230 Volt Compressor Install / compressor controlled by 115 volt lighting circuit.
N
nkachur
Manitoba Canada
You might also consider adding an electric solenoid valve to the air outlet from the tank. That way you would have a full tank whenever you turned on the lights. Now with the power off it could take 10 to 15 minutes before you have air to work once you turn the lights on. Also a lot of unneeded noise every time you turn the lights on. Just wire it in parallel with the contractor coil.
That is an idea. Will have to investigate.
Sent from my SM-G903W using Tapatalk
N
nkachur
Manitoba Canada
Received the hour meter that I ordered at the beginning of Sept. Will get it synced and installed in the next couple days. 09645ec17a28513521e68d0124777dd2.jpg
N
nkachur
Manitoba Canada
Final steps in place less the permit and approval.
1) tied the circuit breakers. Had to find #6 junction nuts on Amazon but works awesome.
2) installed the hour meter on the control panel. Miss cut the hole but was able to fabricate up some adaptor plates to sandwich the hole.
Everything works great. a284dcff26bb6187c159250e4e5ffe6d.jpg7deb9c3df5a88e5007d4f2512233042c.jpg8fafcfcd89ec69759a25b15fb480e2af.jpg09288146bc4b2016b1a6ce444c0a0653.jpgbcc78ceb5f2f400838b44b71f1315270.jpg
