30 x 40 Michigan Build Thread
skooter_built
Here's the number one storage item, my 2004 Jeep Rubicon rock crawler...
...in addition will be my 2500 RAM Cummings quad cab on a daily basis, and my son's 1998 Cherokee Father-Son project vehicle.
Nice looking TJ! Looks like your running 60's and a full traction or RE longarm.
Here is my TJ project that is waiting for its new residence so I can finish it, a 24'x36' pole barn. Where in Clarkston are you? I live in White lake and soon to be moving to Holly. Are you on GL4x4?
M
mzy4v1
Clarkston, MI
Skooter...
...yes I'm on GL4x4, same username as here. I'm running 60's, front longarms are Rusty's, rear is my own custom 4-link, and custom skid plate.
I am off Oakhill Road.
M
mzy4v1
Clarkston, MI
Sorry guys, no updates this week (just answering questions). I have been in Germany on business and won't get home until tomorrow afternoon.
The electrical inspector did come and sign-off on the electrical as is stands now.
Bruser
Nice well done building. I am currently planning a 40 X 60 with an attached apartment. Need to do more than a typical barn as the building needs true footings. Also on GL4X4, small world.
Have done the DI JJ on 4 occasions and always had a riot. Thanks for your time supporting that!
M
mzy4v1
Clarkston, MI
Managed to get a little time in the barn this weekend. Finished the final framing on the south wall...
...then got all the bays framed on the north side...
...also did a little shopping for insulation and drywall...
...and for the attic...
...btw, here what the attic currently looks like...
milner351
SE Michigan
Looking Excellent - I hope I can find someone to do the concrete work I need done in that price range - I'll be following along - you're not cutting any corners here for sure! I copped out on the interior finishing - I ran 2" foam board against the exterior purlins, then ran white interior barn siding (22ga) vertically over the foam using three inch barn siding screws to go through the steel and foam and into the exterior purlins. Certainly no where near as nice as what you have planned here!
XDC
Waterford, MI
Place is looking killer!
Not to far from me either. just right over here at the boarder of Waterford\Clarkston
keep it up !
M
mzy4v1
Clarkston, MI
Thanks for the kind words.
Not been too much going on, I did get the last on the framing done on Sunday. So I started on phase 2 of the wiring. I have the attic lights done now. Hoping to get some more time out there this weekend for more wiring. I'll try to get a couple of pic's this weekend.
c6matt
Greater Detroit (Novi)
Great build, anf thanks for the info.. I'm going to be putting my garage up in Commerce In july.. 30x48.. but I think I need to do stick built because of the grade on my property.. def gonna give your concrete guy a call..
bbaxj
Great looking barn!
Another Michigander here, only about 20 miles from you actually. I am hoping so start a 30' x 40' build in about a month or two and am currently just getting quotes. I was wondering if you would mind sharing the name of your company that did the concrete work. The quotes I am getting are quite a bit higher than what you paid so that seems like an excellent bid! And since I am doing the same size in the same area I am hoping I could maybe get a quote from them. Also, who did your exterior and framework? Oh and finally, I have a father son 99 Jeep Cherokee project going on too! Thanks in advance for any help you can give me.
Here's another option for you:
http://www.pasqualiconstruction.com/
Owned and operated by a longtime family friend of mine, I've always heard good stuff about their work. I'm hoping to have them put a cement pad outside my garage this spring.
M
mzy4v1
Clarkston, MI
Curious on the framing between the posts, it looks like a insulation nightmare. (Unless you do spray foam)
Yes the insulation is going to take a little more time, but I needed to get the studs in the right places to support steel liner panel on the bottom 4' and then drywall above.
M
mzy4v1
Clarkston, MI
Spent a little more time in the barn yesterday, finished up the wiring in the panel.
And added a little bling to the outside with lights on the front and at the side door...
Moving onto the wiring for the surround sound now.
M
mzy4v1
Clarkston, MI
Also added a little 'welcome' to the door that shows what's inside..
I decided to start on the air-line routing today. I have the Rapidair Maxline 3/4" pvc/aluminum tubing and fittings. Pic's to follow in a day or two.
curtis9
Northern Michigan
Looks great! Im from Michigan also and am wanting to build a 30x40 as well. How did you do your roof? Did you put any insulation board under the metal or anything like that? The local building place here sugested i put 4x8x7/16 sheets of green guard insulation board under my steel. I am in no way a builder and am trying to find out what is th ebest way to go. I plan on have the building insulated and heated with in floor heat.
ShiftedSolutions
Central Michigan
I am from michigan and just built a 32x40 with in-floor heat. I would recommend something like that under the steel. I did not install anything and wish I had. It quiets things down and cuts down on condensation. Just one of the things I put in my "If i had to do it all over again I would do that instead" folder...
curtis9
Northern Michigan
Ok thanks. Thats what i wanted to hear/know, its nice to be able to learn from other people who have already done the same thing i plan on doing.
M
mzy4v1
Clarkston, MI
I did not put anything under the roofing panels, but I am insulating the ceiling below. I did notice last weekend when the sun was out for a few hours that it was noticeably warmer in the attic. I think most of this is radiant heat, so I am considering putting up a foil radiant barrier. Maybe a really good way to go would be the insulation foam board with foil on one side.
curtis9
Northern Michigan
I plan on insulating the ceiling also, i am just worried about the building sweating after reading some people posts on the forum with a metal roof. Do you think I should even put the insulation board under the metal if i am going to insulated the ceiling? I think the insulation board was around $550 for the whole roof.
M
mzy4v1
Clarkston, MI
Mine was sweating really bad for the first month after the concrete was poured, since then it has been dry...but bear in mind I have only been heating it periodically with a torpedo heater. I think with good ventilation and the ceiling insulated you won't have any sweating problems.
You may still want to consider something if you are planning on storing a lot of stuff in the attic. I am going to see how it goes this year and then decide if I put up any radiant/thermal barrier to help reduce the heat in the attic.
soapii
SE Michigan
Thanks...how far along is your build?
Garage is all built and exterior is fully finished. I'm working on the interior right now. Specifically I'm in the middle of modifying a few trusses to gain some ceiling height for my lift.
--Joe
M
mzy4v1
Clarkston, MI
Made some great progress this week...
  • Completed air lines and tested for leaks
  • Finished gas lines and checked for leaks
  • Hung all the wall insulation
So now I am ready to start hanging drywall.
M
mzy4v1
Clarkston, MI
Had a great weekend working on the barn. Managed to get 80% of the drywall hung this weekend (and that was after installing a new washer and dryer).
The long wall closest to the house is complete...
The front wall above and on both sides of the main door is complete...
Still have to finish drywalling around the stairs...
The other long wall is 80% complete, one more sheet to hang. Then it's onto the stairs and finishing around the windows. It's difficult to see in the pictures but the bottom of the drywall is finished with the white plastic J-channel, this gives it a nice edge to **** against the steel panels that will be along the lower 4ft.
Darkboones
Grand Rapids, MI
Looks great! Cant' wait to see it with the steel on the bottom. What are you planning on doing about the electric boxes in the steel part of the wall? Did you hang them at the same thickness as you would for drywall?
M
mzy4v1
Clarkston, MI
I did hang the electrical boxes at the same depth as drywall, but I expect to need to move them when I get to hanging the steel. I will probably have to play with the location along the wall to make sure they aren't over the larger ribs in the panels. The steel for the lower may be later in the spring/summer...I want to get the ceiling finished first (also steel).
