I bought the ebay Blackhawk. Standard New Britain inside. 45 teeth in the head with 9 on the pawl. I put it next to Penncraft and Mac versions, which both have 60 teeth in the head and 12 on the pawl.
The 3/8" drive rocks a bit because of the crappy clip that is used. It looks like a spiral clip that has been cut. The Penncraft uses an internal snap ring, and the Mac uses a spiral clip. In the 3rd pic the oem cut clip is on the left, and the right is the snap ring from the Penncraft.
I will never find a spiral clip at the local hardware stores, so I bought an internal snap ring. Problem is I cannot compress the snap ring to get it into the groove because the "ears" hit the large 3/8" drive. This is not a problem on the Penncraft because the drive is 1/4". Don't know how SCscoutguy was able to do it. In the last pic the snap ring is not seated in the groove because I cannot compress the ears. This must be why the Blackhawk does not have a standard issue snap ring - it will not fit because of the large drive. Why Stanley took a spiral clip and cut it, is a mystery.
So I took the spiral clip out of the Mac to put in the Blackhawk, and then I was going to put a snap ring in the Mac. But the spiral clip from the Mac is too thin and the Blackhawk is still going to rock.
I would like to find a thick spiral clip, but that is just something I can't find locally.
