Back to the wiring. This time running the big cables for the battery, starter, grounds, and other miscellaneous wires in the area. I wrapped the cables in the same braided covering. I used red heat shrink on the ends of the positive cables and black for the negative. Should make for easy identification. I mounted a power block to have a place for all of the positive (1x #10, 2x #8, 1x #4, and 2x 1/0) to meet. I also used a perfectly placed factory hole to ground the frame and bond all of my grounds. The frame will be used to conduct the grounds for the fuel pump, fuel sender, fan/fan relay, and front/rear lights. Here are pictures. I’m hoping I can get this thing started up in the next 6 months. Thanks for looking!
