Now that the Fabrication Bench has been signed off as complete, I fitted some new electrics to the desk lamp I scored of EBAY a few weeks ago, although not period correct as I have done with other lamps in the past the newer style fittings and lead are a hell of a lot safer for every day use. I have picked up a 40 watt BC LED daylight lamp to try as well.
View media item 46374
I picked up another couple of sets of castors the other week firstly to make a another trolley that will fit the 20 tonne press to make it mobile. Although along the same lines as below it will be a little bigger than the other set I made last year and be multi functional as against fitting the castors permanently to the press.
View media item 31942
The second set of castors that you see mounted to the angle iron will go to make another utility table the same but a little lower than my first. I use it daily and is the best thing since sliced bread.
View media item 32440
Have a great day, regards.
How do you find the time. You are truly what we around here call a "doer". "Doer hafcup" tha's what I am going to start calling you. I am curious and if you don't mind me askin, how old are you. And do you have any help on these projects.
