Spareparts
Glad you got it done, I'am getting to old to wrestle with tires, they go to the tire shop
Yes, i zip tied the abs sensor in place. it'll work. Next issue is when i tighten the axle bolt, the axle stops moving. I can't find anything wrong with the assembly, the axle is factory reman and looks good. Dims all match what came out. It's a puzzler. I'm thinking of letting it self clearance in operation. Alternative is pull the hub and put another in.What is the next action step you can do tonight on the car?
Are you able to move past the stuck bolt/stud, etc?
@86turbodsl and @Spareparts, I bought Vevor's copy of the Bead Breaker and used it to replace a couple of valve stems. It worked great to get the tire far enough away from the rim to get the rubber valve stem out and a metal clamp style valve stem in. At 77 that seemed like a good idea but I gave up after two and brought the car to Tire Kingdom to have four new Riken tires (from Tire Rack) and the two remaining valve stems swapped. I brought the stems to Tire Kingdom and assumed they knew what they were doing. Turns out they don't and after installing all four directional tires the same way (so the two tires on the right side were sweeping water under the treads instead of away). Talk about a squirrely drive home in the light rain. They remounted the tires for free and I thought I was good to go. Two days later I smelled a dead skunk on I-95 heading home but it turned out to be one of the valve stems they installed wasn't even finger tight. Centrifugal force at 70mph let the stem move into the rim and allow air to get out. The hotter the tire got, the more air came out. A burning Riken tire smells just like a dead skunk. I had to buy a fifth Riken tire but I had it installed at FUBAR tires rather than go back to Tire Kingdom.Glad you got it done, I'am getting to old to wrestle with tires, they go to the tire shop
that fire extinguisher is water? i'd be more inclined to just get a hose if that's all it is.I would imagine the pivot is important if you are working at capacity, but a bit of movement for a homeowner rig probably would be fine, how far are you thinking of moving it?
Also this Fire Extinguisher is one of the best investments I have ever made, easy to use and totally reusable.
That just adds to the excitement!God forbid you have an electrical fire and you decide to throw water on it.
