16" or 24" centers?
mltdwn12
Phoenix now, Berkeley Springs WV in June '18
I have a pole barn that I'm putting studs in now for insulation and inner walls. The current main 6x6 poles are on an 8' center. The small side of the barn has ~9' ceilings and I installed studs on a 2' center. The more I read I wonder about 16"centers. I still have the larger side of the barn to stud. It has 16' ceilings. Since these studs are only providing a framework for insulation and OSB is it worth it to spend the additional money on material to do the next section on 16" centers?
Thanks for any help, this is my first barn/shop project. I haven't had much luck getting anyone to come out and quote the work, so I decided to try and do it myself!
Marctrees
TX/LA border - Toledo Bend
24 more than adequate..
16 is not only the minimal expense of a few more studs...
But mostly the fact that your batts... per man labor installed rollout..
would cover 50% less per batt.
More time, absolutely no benefit.
Marc
Blazinzuk
Afton Wy
I did it on 16" centers. But I have put up alot of random shelves and I just liked having a few more studs to drill into if needed.
It cost I think about a 100 bucks more.
But around here I could get the narrower insulation cheaper than the wider ( my local Ace hardware beat everyone's price) so I did 16" centers for just about 20 bucks more than 24
rayra
Escaped from Los Angeles
24" will work fine, even more so if you run your drywall / plywood / OSB horizontally. But check first and see how available 24" insulation is in your area. A price premium for it might make an extra 2x4 for every 4' of wall a worthwhile expense.
K'ledgeBldr
Johns Creek, GA
This would be my determining factor-
Assuming you're using f/glass insulation, how do you plan to separate the insulation from the notorious sweating steel cladding?
firecracker
Lancs UK
As an x carpenter I did a couple of jobs at 24" that were OK, but I always wished I'd done them at my usual 16" centres. No particular reason, just peace of mind I suppose :beer:
NUTTSGT
Northern Central Ohio
I was told to use 1/2" to 1" foam board directly on the steel walls and then insulation. Thoughts?
I'd put the foam board in before building the stud walls. Looking on CL, you may find some places selling 1½" foam reasonable cheap.
Back to your original question, the 24" should be fine but I think I would prefer to have them on 16" centers to hang stuff on.
Falcon67
Merkel, TX
Either works - however, check on availability of insulation rolls, etc that fit the 24" OC. 16" is standard construction so that will be what is mostly in stock. Sometimes 24" is a bit hard to find.
rwa2004
Western PA
16" my vote.
The savings of extra studs with 24" is virtually nothing.
The labor saved with 24" is virtually nothing.
The improved insulation with 24" is virtually nothing.
With 24", you will notice much "softer" walls where the drywall/osb flexes far more between the studs. That extra stud/sheet makes a big difference for how rigid the sheet is held.
johnnyradiant
Vancouver, BC
16" my vote.
Sorta like the developers in my area. They all have to report to the municipalities about the impacts their projects will have. They all present their traffic congestion reports as virtually nothing and after a few years of so many virtually nothings I live in a heavily congested region that not too long ago was clear sailing most of the time.
Falcon67
Merkel, TX
16" my vote.
Agree with 1,2,3. On 4 - respectfully disagree. Have done two buildings with 24" OC studs and have no such issues. The only flex I've seen in my 7/16" OSB walls is when I punched a hole in a sheet with a golf cart. :willy_nil
TractorJeff
Elkhorn, WI
What is a stronger build?
The building is a Pole Barn which is already self supported.
All the high efficiency documentation states 24" is superior due to less heat/cold transmission through the wood.
Everyone knows staggered stud built walls are the best due to no one piece of wood touching the inside and outside!
Just Saying!
K'ledgeBldr
Johns Creek, GA
Are you putting the foam board on the backside of the framed wall before standing the wall? If not, you're not getting the full effect of the f/glass because it's being compressed in that less than 3.5" cavity.
mltdwn12
I was going to put foam board between the horizontals, directly on the metal siding. Then there's about 5" of space for insulation between where the inner wall will attach and those horizontals. Or should I just slip the foam behind the 2x4's (there's enough room) and nail it to the horizontals?
rustyjames
central nj
Have you considered using Roxul? That stuff is the ticket.
K'ledgeBldr
Johns Creek, GA
This sounds like the way to go- fairly easy, straightforward, and still leaves "breathing room" against the metal sheathing to help with condensation evaporation. Just be sure to tape the seams to seal air movement- considering it would appear that the walls are already standing.
lakeroadster
Central Colorado
16' long 2x4's and 24" spacing :confused:
You ever planning to hang anything on the walls, like wall cabinets, for storage? Or tire storage racks, or ??
If the answer is yes... use 2x6's on 16" centers on that tall wall. Then the wall will be strong enough for whatever you want to hang on it in the future, within reason.
Marctrees
Seems 2x4 would be fine if tied to a few midway wall girts.
Like 1/3rd and 2/3rd up the wall.
Even if 2x6, I would sure tie it at least to one near center girt.
I'm assuming the studs are directly against the girts..
I would CAREFULLY "Toenail" w 2" decking screws, being careful not to dimple siding panel.
So, very simple to tie in, don't scrimp on tie frequency.
Marc
DHCrocks
Hawaii
I just saw this old house this weekend and they were talking about doing a net zero house and to improve the efficiency they used 24" oc studs instead of 16" oc. The larger spacing meant the insulation bays were larger and that less studs could be used. Wood is apparently a poor insulator and that by minimizing the amount of studs the efficiency of the building would be improved.
since you are doing this from an insulation standpoint only go with the 24".
Blazinzuk
Afton Wy
Speaking of that. I tied into one girl and it made a huge difference in the rigidity. I think in a high wind area I'd tie in to all of them. Put a peice of 1/2 foam to not be as isolated as possible.
View media item 83926
lakeroadster
Central Colorado
Speaking of that. I tied into one gir(t) and it made a huge difference in the rigidity. I think in a high wind area I'd tie in to all of them. Put a peice of 1/2 foam to not be as isolated as possible.
It's a floating slab... it's named that because the slab moves independent of the wall.
In your case you have the wall attached to the slab, and attached to the building structure.
On a structure with a floating slab it's good to not rigidly fasten anything to the slab and to the building structure. If the slab raises due to frost heave, or settles due to sub-grade compaction issues it can damage the building structure.
That means, ideally, all walls should be floating walls. For perimeter interior walls that means attach them to the structure, but leave a gap at the floor. For divider walls that means attach them to the floors, but not to the exterior walls or trusses.
That's what I did on my barn. It's not really that complicated, just takes some planning.
For perimeter walls see post #142 here: https://talk.classicparts.com/threads/lakeroadsters-high-country-barn.22110/page-8
For divider walls see post #135 here: https://talk.classicparts.com/threads/lakeroadsters-high-country-barn.22110/page-7
Hope that helps. Good luck on your project.
Sparkynutz
Wisconsin
I read through the posts quickly twice looking for details on the grey cabinets. maybe I missed it. What make are they or did you build them?
Sent from my SM-G960U using Tapatalk
lakeroadster
Central Colorado
I bought the cabinets from Lowes back in 2005
They are made by Do+Able Products Inc. Chino CA
Base Cabinet P/N 12333, Wall Cabinet P/N 12332
