1/2: speaking of Andrew's engine is it going to go in his car without any modifications to the frame or making new mounts for it?
Andrew must be quite busy with 2 little boys and a new engine and racing hobby? he's learned from the best that is for certain.
any new pictures of the new RODENTS? any names yet or did i miss that? or many you wait to name them until they open their eyes and start roaming the Shed's grounds.
congrats on getting the tenant situation figured out and really hope it works as it is designed or maybe better.
nicely done mailing a few of those Ford signs out to members that maybe they were made for in the first place!!
cheers
Drives, thank you yet again..
The
Rover K Series is getting nearly a full makeover and freshen up and about the only thing that will not have anything major done to it apart from a service will be the close ratio gearbox that went in earlier this year.
Here is a breakdown of what has been and some of what will be done:
Engine;
New liners, Omega pistons & Maxspeed rods.
Upgraded oil rail.
New oil pump and then modified the galleries for better flow..
Water pump and all new plumbing.
Bearings, seals & gaskets.
New lightened flywheel and clutch assembly.
New harmonic balancer.
New knife edge billet crankshaft.
Balanced all reciprocating components.
Oversized valves.
Bronze valve guides.
Mechanical lifters.
Piper camshafts.
Port and polish cylinder head.
Vernier cam timing gears & timing belt and tensioner.
Replaced all ancillary things like stretch bolts, gaskets, sensors, transducers & pressure switches.
Coat exhaust extractors.
The sub frame:
New Janspeed fully welded unit.
New engine stabilizer bushes.
New engine mounts.
Full adjustable suspension arms.
New wheel bearings.
Replace drive shafts.
New sub frame solid mounts.
Andrew is one busy lad, with young
Aiden taking priority at the moment. BTW who is doing really well.
Bear in mind that this is my first
Rover K Series build, so it has been a steep learning curve for me as well.
The # Gen 2 rodents are still fairly docile, just finding their legs and are growing at a rapid rate. It will be a few weeks before they are under foot and discovering the garden.
I will endeavor to get some pics of the pups up this week. We have not named them as yet as the Breeder usually likes to do this.
The
West Wing is ready to go apart from detailing the lawns later this week. I basically demobilized the home on the weekend removing all our goods and chattels and replaced the drawer runners on the dishwasher last night.
The
Ford Scripts were just a spur of the moment thing really as you do, I am just so pleased that I was in a position to do so..
Have a great day and I thank you for your visit..
