'78 F350 Dually Project
R
RivennHewn
PNW
It looks like you can use the bracket as a drill guide to get the light installed.
The install kit comes with a drill bit bushing that you install in the mounting bracket. Need a 16” bit to get through to the dash.
kbs2244
IMHO the visor looks too modern.
I like the look of the old ones, but they didn't have the swoop.
Look for some old PICs and try and find one with the air exits at the join point.
I would sell it and keep looking.
R
RivennHewn
PNW
Sounds like you're talking about the Fulton visors. I believe they are for older-50's era trucks.
R
RivennHewn
PNW
This place looks interesting...........
MybE
R
RivennHewn
PNW
Is that a place that does media blasting?
Yep.
Picked up my hood today. Alternative Blasting in Marysville, Wa.
They did a great job. Unfortunately, there is a fair bit of body work to be done.
There are holes where the F O R D was removed from the front of the hood, a good sized ding in the front corner, and one right on top, as well as some rough grinding marks from previous bodywork/paint prep that was a tad aggressive.
Nothing that won't get taken care of, just a bit more work than I was anticipating.
From the under side, it all looked good.
X5sE
Spareparts
Lansing Ks.
Installed a lot of the Unity lights on that vintage Ford, we used the electricition bits, a lot longer, forgot the size, seems like 1/2". Be careful as wire for the cab lights go up thru the piller and easily nicked with the drill bit.
R
RivennHewn
PNW
Seems I'm going to need a longer shaft for the light. Total for the parts I need to make this work is about $150.
Might need to be back-burnered for a bit.
Seems I have a couple things coming up that might slow the progress on the truck. More on that later.
After a can of acetone and a pile of rags, I got the hood shot with primer this afternoon.
OM8b
Time to start some body work:
hJhV
sSlf
"..Just shot a coat of primer then he looked inside,
Well him and my uncle tore that engine down
I still remember that rumblin' sound......"
R
RivennHewn
PNW
FedEx brought me my Bed Up Indicator light kit early this morning. Gave me time to get it installed today!
8ob1
Crawled underneath the truck and found out my truck frame and bed frame aren't in the same plane. I had to add 1/2" to the bracket so the two parts lined up.
49cd
Bed up switch installed on the truck frame:
a7g5
Point of contact with the bed frame:
91OF
I had to adjust them so the stop hits the switch, and depresses it 3/16" of an inch.
All that so this little light will come on when my bed is in the up position.
r5bU
Went about as slick as projects go..........
R
RivennHewn
PNW
A couple post back I mentioned that there were a few things coming up that might slow the progress on the truck.
This weekend one of them came home.
We took a long weekend and drove from Seattle to Redding, Ca. and picked up our new pup.
9dmp
LwB8
bYU8
8 weeks old. Handled the 12 hour trip like a trooper.
He's a Newfoundland, and will most likely top out at about 155 Lbs.
He's already bigger than my wife's 12 Lbs. poodle, but I'm sure the poodle will remain the top dog for quite awhile yet.
Still looking for just the right name.........Open to suggestions
Strouty
Southern Maine
Luke, in a strange Dukes of hazard way. You have the right truck too. I suppose Skeeter would be better just because of the truck.
I do like trooper, but then the kids at doggy school might call him pooper.
Toothaker
Wichita, Kansas
Awesome dogs. I have a friend who had Newfies. It was nice to see the kiddie wading pool - they are water dogs, and he will need access to water so he can cool off and play.
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Going off topic and once had a friend called Doggy. He was a great panel beater spray painter. He had a Dog called Turner as he said it turned good tucker into SH#T. Turner used to sit on the fuel tank on a Triumph Motor bike in front of Doggy. Now that was interesting to see.
I still believe the name Trooper will stick as a choice for you.
R
RivennHewn
PNW
Thanks all,
GJ/ truck/ sleep time has been a little short around my house since the new addition.
Little guy takes constant supervision!
I’ve gotten a ton of suggestions from friends/ family/ coworkers.
Nothing seems quite right yet. Still trying to find a fitting name!
1Garageman
Columbus, Ohio
I had to look up the dog on American Kennel Club website. There is an awesome story in the history section about their dedication to humankind.
"In 1802, when Lewis and Clark began their historic 8,000-mile trek across the American continent, a Newfoundland named Seaman was part of the expedition. He was useful as a hunter and guard dog, once saving lives by running off a rogue buffalo that was charging the camp. Today, Seaman is depicted in 10 different Lewis and Clark monuments across the country".
HOTFR8
Thanks all,
Yes I can just imagine he is full on at present with your time.
Let us know when you find that name.
Toothaker
Wichita, Kansas
My buddy in Omaha had two Newfies. One winter he was camping in the snow with them. As he rummaged around in the campsite he heard a shotgun shell being chambered, and a voice of authority say, "step away from the bears, sir!"
Bear
Sent from my mobile using The Garage Journal mobile app
R
RivennHewn
PNW
What trim level is your F350? If it's a Ranger call him that.
Ranger was on our short list, for a few reasons.
It's what we went with. Too bad my trucks only a Custom. Oh well.
Spent this morning stressing and fretting about drilling a hole for the Unity spot light.
installing the mounting bracket was easy enough, but the main hole from the cowl to the inside had me a little anxious.
R9E5
There was little room for error.
tEdp
Reading, and actually following, the instructions helped :headscrat
qPny
93LR
bVsp
Good thing I had my helper to keep me calmed down.
rujC
I will add that Unity's customer service has been great.
R
RivennHewn
PNW
1/2 Cup/ Hotfr8,
Getting anything done with a 9 week old puppy around is a pain in the ****.
The light went really well, and looks good too.
I couldn't be happier with either!
R
RivennHewn
PNW
At least when he’s under foot I can keep my eye on him.
The spot was super easy to wire. It’s just above the fuse block.
Only a power wire, it’s ground thru the body/attachment.
R
RivennHewn
PNW
Looks good, glad you go the hole through without having any issues. I was a bit nervous for you.
It was 5 or 6 layers of metal, all at odd angles from the bit.
Each one wanted to deflect the bit.
Went at slow speed, with just enough pressure to keep the bit in contact with the metal.
zmotorsports
Northern Utah
Spot light turned out great. I remember when those were all the rage back in the 70's and 80's but you don't see too many of them these days.
R
RivennHewn
PNW
I’ve never had one, but always wanted one.
The new ones are a lot more powerful, and get fairly expensive.
This one fits the truck (and my budget) perfectly.
