What a crappy day. The car ran just fine all the way over to the shop, no issues. I parked it, went inside, told the guy the brakes were spongy and the power steering wasn't working. He said he would not test drive it, and alignment might not be great. He didn't like my custom alignment specs, the technician who was doing the job got it started and into the shop fine, and when he went to move forward onto the lift, he was grinding gears LOUDLY (blowing the teeth off the gears basically) and that's where the shifter loosened up. I got it back into 2nd ONCE to get it out of the shop and it loosened up the rest of the way at the corner. At that point, i had to call the wife, who was 40 miles away, to come get me and drive 25 miles home to get the tools i needed, and the jack, then drive back the 25 miles to fix the car, in under 5 minutes, while i found the tire was flat so i took it off and rolled it over to the tire shop, where i waited an hour to have them tell me the bead and stem were leaking and the rim was bent.
They charged me 30 dollars to reseal it and I put it back on and drove it home with wife following, telling me "is the car supposed to be that loud?" by phone a couple of times.
At this point, i have to fix the brakes and the steering before i can return for alignment.
I have turned the steering wheel back and forth off and running, per procedure, nothing is working. At this point i'm probably going to have to pull the hose and fill the pump manually. Wheeeee
