinguishers being replaced by this recall will now have metal valves. That's a good step in the right direction.
dave89iroc
Amerex is good, thats what I have
gungatim
west mich
I have a number of these, some empty I saved for projects. are they going to replace anything with a valid serial # I wonder? or will we have to send them back?
This could be bigger than the HF class action lawsuit since most of mine came from yard sales and stuff...i'll have to check the scrap bins when I get home.
MoonRise
Oh boy. Only 37.8 million units listed as affected. Plus another 2.7 million in Canada.
I probably have a few. Sigh, more **** to do now.
R
rlitman
Long Island
My understanding that that they will send you a replacement for a unit with a valid serial number, plus packaging for the return of the defective one.
mrpizza
IL
I have one in a box that got stored, and likely 4-5 more around the house. Better start looking I reckon.
Dragfluid
Pillager, MN
If you care about your home/shed, get REAL fire extinguishers. If the unthinkable happens, you'll get one chance at doing something about it.
Look for a LOCAL guy that services them. Buy them from him. Build a relationship. Have them serviced when they're due.
wvrailroader
West Virginia
Ansul is a good one to buy. They are expensive, but much cheaper than something burning up. The suggestion of buying them from a local guy is a good one.
NUTTSGT
Northern Central Ohio
I've heard some bad stuff about Kidde extinguishers but I do have one in the house and the other in the garage.
Whether they are being forced to do it or on their own, it's probably going to kill the company and their bottom line but you have to applaud them for making it right.
In all seriousness, it doesn't matter if the extinguisher works or not if you don't know how to use it properly, you just might matters worse.
purplezr2
Central MN
Doesnt appear to have effected there stock much
Well there roughly 45 million effected units, I bet half don't get turned in.
jayoldschool
Canada
Have to look in the kitchen, the garage, and in all the cars. They are all probably on the list...
jon72vega
Niles Michigan
OP,
Thanks for the info!
My kitchen extinguisher is on the recall list.
Filled out the online form, and a new one is supposed to arrive in 15 to 20 business days.
L5wolvesf
Northern AZ
I wonder if ones made by Kidde but not with their name on it are covered. I have 3 Kidde and 1 "Fire Control" brand.
I read here on GJ a post from a member who is/was a fire fighter and serviced extinguishers also. It was an interesting post and he indicated which brands were good and which were not so good. It was posted maybe 5-ish years ago, but I read it within the last year.
NUTTSGT
Less(by far) than one percent is more what I expect.
I guess I'll finally get to be a 1%'er.
I see mine on the list... FA340HD
EDIT: I have mine submitted for recall.
Thanks rlitman. :beer:
sns1938
Re: Free replacement fire extinguisher
Thank you, didn't know about that. Getting a free replacement for my 1989 fire extinguisher that came free with our last house :)
Falcon67
Merkel, TX
Got 5 here, will start on forms tomortow
gilbo
Thanks for the link, I have 2 on the list that is recalled.
rharman
SoCal
I replaced some a couple of years ago. Kept the old ones thinking I'd possibly make some kind of fountain out of them. If they're on the list, now I can have additional locations. Better use than a fountain...
rburke65
Canfield, Ohio
I've got 2 in the shop I'll have to go check. As said.....something else that I've got to do.
NUTTSGT
Check for the model numbers, if they are new enough get the date code and serial number before you start the forms. Once you have that information, the forms only take minutes.
RVDan
North America
**** I think I've thrown away about twenty of them over the years because they lost pressure. I never imagined they were going to be required to warranty them forever. I presumed they all lost pressure after the one year warranty period on purpose so you had to keep buying them.
lbhsbz
Long Beach CA
This is fortunate...I have 5, 3 of which are in need of a recharge.
I had a bit of problem with the website freezing up using Firefox, but Chrome got the job done.
PCustoms
VT
I'll have to check mine, I believe they are all Amerex and Ansul.
Realistically is a kidder from more then 10 years ago still servicible? You are supposed to flip and shake them every year to keep the powder from clumping, and in are commercial environment they have to be services every 10? Years IIRC. I'm a resuming most of these are homeowner owned and pretty much "out of sight, out of mind" suprised kidDE is liable that far back.
Last one I shot off (doing a gage clean out for a widow) spittered and spat a few chunks and locked up. Threw it out and brought her a new one.
LS6 Tommy
Northern NJ
I just sent the link to the recall website to all the Supervisors, my Head Custodians and Maintenance Staff...
Tommy
pendragon1998
NE Georgia
Here's the link to participate in the recall. They needed my name, address, phone, and email, plus the model number, date code, and serial numbers on the extinguishers. Pretty pain free. Replacements are being shipped to arrive in 15-20 business days, it said.
EdJack
I'm going to have to check mine. I am almost certain I have two of these hanging in my garage, and a third under the sink in my kitchen. And those suckers are OLD. But have the plastic handle thingy. I almost threw them all away last time I cleaned my garage.
I'm in for three free ones...
Falcon67
Merkel, TX
I snapped pics with the phone, intend to compile a little spread sheet and work from there. I too need to share this around with the car clubs and at work.
38 Dodge Coupe
Delaware Ohio
Thanks rlitman for the heads up. I found out I have two on the list. NUTTSGT is right, get the model # and date code before you start. I needed a magnifying glass to read the info! The online form on the kidde web site is pretty easy to fill out once you have all the information at hand.
lbhsbz
Long Beach CA
I found 3 so far, all 1A10BC's Kidde brand 2 red, 1 white.
their ID guide is ****, the model is listed differently under the UL listing, and my white one has a date code of 1/9/04 according to their documentation but it is less than 2007 so shouldn't even exist.
got one in the camper to check, and 2 at the cabin and several in the scrap to go through yet...
Only the model number and serial number are required fields, the date code is not (when filling out the form on their website)
