neogenesis2004
- Joined
- Jan 21, 2014
- Messages
- 49
I've been lurking the forums here for a while, checking out all the nice garages/work spaces and gathering ideas. I do about 99% of my own mechanic work to include engine building and more. So it's very important to me to have a nice, organized space whenever possible to increase my comfort and efficiency. My garage is about 21x21x9.5. So its not huge by any stretch and not super tall. It's a good size space compared to anything I've had in the past, and with the right choices I think it will become an absolutely great space.
About the space:
Like I said above, its roughly 21x21x9.5 standard 2 car garage. The entry door to the house is at just about the center of the rear wall. The plan is to have the rear wall lined with wall cabinets all the way across. To the left of the stairs will be a tall floor cabinet against the left wall, and a workbench with tool box underneath between that and the stairs. On the right of the stairs it will be mostly open with just one of those standing plastic sinks, and a spot for my engine lift and shop press. The reason for the open space is to enable easier ability to pull an engine out the front of one of my cars. Thus, the lift will be in the right bay. I'm still deciding, but I'm also thinking the wall cabinets on the rear wall will wrap around and continue on the wall of the left bay (better to have too much storage right?). So that's it for the basics of the layout I'm looking to do.
Fun parts:
Lift:
I've spent a lot of time thinking about this decision, going back and forth around a handful of them. I've jumped between the MaxJax, a regular midrise, and various other midrise or full rise scissor lifts. The biggest variables being width/footprint, underbody access, price, ease of install. I have a crack running right down the center of my garage slab running left to right, so that is a big factor of the overall potential cost and ease on install considerations that has gone in to my decision.
The MaxJax is great, but it would require concrete work because of the location of the crack in my floor. So that would be additional cost and time. The biggest issue though is just how wide the two post setup would be. I have 2 E46 M3's in the garage, so they are each fairly wide. After measuring, the MaxJax would make using the other bay pretty tight on a daily basis so I've ruled it out.
The lift that I ultimately think I will be getting is the Atlas Kwik Bay 7000 mid rise scissor lift. It has a completely open center, price is reasonable compared to the other options I was considering, it doesn't require bolting to the floor so the crack isn't a concern, and the footprint is no wider than the car that will sit on top of it. Also, there is a Greg Smith Equipment warehouse in Delaware a few hours away. So I could pick up the lift in a truck and drive it home to save on shipping.
Cabinets:
I am leaning toward white Ikea cabinets with a yet to be determined door color. I'd prefer to to have solid wood cabinets, but I don't have the setup or the time to make my own cabinets from quality plywood and I don't want to get bent over from some cabinet supplier. Definitely open to options here.
Workbench:
I just picked up a 6ft Gladiator adjustable bench from Sears Outlet for $350 out the door, $150 off the new price. I feel like I got a solid deal for basically new. It really is a nice piece, really hefty and solid. Pic attached.
Toolbox:
To go along with my workbench find, during the same search I found out that my local Sears was getting rid of a display model Viper Tool Storage 41" 9 drawer toolbox. I got it for just about $400 out the door, $270 off new price. It's basically brand new with just some minor scuffing on the top. It will be residing under the workbench though so that doesn't matter at all to me. Pic attached. If I outgrow it I can look in to getting one or two side cabinets for it.
Compressor:
I haven't put a ton of research in to this yet. I'd like to get a large 60-80Gal upright compressor and most likely install it into the utility room in the basement. From there, copper pipe it up in to the garage and have a drop line coil mounted in the center of the ceiling, and a hookup on the left and right walls and one by the workbench on the rear wall.
Flooring:
I love the clean look of epoxy floors, but I'm not really interested in not being able to use my space for even more than a day. I have some really really heavy stuff in there that I just can't move anywhere else, multiple spare M3 motors and other stuff. Another thing that steers me away from it is that my knees, ankles, and heels just do not agree with standing on concrete for extended periods, which I'm prone to do in the garage. All that said, I'm leaning toward some sort of garage floor tiles. Those will absorb some of the shock from standing, and I can install them in a full day and be able to move my large heavy items around with my engine lift during the install. I haven't settled on any particular brand or tile style yet.
Climate Control:
I plan on most likely getting a mini split heat pump installed so that I can independently heat/cool the garage without having to worry about code regarding sharing climate control with the rest of the house.
Where to go from here:
Right now the garage is pretty plain and barren. It's also sort of a mess at the moment with parts all over the place from my project car and maintenance on the other M3. I need to move as much as possible into temp storage in the basement. High level list of things to do:
1) Clean out garage and move stuff to the basement.
2) Get an electrician to come in and install additional 120V and 240V outlets
3) Insulate the garage door, above the open ceiling, and in the one exterior wall if it is not already.
4) Get someone to come in and finish the drywall.
5) Paint. I hate painting because I'm extremely **** about details, so I am never satisfied....
6) Hang cabinets.
7) Install garage tiles on floor.
8) Get a plumber to install garage sink.
9) Begin bringing tools, etc... back up into the garage and organize into toolbox and cabinets.
10) Purchase and install lift.
11) ...
12) Profit?
Pardon the initial crappy phone pics. I'll start using my digicam as I make progress.
About the space:
Fun parts:
Lift:
Cabinets:
Workbench:
Toolbox:
Compressor:
Flooring:
Climate Control:
6) Hang cabinets.
11) ...
12) Profit?
