That is an idea. Will have to investigate.You might also consider adding an electric solenoid valve to the air outlet from the tank. That way you would have a full tank whenever you turned on the lights. Now with the power off it could take 10 to 15 minutes before you have air to work once you turn the lights on. Also a lot of unneeded noise every time you turn the lights on. Just wire it in parallel with the contractor coil.
Sent from my SM-G903W using Tapatalk
