Sure thing, I am on Instagram:
@44Bikes
Good to hear the above tips may help.
If I can make a recommendation on torch/s:
Personally I really like CK Worldwide:
http://www.ckworldwide.com
The offer both air and gas cooled torches in a variety of head angles and amperage ratings and their customer service is really, really good. I had to trouble shoot a problem and the CEO of the company called me back.. I own their
CK130:
Regardless of the torch size and thickness of material you're tackling, be sure to get a gas lens along with your alumina cup. I personally use a No. 10 alumina cup with matching gas lens for 99% of my welding in steel and have a No. 8 stub with matching gas lens for really tight/acute spots. Both offer good coverage but the No. 10 stays a bit cooler and offers more coverage. 1/16" 2% lanthanated tungsten and I have 3/32 of the same for thicker materials on hand. Most of my work is thin walled materials so 1/16 tungsten is what I use primarily. Gas lens provides good arc stability and less arc wandering on material during start up and lends to a more even distribution of gas.
Make sure you get a superflex hose (depending on manufacturer they call it differently). It's really light and when you weld for long periods, the torch assembly doesn't start to pull on you so you're fighting torch angle. I'll also loop it over my arm or lay a section in my lap to unweight the torch gas lines.
The best advice I can give anyone who is practicing TIG is this: CLEAN. CLEAN. CLEAN.
TIG welds need cleanliness. Both your weld materials, your set up and where you are physically welding. Mechanically remove any mill finish or dirt from inside and outside the material (if tubes). Ideally give the part a warm soap and water wash, dry with lint free cloth but post clean up, an acetone or denatured alcohol wipe down with a lint free cloth is good practice to remove any remaining dirt/oils. Once clean, do not touch the weld site with bare hands. Any oils from your hands can introduce contaminants.
Once ready to weld...
- Clip a new tip off your filler and punch the pedal to get your pre-flow running but do not strike an arc.
- Allow the argon to "wash" that weld site clean as one final finally step. Once argon has finished flowing, strike your arc and start your weld. When you finish, DO NOT remove the torch. Allow your post flow set up to run through it's pre-determined setting. This allows the weld to cool and is protected by the argon.
- Always clip a fresh tip off your filler metal. (I mention it twice because it's a step you never should skip.) You will introduce contaminants if you do not. I repeat this on both ends of my filler just to be sure I've done it. It's a routine!
- Colors you're looking for are in the silver, gold, blue and purple range. Dull grey or flat colors? You're either moving way too slow, using way too much heat, your argon flow needs to be adjusted at the torch, weld area is not clean or some combination of those.
- You're looking for smooth transitions and fillets, good bead spacing, colors in the above range, no undercutting, no lumps, gaps or beads that are unevenly spaced. If there's something that does not look right, it's ok to go back over. Long term you want to avoid this, but steel is incredibly forgiving. You want smooth transitions, no undercutting and good bead spacing as I said, so marching back 4-5 beads won't harm anything so long as your heat management is respectable and under control.
There's just a few small steps you can take to produce really good, strong welds. It's nice to test your welds, but for those who don't have that access, if you follow the above, all typically goes smoothly.
But take good notes too so if there is a problem, you can go back to those initial steps to understand what went wrong and how you can adjust your process to make thing run smoother. Problems are typically in prep and set up.
Purging: Any stainless alloys and titanium alloys must be purged. Oxygen is a contaminant and will create a weak weld. Other steel alloys depending on what it is you are doing do not necessarily need this. For my own steel work, I purge because there are critical dimensions that I must ream parts to so it is essential that certain areas inside the bike frame are oxidation free. It does make a noted difference when welding if you are purging. It's small improvements on weld integrity but initially, you want to work on all of the above rather than use more gas.
Like I mentioned earlier, cleanliness is really, really important. So get into good habits and practice now as it will make for better work practice which is intuitive later down the road.
Any questions you or anyone have, feel free to ask. No secrets here when it comes to TIG welding!
