hewey
New driveway looks great, and from what I can see it looks like a nicer approach to the house too.
Out of interest what colour are the sheets on your shed. I like how it looks![]()
but that didnt stop us stirring him![]()
That balustrade came out really nice, nice work!
Rego will be a bit under $200 so assuming there are not too many minor incidentals I think he has done well.
Thanks Geoff.
Im just having an early lunch stop from cutting sheet metal, it is a terrible job.
So what do you use to do that? - cut sheet, not eat lunch
Yesterday I was using my 5" grinder with a 1mm cutting disc. Today I am going to try something that goes against my better judgement so I may end up in hospital
But apparently these are great for cutting sheet metal.
https://www.totaltools.com.au/113393-evolution-1200w-185mm-multi-purpose-circular-saw-rage1b
All the youtube videos I have been watching shows people with a lot of blade hanging out the bottom......I think Ill try my first cut with minimal blade exposed.
I use an evolution compound mitre saw to cut all my RHS and SHS during the day (extremely noisy) and I use my horizontal band saw during the night. My nieghbour's are a long way away so they cant really hear anything but I am pretty sure a mitre saw cutting steel at night would be heard miles away!
Interesting. I had a look at that Evolution saw and also their mitre saw you mentioned. Is there anything special about them other than the blade? Could you put the same blade on another saw and it'd do the job just as well?
From what I understand, it's a combination of the blade, slower blade speed, and a more robust gearbox. On most wood only circular saws the internal gears are 'surprisingly delicate' and are unlikely to survive the added shock load of metal cutting.
Could having the blade extended well past the cut improve the chipping action of the teeth and reduce kickback, while reducing the number of teeth in contact with work to reduce load on the motor and gearbox?
I have been contemplating one of the Evolution mitre saws but was concerned about the noise generated living in the burbs - from your comments looks like I'll be sticking to a bandsaw.
