Razorhunter
- Joined
- Apr 25, 2013
- Messages
- 393
I have obtained ( basically for free) a 5'x10'x1" piece of plate steel.
It is not badly bowed or warped. It currently sits on 6x6 blocks in my driveway, and can be manipulated much easier than I would've guessed via placing shims anywhere between the plate and the 6x6's it resides on.
Now obviously I want it as straight and flat as possible, but I probably won't be able to get it blanchard ground or anything like that.
I just want to fab up a frame out if either tubing or c channel to support the 2040lb plate/top.
Anyone here done this? I know how to weld pretty square and straight off of just a concrete floor (using the three-points-of-contact rule) but I'm considering just fabbing/welding the frame up on top of the plate itself, basically using the plate as a flat plane.
I would of course shim it anywhere necessary first and go from there. As I said, when I tightly pulled a very fine monofilament line across it (yes, backyard engineering), it is amazingly flat.
Just trying to do the best I can with what I've got here. Any help or advice is much appreciated guys.
I've needed a big, thick and flat (as possible) weld/fab table for years and quite frankly I've never felt like I'd be satisfied with 1/2" plate etc. I really hope I can pull this off and have a very acceptable level of flatness when complete.
Thanks for your time guys.
