I was thinking of buying another kit as a christmas gift and came across this image. I forgot phones have very decent built in gyros so it's possible to get an app to do the same job:Thanks for your input. I purchased the sharpener and was able to improve my pocket knives but I think I will follow you further by buying the gauge. I appreciate the tip.
I'm seeing $399 for that vise now.
Mike
Not anymore, but there is a 3" for $60
Must be a targeted 20% coupon, darn it!Received one of these from Amazon yesterday. Not a pro level vise by any means but a cut above similarly priced sloppy garbage available under many names. Moveable jaw has no slop due to center guide rod and removable jaws decently finished. Bottom side is ground and parallel to jaw slides. Looks identical to the equivalent Wilton selling for ~$53. With 20% coupon Amazon has been running on and off it came to $31 delivered. Nice little vise for being a cheapie.
I don't see a coupon on thereReceived one of these from Amazon yesterday. Not a pro level vise by any means but a cut above similarly priced sloppy garbage available under many names. Moveable jaw has no slop due to center guide rod and removable jaws decently finished. Bottom side is ground and parallel to jaw slides. Looks identical to the equivalent Wilton selling for ~$53. With 20% coupon Amazon has been running on and off it came to $31 delivered. Nice little vise for being a cheapie.
Don't know if it's a targeted coupon, only that it would appear sometimes when I was checking back and forth on it when comparing it to other vises. Maybe being a Prime member helps, don't know.I don't see a coupon on there
In for one at $31. The coupon was automatically applied for me.I don't see a coupon on there
those are missing the stabilizing rod like the Palmgren so a bit sloppier. IHHP & shars carries a Palmgren clone ranging from 35-45
In the past at different times I had 3 of that style (without the quick release) and they all had sloppy jaws and were not machined flat on the bottom side but powder coated/ painted like the rest of the vise. Many of these cheap vises are not machined flat on the bottom. Also no V-grooves in the jaws for holding circular objects. None of this may matter to you as we all have our own criteria. Just putting it out there.
****The places that I saw the Shars vises, although at a good price, also wanted ~$18-$20 delivery.those are missing the stabilizing rod like the Palmgren so a bit sloppier. IHHP & shars carries a Palmgren clone ranging from 35-45
3" Precision Drill Press Vise
www.shars.com
I'm partial to this quick release design personally though it's a bit taller:
Pardon Our Interruption...
www.ebay.com
Gotcha, I had picked this one up in the past and is also a decent option if you can catch in a deal. Downside is being a milling vise it's slow to screw:****The places that I saw the Shars vises, although at a good price, also wanted ~$18-$20 delivery.
****The quick release designs, although nice to have, were not as important to me as having 2 flat surfaces to support workpiece.
VEVOR 3" Milling Machine Lockdown CNC Vise w/ 360° Swivel Base Clamping Drilling. @chingOn(thank you for putting this on my radar)
Although the set came w/2 diamond hones, I became a fan quick since they don't need water. I also suspect the corundum stones won't last. I found these three deals:
Coupon popped up for me today and I snagged one, thanks:Don't know if it's a targeted coupon, only that it would appear sometimes when I was checking back and forth on it when comparing it to other vises. Maybe being a Prime member helps, don't know.
I will tell you that it's a solid little vise (~8 lbs.) and it came finished in a nice blue color instead of the gray shown in the ad. Also came with an instruction leaflet and 2 Allen wrenches (one for the jaw screws and one for the grub screw that retains the threaded rod into the moveable jaw). After seeing what is out there being offered and what you get (or don't get) for your money, I'd pay the $ 36.44 and still be satisfied. The lowest price I've seen elsewhere was ~$63 and even up to~ $90 (obviously overpriced) at industrial suppliers. So, if you're interested, you might grab one and return it if not satisfied. A few minutes ago Amazon showed 5 in stock and you don't know if the price will increase when they get a new batch to sell.
P.S. I added a short M6 bolt and nut to lock down the grub screw which has a habit of backing out after running the jaw back and forth a bunch. Don't have any Loctite on hand.
I bought an open box 1/2 HP from them for $87 a couple weeks ago.Bought this earlier today. The 1/2HP version was $115.00. Amazon's list price of $270.90 for the 3/4HP version is fantasy. The MSRP is $150. I am replacing a 20 year old 1/2HP In-Sink-Erator Badger 5.
In-Sink-Erator 3/4HP
i know these tend to have a low longevity rate, but at this price if it gives me 2 hours of relief from cleaning small parts ill call it a win.
I have a larger version of this cleaner in my shop, it's been running well for ~3 years now. I wouldn't say it receives heavy usage but at least a few hours a week.i know these tend to have a low longevity rate, but at this price if it gives me 2 hours of relief from cleaning small parts ill call it a win.
Now 10 bux lessBought this earlier today. The 1/2HP version was $115.00. Amazon's list price of $270.90 for the 3/4HP version is fantasy. The MSRP is $150. I am replacing a 20 year old 1/2HP In-Sink-Erator Badger 5.
