Between 485 & 705 SQ/FT 3rd time's a charm with a 3 car workshop
L
loganb
Omaha, NE
Making slow progress in the Nova
We are hosting a large gathering next week(ugh) so it's gotta go back to storage shortly so I can get the garage cleaned up for overflow seating in case it's warm
Will have to find some homes for a bunch of little stuff on this years Epstein day event
And caught this and had to grab a pic and share the fuel company with a sense of humor
OutlawDrifter
KS
I got the dental pick and tweezers as well as too many other things!
Skipped the 250th pliers...didn't have room in the drawer and I spent an absurd amount of money on pliers last year :LOL:
And because we all need some **** talking...you better get your *** in gear on that Nova! Prime Fall driving season is coming up ;)
L
loganb
Omaha, NE
Definitely not wrong on needing to get moving! The list is getting smaller....it's back to driveable now which is a big plus....well once it's off the jackstands and fluids are topped off! I've been told it should go back to storage tomorrow....not sure I'm going to get that one done....will depend on how much help with kids I get
L
loganb
Omaha, NE
Ended up with about 18.5 lbs of pulled piggy in the freezer.
Nova is closer and should be driving again tomorrow night....now that means driven to storage as there won't be any time to work on it till after the weekend event but it's more then it's driven the past 2 weeks
L
loganb
Omaha, NE
Nova is back in storage...for a couple days
Power washer got broken out
Put the still new in box from a year or so ago(oops) surface cleaner on and gave the stall a wash
It does do a nice job of medium cleaning with minimal mess and over spray. It's a 15" cleaning head with a rating of 3.8 from on a pump at 3.5 gpm and it feels a bit underpowered but the slab is much cleaner so it was apparently powerful enough.
L
loganb
Omaha, NE
Props to all y'all who host events all the time....shits a lot of work lol. When you do it more often it gets easier...but glad this event is on a 7 yr rotation so won't be our turn for awhile after Sunday...maybe I take Monday off work.
Now to finish putting away tools and moving more stuff around in the garage to make more space
L
loganb
Omaha, NE
Too hot, too much left over food and beer....wait only 1 of those 3 things is actually bad lol. Gathering went well, everyone seems to have had a good time...garage having AC was a big help as it provided sufficient space everyone could stay inside if they wanted and get away from the heat index of 114 or so we had. All the 3d printed fidgets and toys were enjoyed and disappeared so that was great and the laser got fired up for some coasters
Now to figure out some better locations for some of the tables and chairs so they're out of my garage and then back to more regularly scheduled programming here.
Did wake up to an unexpected message on the thermostat about how it was calling for cool but temp was going up....uh oh with today's forecast being similar to yesterday and 100+ actual and heat index of 110+. Compressor fan was spinning normally so not capacitor(which is guaranteed to not fail as I have a spare!), filter was good so kicked it off and let it sit for 10 minutes then fired it back up and a couple minutes later had this temp reading in the duct above the A-coil
So....not sure what happened but it apparently needed a reboot. Seems to be cooling things off correctly again so hopefully this was just a fluke. AC is about 10 years old but a 4 ton unit so should have plenty of life left but when it goes it won't be cheap to replace.
L
loganb
Omaha, NE
Hope it was just from running constantly that cause a little hiccup in the system.
Appears to have been as hasn't had an issue since! Knock on wood...
Speaking of wood....
Neighbor asked if I could help on a little project. They lost a tree in a windstorm last year and they kept some cookies and wanted to combine one with a bomb tail/fin stabilizer they had to make a small end table.
The cookie has had a significant amount of epoxy poured on it and it's not flat...so that added some complexity
Initial mockup
The tail of the fin stabilizer has to be cut down a bit so it doesn't take as deep of a pocket into the bottom side of the table
Bottom side as I pondered how to knock the high spots off
Landed on the CNC to flatten it as was too tall once leveled out for the sander. Didn't do the entire bottom, but enough to get the fins to sit flat
And closer to mocked up ..need to make a template to get final diameter on the pocket in the base....it's going to end up in the range of 2-5/8"
gearhead1960
Years ago, had A/C tech want to clean my outside unit cooling coils for big $$$ as most people don't know that this can affect performance greatly. I now clean them every other year in hopes that the lower load on the unit will give me longer life for the A/C system...you might want to check your unit, if you haven't already done so....IMG_3476r.jpgIMG_3477r.jpg
L
loganb
Omaha, NE
Great reminder! I've got clean the coils on an annual calendar reminder and did do it this spring vs dismiss and say "will get it later"...I've got the fun "fuzzy coils vs the straight fins so they're especially fun to clean
This morning got out early with the kids and hit the Offutt AFB airshow flightline before it got hot and other conflicts came up...got to see the planes but had to leave before the airshow part
C-5 Super Galaxy out of Dover...last year they had a C-17 here
F-35 Demo team flies at 2:14 today...they brought 4 birds, two on static display and two for the airshow
Had a BUFF on hand
Bomb bay
Cool TBM torpedo bomber, apparently the only flying nationally historic designated structure. They were doing paid rides on this ....that would be pretty sweet
Looking up the tail to the rear facing gunner position
L
loganb
Omaha, NE
Been awhile since I've been to that show. They generally put on a good one. B2 gave us a flyover last time I went 7-8yrs ago.
Mother nature had her way this year and the air portion got canceled around 1:30 or so as a thunderstorm rolled thru. Tomorrow looks clearer and hotter.....not sure if I'll try and go to the show part solo or not. When we left the line at security to get to the show area had to be at least an hour long....not something I want to tackle with kids...
L
loganb
Omaha, NE
Local shop had a donuts and coffee event this morning so loaded the kids up
As you might guess they specialize in Corvette and Gen 1 Camaro...very nice shop
Some of the more unique things that dropped in...we were there early and left early.....kids lost interest when I said no to a third donut lol
'56 DeSoto Firedome Wagon
L
loganb
Omaha, NE
Kids just left for a playdate so lets see if we can get anything accomplished
Rear view mirror wasn't behaving last night on the ice cream run so trying to get it cleaned up, a new fastener hopefully gets it the tension it needs to stay put. Bit of brake clean and some new spray lithium hopefully lubes up the ball for easy adjustment for another 50 or so years
Been working on a bit of a display board for it when it goes out to a show....my graphic design skills aren't great so this has been very AI assisted. Claude has been working best and was able to quickly build out a "tool" to allow me to adjust all the text, sizing, fonts, columns sizes after I provided the scans of the window sticker and protect-o-plate. I need a new "hero image" of the car...it's cloudy today so not sure I'm going to be able to get it today but this is progress at least. Sized for 18 x 24" printing
Hopefully on the plate this afternoon is polishing/clean up time. There is a 50 Mile March fundraising event next weekend where they march from Lincoln to Omaha to raise money for veterans causes and I know several marching this year. They're trying to setup some cars to line the march in and I submitted the Nova to participate if they want it. Unsure whether they're going to use it as they've got limited spots and I suspect they're going to have a lot of interest from the local supercar scene which is surprisingly robust but either way gives me a goal to work towards and get more polishing/paint correction done.
