Workbench build using H.F. 44 inch tool boxes
Lucky13driver
Corpus Christi Texas
I was inspired by SteveO and beepinjeep on a workbench using 3 H.F. 44 inch tool boxes and square tubing.:beer:
ScottsGT
Lake Wateree, SC
Sweet! Hopefully getting the new 22” to put under my top and sides and use the old 18” as a roll around bench with some serious mods with external casters I can raise or drop to move the bench.
Thinking about going nuts and install hydraulics from a convertible top mechanism to raise and lower.
machsnell
Northern Virginia
Anyone know the outside dimensions of the new 44 x 22 deep boxes?
Want to do the Steveo thing and dont want to go measure
Sent from my SM-G960U using Tapatalk
jscoggin
Midlothian,TX
I love the thread, on BF I bought three of the best 44" US General boxes, the blue ones. I did so with the intention of doing the same thing, making them the base of my workbench. I'm looking forward to seeing how everyone elses are coming together, even those that have the inferior colors. Mine aren't here yet but hopefully will be any day.
gmtech
nc
Can anyone link to the steveO thread? I'd love to see a build thread.
Sent from my SAMSUNG-SM-G890A using Tapatalk
taumac
Brooksville, Fl
Luckydriver13. Good luck on your build. I liked the original Steevo project. I needed mobile so I made mine 3 individual benchs and when put next to each other looks like one bench.
Augus7us
Central Ohio
Tagging along. This is the first thing I plan on doing when I have my shop finished up, probably a few months from now.
I'm going with Gladiator chests since I got a killer deal on them and a bunch of cabinets. I plan on something very similar to what the OP is doing. I'll remove the center chest to have some leg room and I'll have two upright cabinets bookending the bench. So very similar.
Keep us posted.
-Clint
L
Lucky13driver
Got off duty this morning and picked up the steel. I'll be cutting it to length after a little sleep, had a rough shift.
NUTTSGT
Northern Central Ohio
Steevo has inspired a metric **** ton of benches. I'll be looking forward to see how yours turns out. Take plenty of pictures.
bullnerd
Jersey
Yeah, and some pics of the big yellow thing at the far end of that pic!....please.
L
Lucky13driver
So this is an example of what I was shooting for. The ends will be able to to accept some of the benchtop tools i have like a receiver hitch on a pickup truck.
NUTTSGT
:thumbup:Nutts thanks I've always wanted a great shop. And this will be the coup de gras...... I noticed the helmet in your profile pic are you on the job?
Yessir, going on 19 years. That was my first helmet and my current helmet is red as I got promoted to Lieutenant back in May.
L
Lucky13driver
So today I did a little surface prep and beveled the edges. A tip I learned from an oilfield welder is to spray a little Pam cooking spray on the freshly ground metal to prevent rust...it also makes a great anti splatter coating, and if you get the butter flavor it smells like movie popcorn when it gets hot.
L
Lucky13driver
Here's an update. 'The 90 degree clamp has proven to be a huge help holding the parts all square. Also you will notice the use of a ratchet strap to help pull the parts togather it worked surprisingly well. I had a porosity problem on one of the welds due to running out of argon. I'll be on the business end of a grinder tomorrow.:beer:
jrb2
Lincoln, Ks.
Here is the one I built. It works great except that I did it just before HF changed to the 22 inch cabinets. Mine are closer to 18 inches deep.
NUTTSGT
NUTTSGT congrats on 19 years! I'm about 6 months behind you, I'm an engineer. And believe it or not my name is Eric also ��.
Engineer, must be a large dept, Corpus Christi FD ?
I'll have 19 in March but I bought 2.5 years of military service credit so I'm over 21 in the pension system.
We're a small dept, so we do it all, no engineers, truckies or EMS guys, we rotate to do it all. :thumbup:
Are you using pure argon or 75/25 ? (CR 25)
L
Lucky13driver
Here is the update pics. I decided to ad some gussets to the corner joints and under the tool mounts. That had no extra cost due to extra material I had. However, I bought some really big nuts and bolts for leveling feet and they were surprisingly expensive. If I were to do it over I'd consider scaffolding screw jacks instead.
