2018 Home Depot Clearance Thread
maksim
Re: 2018 Home Depot Clearance Thead
Got several bottles of the Zep drain cleaner for 1.83 and 2 of the dewalt multi tools for $6. Some bundy wire connectors are at .03 price now. Most stores have them in the electrical section, not the clearance section. The mother load today was the Mass Air Flow Sensor cleaner, that was clearanced out months ago. I got 4 cans then for $2 but today I found a case of cans sitting where the Lucas gallon heavy duty oil stabilizer jugs normally are. Someone must have found a new case up high and put them on the shelf. I price checked one and it was .80! I swooped up all 12!
oh, and I also got the multi cut tool for a penny today.
Thanks, will have to take a look!
maksim
Ridgid X4 18v recip saw 0000-323-251 marked down from $120 to $60
Saw that, not in all stores. My local one does have 3 of them marked down to $84 or so, but rings up $60. Let me know if you need a lead on them in central NJ.
txusa03
Have not been in HD for a while. Is this an error? I thought regular price was $499.
Kenta
Ecobee3 WiFi thermostats down to 63.0
At my local store the PCA said 1 in stock @ $63. Rummaged around the clearance sections, no luck. Went to the checkout and then they looked in the "cage" where they keep the rest of the expensive thermostats, not there either! Anyone find one and, was it in the cage or out in the clearance sections?
Mctiger1985
Louisiana
Did you look up high in the aisle with the regular thermostats?
fourjeepin
Atlanta, GA
I only look for something with inv of 1 if it is big and expensive..
drwheels
okla. city ok
Bare Milwaukee sawsall went to $125. 60 inch lawnmower blades at $15.03.Oregon bars and chains at 06 pricing.
C
chadman117
Echo weed whackers and trimmers have been 06 for months, hopefully they'll get put out of their misery soon and go 03.
2manytools
Mt Pleasant, MI
$499 is way too much. $299 i think is MSRP, which doesn't make sense either, as the large is $129, medium is $80, and the small car is $70 retail I think.
$200 was the BF (or whenever) price they had when it was briefly in stores. Never last long enough to go to a regular price, if it was very programmed in.
Mctiger1985
Louisiana
$499 is the kit that includes the drills I believe
BeardBro
I thought that seemed odd. There are a few items I want that have been stuck there for months. Have you seen .06 items drop after being held at that level for an extended time?
schmelpboy
Those oversuds and cause my dishwasher to leak.
Same here. 70 cents cost me a 1,000 deductible and 2 weeks of aggravation while I couldn't use my kitchen and basement.
Sent from my SM-G955U using Tapatalk
12three
X4? Didn’t the X5 come out 2 years ago?
x4 is old. theres multiple x5s i believe, and one of those even has a brushed motor.
$60 is pretty steep for it. but ridgid is the only cordless option with an orbital feature tho...
i might grab one at .03 but im sure it will be gone before then
06GMC5.3L
Mine would just leak a little bit out the front of the tub from behind the door then it would pool on the floor. It wouldn't happen all the time either. Took it all apart a few times and couldn't figure it out. Finally tried a powder only pod and haven't had any problems since.
Hexen
Texas
Wow, same thing happened to 2 people who happened to be following this thread, what are the odds? Sounds like Cascade Platinum has some issues!
My family has been using 'Finish' tabs for years with no issues, FWIW.
schmelpboy
Probably pretty good considering it's a clearance item for a reason.
bmoore1
Let there be light1527031317558.jpeg1527031331327.jpeg1527031344045.jpeg1527031356120.jpeg1527031368638.jpeg1527031381920.jpeg
Sent from my Pixel XL using Tapatalk
bmoore1
Let there be light1527031584286.jpeg1527031597789.jpeg1527031608737.jpeg1527031621245.jpeg1527031633422.jpeg1527031646870.jpeg
bmoore1
Let there be light #31527031689674.jpeg1527031698406.jpeg1527031710599.jpeg1527031722148.jpeg1527031738260.jpeg1527031751655.jpeg
bmoore1
Let there be light #41527031788514.jpeg1527031802143.jpeg1527031812443.jpeg1527031826220.jpeg1527031837377.jpeg1527031849289.jpeg
bmoore1
Let there be light #51527031909370.jpeg1527031918805.jpeg1527031931924.jpeg1527031942302.jpeg1527031952961.jpeg1527031966340.jpeg
bmoore1
JR4815D2
___
Hexen
Texas
If anyone is looking for a basic obdii reader.
That appears to be a full featured tool, from the description:
The AL519 supports all 10 modes of OBD-II
Record and playback data
Graph live data
Yeah, that is a very nice-sounding tool. Excellent reviews on Amazon, where it costs 2.5x as much:
Autel AL519 AutoLink Enhanced OBD ll Scan Tool with Mode 6 Fault Code Reader EOBD
https://www.amazon.com/dp/B007XE5LTG/?tag=atomicindus08-20
csmitty
Same one can be had from HF with a 20% but probably still a little more. Can't say I've ever seen one of these in a HD.
06GMC5.3L
Do you have a link for this scanner on the HF site? I could not find it, all I could find were the Zurichs and a high end Autel tablet.
Thanks.
Yes, those are them. They are "equivalent".
06GMC5.3L
Hmm, I only found four and none of them had the same buttons as this one. Guess I will need to read the descriptions to find the equivalent one.
What type of vehicle are you mainly looking to use it for? GM, Ford, etc?
