2 pole breakers
Roostzilla
I'm trying to add 220 for a neighbor who just got an electric Mustang (pretty cool car!) It's a mobile home supply pedestal with 4 bus tabs from I guess 2 phases, there's a 2 pole 50 in the middle, so when I move it over to add a 2 pole 30 for the car I lose 220. My question is would it be better to add another bus bar, if I can, and ill need to call an electrician, or get a quad 2pole 30 2 pole 50? Added twist...can't have rejection clips! I've been trying to find one with zero luck. Thanks.
jeepxj
another bus bar? man this is a bad idea to be messing with.
also i believe you need a GFCI for outdoor ev outlets like you're doing.
Its not 2 phases. Its single phase and you cant add a bus bar.
If its a 2 space 4-circuit panel you would need a quad 30-50 breaker to do what you want.
R
Roostzilla
Thanks guys for being so helpful, I thought this might be the place to go for answers. I made it clear that I don't know terminology and that if necessary I'd call an electrician, but I'm perfectly capable on changing a breaker! Geez, tough crowd. I've worked in remodeling for years, and moved to a mobile home park working under an electrical engineer. He died and now it's me....so if someone has something to say that is productive then I would appreciate it. Thanks to the guy who at least tried to help, but , again, I thought it was pretty clear that I an looking for a quad 2 pole 30 2 pole 50 with NO rejection clips. I'll send a picture and maybe someone can tell me the proper thing to ask. Thanks.
mark-NJ
new jersey
I thought I was productive in my previous post, but now that you've provided this info, I'm CERTAIN that I provided productive info. Here it is again: The liability is enormous...why bring that on yourself?
R
Roostzilla
As you can see, there's room for more in there, so I thought that might be an option....for an electrician!
The quad is probably not gonna work in that panel as my guess is its a 4 space 4 circuit max panel.
What brand of panel is that? Can you take a picture of the overall outside of the panel?
It would’ve been good to put these pics in the OP
What’s with the PVC pipe inside the panel?
R
Roostzilla
Mark, not sure if you saw the picture as your responded as I was sending it, but I'm asking 2 questions....can you answer either of them? Can something be added, or where can I get that breaker?
R
Roostzilla
The quad is not gonna work in that panel.
Well now we're gettin somewhere, thanks. My fault for not sending pictures first, I just found this site and got all excited. I'll go take some and post them.
Skooterj
Indiana
Maybe I'm missing something, why wouldn't a Quad work if you kept it in the middle?
Skooterj
Indiana
Whats the max # of circuits that panel can have as listed on the panel label? Im guessing its 4.
I can't make out any of the writing in the panel. But you are probably right. Personally, I would want to replace the panel anyway, something with at least 8 slots. But it may be fine for a mobile home, and if allowed by the panel, the 30/50 quad would solve the EV charger issue.
R
Roostzilla
Wrong picture is what that is, again, sorry. Just figuring this site, here is what I have
R
Roostzilla
The 2 breakers are a 2 pole 30, home depot. And the 30 50 the guy got from lowes. The 30 50 has the rejection clips
R
Roostzilla
ok so it says 6 max handles since its a main. so i was wrong about 4 circuits max. you will need to find a non-ctl breaker in siemens QP or QT, cutler hammer QP, BO, BR or GE TQ, THQ. or THQL
Norcal
If you look very closely only one 2 pole breaker in the center will provide 240V with provisions for a single pole on each side of the 2 pole.
R
Roostzilla
Yeah, I got the 2 pole 30 and moved the 50 over, no 220, realized my mistake and just trying to get this guys car charging. Here's a better picture of the panel, got the name in there this time.
Norcal
220 volts is a line to neutral voltage & not used in North America. Milbank got in the mobile home pedestal business after buying Unicorn some years back.
R
Roostzilla
This is a little better. So Norcal, is there any way to get what I need? Gotta tell you, I'm in SoCal and been to supply warehouses and nothing.
Norcal
What Wyliesdiesels suggested, a quad breaker is about the simplest way to do it.
