Sam'sAutoParts
Sam, I don't think I've ever seen a metal auger case...
Neither had I, it was closed on the sellers table, so it was a surprise when I opened it.
Paid $1 for this lot Saturday:
Snap-On:
OEXM13 (1987)
OEXL 24 (PAT. 3273430)
Wright:
3403 3" extension 3/8" dr.
3053 13mm 3/8" dr. 6 pt.
Got a call from a guy who was given my card. I picked up all this for $95. I paid 90 for the 1938 Take Away sander. All I need now is a manual....
All cleaned up...
Toilet bowl cleaner.Lug, what did you use to clean those climbers?
Jack-fuggin'-pot, UNAIU!And the big blue socket box in the background... That's all OTC (Owatonna)
over the OTC setLugz, The sockets are bright chrome plated all the way down. The breaker bar isn't the same that we've seen and is also chrome plated. I'm thinking it's an immediate post war set with some wartime pieces. The ratchet is the push through type that only ratchets in one direction. As you noticed, the ratchet and the extensions are plain steel.Jack-fuggin'-pot, UNAIU!
The handles and extensions look to be plain steel finish. As for the sox, from here it looks as if the bases are rough finished and the walls are either plated or polished. Can you tell which? (If plated, I would not hesitate to put that set in a GMTK and call it either transitional early or late war, but I am curious.)
Thanks 3bay! I was very happy to find it.Usernameover the OTC set
That would be a pre-war vestige as seen in the specs in pre-war and early war manuals, before they updated it to reversible. Which means the different breaker bar could be early, too. The box looks post-war, but you could have a mixed vintage set there as you suspect. Either way, nice set.The ratchet is the push through type that only ratchets in one direction.
It's been a while since I checked in on this thread. You guys are killing it!
I had a decent bit of luck at the flea on Sunday.
A couple of male/male 1/2" drive extensions
Craftsman (U) extension, BE speeder ($1 ea)
Wizard 1/4" drive breaker ($1)
SK and SnapOn sockets ($0.50 ea.)
Big Vlchek DBE 1-1/8" x 1-1/16" ($0.50)
Long handle PROTO 1/2" drive ratchet ($5)
Big PROTO L.A. DOE 1-1/8"x1" ($1)
And the big blue socket box in the background... That's all OTC (Owatonna) ($15)
Picked this up today: Getstner box no door, with machinist tools, 5" starret vise, 4" reed swivel jaw, exact clamps, rr track anvil, battery charger.coolest thing, a Tesa inside micrometer.
Nice haul, Joe! Prior owner had good taste in tools. What brand are the outside mic's?
Resisting the urge to follow this up with a classic 1970's style Polish joke book joke!Starret and Browne and Sharp...one Polish one as well.
Outlaw,
Thanks for the pics. I'm thinking the gaffs on the climbers in the figure in the manual I posted, the museum pics in the links I posted, and my recently found examples all look the same. I don't know if they'd be identified as tree gaffs or pole gaffs, but they all look the same. None of those (manual, museum, mine) are as widely spaced from the climber shank as the tree gaffs in your pic 1. But they're considerably longer than the pole gaffs in your pic 2.
Thanks, 2oolhound. This explanation makes sense and is what I was getting at with the dual-purpose (pole/tree) environment Signal Corps linemen and/or Combat Engineers would work in. (Or it could just be wishful thinking to self-rationalize these into vintage military vs vintage telco/forestry service...I think Lug's spurs are pole spurs but long enough to work in bark or sap wood if necessary.
)Resisting the urge to follow this up with a classic 1970's style Polish joke book joke!![]()
Thanks, 2oolhound. This explanation makes sense and is what I was getting at with the dual-purpose (pole/tree) environment Signal Corps linemen and/or Combat Engineers would work in. (Or it could just be wishful thinking to self-rationalize these into vintage military vs vintage telco/forestry service...)
Picked this up free at the dump, it was stuck, but after a few whacks, now its not
Tag missing anyone recognize?
Once was sprayed gold over gray paint.
From a C/L ad today for $60.00. The grinder is model number 600E, 1/3 hp. I plan to use the base for my 3/4 hp Baldor buffer.
Blue Frog
Thanks, this looks like a cousin at the very least
http://vintagemachinery.org/photoindex/detail.aspx?id=9312
the bearing spin well, but are pretty noisy, I'll tear it down to see.
It vibrates a good bit, but the knotty wheel is in terrible shape.
Many of these grinders post ww2 were made by a few Companies. Wissota made for Milwaukee and others. Both my 10" Baldors are labeled as Delta Rockwell....know the shape and you will learn to identify them from 20 feet.
