Air compressor advice
T
thinktwicez71
Ogdensburg New York
I just saw a saylor beall 4500 chart that showed this pump with a 15hp motor is run at 830 rpm , and the 10hp version from the factory is run at 605 rpm . So I'm guessing it can go at least as low as 605 then
The Tool Tyrant
Bonita, Ca. (San Diego)
Okay, but that's with 2.5 more HP than a 7.5, so it would need to turn slower than 605 in order for the 7.5 to pull it. That's a big pump, which will put out probably more CFM than you'll ever need, so if the minimum pump rpm is low enough that the 7.5 will pull it, you should be good...but check first.
T
thinktwicez71
Ogdensburg New York
Ok just in case the 7.5hp doesn't work and I need a 10hp , are leesons better than baldor for single stage ? I saw a 10hp leeson single stage 1725 rpm new with a sf 1.15 for 749 shipped . The place is out of Texas and he said it's better than a comparable baldor and 300 cheaper ! , what are your thoughts ?
T
thinktwicez71
Ogdensburg New York
More amperage he said and more torque
rrangus
Wilkesboro, NC
You can go slower on the pump, however there is a minimum recommended speed to operate at. Make sure what that is and the HP to turn that speed. Some of the manufactures put out a chart that will show pressure/speed/HP/cfm's. Make sure that you have the electric power to run it also. Your starting to talk about bit amps here.
on edit, here is an example from Kellogg for pressure/speed/HP/cfm's. http://www.aircompeq.com/ka.htm
edit#2, here is from SB, http://www.saylor-beall.com/pumps/ . If you have a 4500 pump then it looks to be spec'ed for 10-15 hp and may not do well with 5 -7 hp. Also on the SB site they have manuals for the different series pumps you may want to read once you figure out the pump your looking at.
lg
no neat sig line
I am not sure that there is a minimum RPM for the compressors. The chart just shows RPM's for rated capacity.
Having bought many compressors over the years, I would take the Saylor Beall over the DeVibiliss. I am running a 5 hp SB that I bought new in 1986, many days it never shut off other than at lunch time. I also have a Quincy QP pressure lubricated compressor. It is over 20 years old with no problems.
T
thinktwicez71
Ogdensburg New York
Basically we are more worried about the minimum rpm for the compressor to keep proper lubrication because it's a splash lube compressor
T
thinktwicez71
Ogdensburg New York
Well I talked to Saylor beall this morning , according to him the slowest rpm is 605 rpm which is what the 10hp from the factory does . So i ordered a new baldor L1512T . 10hp single phase 1725 rpm . Great deal I thought , free shipping $875.00 . Glad the wife pays the electric bill haha. Honestly the limited amount I'll use this it won't be a big deal
The Tool Tyrant
I'm glad you THOUGHT TWICE :lol_hitti about trying the 7.5 hp motor. Personally, I would have gone with the Baldor 10 hp also, I've always had great reliability with the Baldor's. That pump will put out some serious CFM for sure.
Make sure you use the correct wire size for that motors amperage draw.
Good luck!
larry_g
oregon
You have one other knob to turn besides pulley ratios. When you get this thing running get an amp probe and monitor the input current while running. You will see the current rise as the pressure builds. If the pressure rises to a point that he current draw is exceeding the motor limits before cut off, you can lower the cut off pressure. There is really no reason for most people to have a 175 psi cutoff. and the energy used going from 150 psi to 175 is a lot. I have mine set at 110 cutin-150 cutoff and all works sweet.
lg
no neat sig line
T
thinktwicez71
Ogdensburg New York
Well ain't this some **** ........did some searching on saylor website for parts and came across a drawing of the 4500 pump and on the bottom it clearly says min pump rpm 400 max 830 rpm. Figures after I already ordered the 10hp and it's shipped , oh well .
http://www.saylor-beall.com/wp-content/uploads/4500_Pump_Drawing.pdf
Look at bottom of drawing
T
thinktwicez71
Ogdensburg New York
I know I need a new magnetic motor starter for this , but what about the pressure switch ? They just installed a new one on it before I got it , but I don't know if it's approved for the hp motor I'm installing . It's a square d 9013ghg2j63
T
thinktwicez71
Ogdensburg New York
What is this hp figures in the installation manual ? That's what has me confused on the pressure switch , wasn't sure if it couldn't handle the amperage going through it
The Tool Tyrant
I have used several different manufacturers (Square D, Furnas) pressure switches and have never seen anything regarding what you show above. The pressure switch controls the relays in the magnetic starter, so the electrical load seen by the motor does not flow through the pressure switch.
