What baby monitor do you use? I might need to copy this with my spare TV.
Probably should have explained the setup better...thx for asking!
I hated the range limit of conventional baby monitors, so we are using a security camera setup run on a PC for the baby cameras. We already had all the hardware and software from outdoor cameras so it was easy to setup.
Cameras are ceiling mounted Power Over Ethernet(PoE) units...nothing special, Dahua brand units that 3 or 4 years ago were 70-ish a piece or so. Beauty of PoE is that you get power and data over the same CAT 5/6 ethernet cable that is cheap and easy to run. Advised to get solid copper cabling instead of copper clad aluminum(CCA) when doing PoE to limit potential interference...its maybe 10 or 15% more so not outrageous.
A POE injector or PoE switch is required to inject the power into those cables, but otherwise it's wired like any other piece of networking gear.
The computer side is running BlueIris for software, think it was about 50 bucks or so for the license when we bought it. Takes a bit of fiddling to get setup but once it's running it's been great, only issues we have are when a firewall setting changes unexpectedly, normally due to a windows update.
We mostly watch it over the app which works well, we can also watch on the computer it's running on which is in our office and is our "home" desktop. To display it in the TV I'm just mirroring a phone or tablet display up to the TV thru either a Roku or Firestick. In warmer weather there is a lot of driveway socialization in the neighborhood and with this we can watch the cameras as long as we have internet so the monitor range isn't an issue and we feel more comfortable being a couple houses up the block or out somewhere with a babysitter at the house
