Air Compressor issues!
mw3designs
New York
Well the pump on my Ingersol Rand SS5 finally gave our. Made it 10 years so I’m not complaining. To make a quick fix I grabbed a HF 5hp pump and retrofitted it to the tank. Went to start it up and the motor started slowing at around 100 PSI or so, and the pressure switch didn’t cut it off at 135 like normal. So I grabbed a new pressure switch, and that solved the cut out issue, but still it gets slow at around 100psi, and fluctuates rpm. I thought maybe the belt, but tension is good, I’m only using one belt on the double pump pulley though, don’t think that would matter though.
Any ideas on things I can check? I’ve wasted almost 2 days Messi g with this thing, and I need it up and running today, or I am pulling the trigger on a new Quincy.....
DeeKay
Colorado
I'm confused, the motor went out so you replaced the pump?? that could be the problem right there
mw3designs
New York
Typo.... the pump started knocking pretty bad. I edited the post. That would be confusing, and wouldn’t say much for my knowledge.
The Cobbler
you put oil in the pump I am assuming...
what rpm are you spinning the pump at?
how tight is the belt? could the single belt be slipping?
are you sure the pressure gauge is reading accurate? ( since your original pressure switch wasnt getting to full pressure)?
Wrench97
Southeastern Pa
Specs for the SS5 pump
Air Compressor Pump, Number of Stages 1, Splash Lubricated, 5 hp HP, 16.3 Free Air CFM @ Max. Pressure, Max. Pressure 135 psi, Oil Capacity 40 oz, NPT Outlet 1/2 in, Pump RPM 1,000, Rotation CCW, Groove Section A, Groove Quantity 1, Flywheel Included Yes, Flywheel Dia. 14 1/2 in, Sheave Size @ 1725 RPM 4 in, Cast Iron Construction, Valve Material Stainless Steel, Valve Type Finger, Mounting Pattern 6-19/16 in W x 6-5/32 in D, Overall Height 20 in, Overall Width 15 in, Overall Depth 14 in
What RPM and pulley size are spec'ed on the new pump?
marinusdees
Edgewood, Washington
Is that a true 5 hp motor, or a 5 hp spl?? How many amps does the motor nameplate rating specify?? Some of those 5 hp spl (special) motors are closer to 3 1/2 hp and will not run a 5 hp rated pump at full pressure.