T
thinktwicez71
Ogdensburg New York
I got my baldor motor , I just don't understand how I mount it . I got these little c channel pieces and studs in a track but the holes on the motor appear small ( haven't actually tried yet 135lbs). Do the studs go through the motor base holes or does the motor get clamped down ? Pictures in a minute
T
thinktwicez71
Ogdensburg New York
Pictures
....i tried looking online at pictures but still can't figure it out 1b7a6d818c7d73e3cc6f93d3cb52d4e3.jpge27ad53f2b057a2d9949e42e184b4050.jpg49997fcec655ea73f8fa52bc88a0a339.jpg2891fd15340784fbf3a38d8023345603.jpg
The Tool Tyrant
That's an adjustable base plate which allows mush easier belt adjustment. You can see it's fully adjustable, so it should fit your 215 motor frame. If the mounting bolts are larger than the holes in the motor plate, just enlarge them to the correct size...no big deal.
The Tool Tyrant
Belt alignment and tension are critical. Remove the belt guard and use a straight edge off the face of the pump pulley when installing the motor sheave to make certain that the BELT GROOVES are in direct alignment. Check the manual for correct belt tension...it will probably seem much tighter than you THINK it needs to be.
redmondjp
Redmond, WA
Yes, and if installing new belts, you want it really tight as the belts will stretch and will have to be retightened at least once after a few hours of operation.
T
thinktwicez71
Ogdensburg New York
Got the motor installed I need to make one more small adjustment on the belt tho. I'm about 1/8" too far out on the motor pulley . I don't know why the previous owner botched the fan guard like this , it wasn't that time consuming doing it the right way and taking the aftercooler off .
T
thinktwicez71
Ogdensburg New York
Progress is being made af1c93b9dad0e7ba16927c60f5d029e2.jpg13095a2b8cdfe224b83c4ba551ba8eb8.jpgcb7fbb4d445bf69a17590525ea750162.jpga10218aff41c11cd2c43dd65a2d90e78.jpge8b61d45e461774fc0b0c4e157a2be93.jpg
The Tool Tyrant
Now...well, actually BEFORE you installed the drive sheave...but it's not too late to remove the belt guard and straighten out that mess!! Don't get over-anxious to hear it run :rocker: and then kick yourself in the **** for not fixing it correctly! :mad:
T
thinktwicez71
Ogdensburg New York
Give me a chance to use my mig welder and mig all the cuts back together , or just put a whole new piece of mesh in it , we got pieces at work
T
thinktwicez71
Ogdensburg New York
These must be as rare as hens teeth , I've looked everywhere since I bought this and I have not seen one video or even another setup like this one that somebody has anywhere . Curious to see it running or what it looked like from the factory . I can't imagine this crooked concoction of pipeing is stock. , plus I would like to hear one run
T
thinktwicez71
Ogdensburg New York
This is what's ,on it 4c65f4d63d87134fb7347fb86a8e26d6.jpg9128977ff42de6e4606b21b7e0512b6e.jpga088e913aaa07eadb9a36914adc01699.jpg0f357fcb7221a9c803f0e3409ce614c1.jpgbb2d52bc53f802bc6acd4b1abcd47275.jpg
T
thinktwicez71
Ogdensburg New York
I stopped over to the local motor shop , he said I could use a fasco h360c for my motor starter and wrote me a diagram of how to wire it all . Is this ok? Sure was slot cheaper than. 240 73b5c0ca909d0f7dfa136e13d91ac1b2.jpg
T
thinktwicez71
Ogdensburg New York
What's the difference between what the motor shop sold me and the others ? Is it the overload relay part something I need ?
T
thinktwicez71
Ogdensburg New York
Well I did that , but apparently that's just a contactor , a cheaper version , the better version is $200 more than this but that version has overload relay protection which this cheaper version does not . He said this will work , but my question is will this version do more harm to the motor if something goes wrong ?
