Amazon Warehouse Deals
Ryan
Administrator
Texas/Hawaii
Ok. Links check out fine. I think this might be an Android or Os deal that I’m missing. I’ve filed a ticket with Amazon…
InsaneEd
trying to be professional here… you know, fix ****… and then I see this and it makes me think of “My name is earl”….
*****, you know I hate peas!
I got the 403 error on all of the attached links including the one Ryan posted. I am running Android with chrome. It opens a new blank tab then a few seconds later gives me the forbidden error 403. Hope this helps.
jetrep
Same for me. Non Amazon links work fine.
tool_scrounge
Southern California
Link problems? I’m here to help…
Does this link work?
No, this does not work. It spends 2 minutes trying to load and then gives a 504 error
I am using a Samsung tablet running Chrome browser.
Edit: But it does work fine on a PC with Firefox
Edit2: Samsung tablet running Firefox browser fails with a 403 error
Crabman
Alexandria, VA/Dameron, MD
I used desktop PC with Firefox to load the deals.
All links work for me.
Android was developed by Google after they bought the company.
Just tested, links also work on my desktop with Microsoft Edge.
Sounds maybe like Google theft, not Samsung since Scrounge getting errors with Chrome. InsaneEd using Chrome, Liketowheel also. jetrep chrome mobile. logixjack chrome also. Not all Samsung devices?
Not sure about Pelican or David (Fatboy).
Swervyjoe
SC
Links don't work for me either. Seems to just be Amazon links. 403 error
Older tablet. Android using Chrome.
thepipe
Southern NJ
Ha. Looks like android is trying to replace my affiliate code with their own. Not y’all’s problem obviously… I’m on the hunt for a fix.
Probably only a very small error in their code which brought this to the forefront. Makes you wonder what would have happened if there had been no error, and whether this has been going on unnoticed for some time. Regardless, this is theft, plain and simple. I'm glad you figured it out.
Crabman
Folks,
We obviously just went through a technical glitch yesterday with the Amazon links.
I know a number of you use Tapatalk. There is a big issue brewing between GJ and Tapatalk.
Ryan started a thread about it here:
I am posting this so the Tapatalk users have a heads up, as you may need to transition to browsers or other means of accessing the GJ site.
Bruce
Ryan
Administrator
Texas/Hawaii
Just got an email back from Amazon... Apparently, they are having "DNS issues". This explanation makes zero sense to me, but I will keep communicating.
dogdog
It’s working now that same link or any other ones I have problem with earlier. Weird
D
Duker
Livingston, TX
As most of you have seen or have experienced by now and as noted by Bruce above the Tapatalk issue has wreaked havoc on accessing the site as I used my iPad or iPhone to read the threads and post deals to the thread. So far I have not found a viable option that made posting deals as easy as Tapatalk to post deals. I asked Ryan on the aforementioned quoted thread for any suggestions he might have but I am reaching out here as to any ideas anyone else might have because at the stage I am dead in the water as other methods I have tried so far in trying trying to post 30+ deals average on a Saturday a deal breaker.
Ryan
Administrator
Texas/Hawaii
I just tried it again and it now works.
Amazon fixed the issue... Ironically, it as an AWS issue.
Copied over from the Tapatalk thread:
Yes. The browser.
You can copy an image found anywhere (the internet, you computer, etc...)... and just paste it into the text field that you create a thread/post with... It's super simple.
D
Duker
Livingston, TX
Walter 13K654 Stringer Bead Wire Wheel Brush - 6-7/8 in. Carbon Steel Wire Brush with Threaded Hole. Abrasive Power Brushes​
D
Duker
Livingston, TX
D
Duker
Livingston, TX
Milton Pro Digital Tire Pressure Gauge S-577D, Straight Foot Chuck with Lock, Pistol Grip Handle, Easy to Read 0.1 Display, 255 PSI Max Pressure, 15 Inch Hose, 1/4" NPT (PSI, kPa, Bar, and kg/cm2)​
D
Duker
Livingston, TX
BIG RED ATB123R Torin 16" Cantilever Style Portable Steel Tool Box with Trays and Metal Latch Closure, Red​
D
Duker
Livingston, TX
United Abrasives-SAIT 23022 Type 1 A36T Fast Cut-Off Wheels, 2-1/2-Inch x 1/16-Inch x 1/4-Inch, 50-Pack​
D
Duker
Livingston, TX
United Abrasives- SAIT 78109 Ovation Flap Disc, 4-1/2-Inch by 5/8-11-Inch, 80 Grit, 10-Pack​
D
Duker
Livingston, TX
PIC Gauge 202L-404G 4" Dial, 0/200 psi Range, 1/4" Male NPT Connection Size, Center Back Mount Glycerine Filled Pressure Gauge with a Stainless Steel Case, Brass Internals, Stainless Steel Bezel, and Polycarbonate Lens​
D
Duker
Livingston, TX
Flexzilla Open Face Retractable Air Hose Reel, 3/8 in. x 25 ft, Heavy Duty, Lightweight, Hybrid, ZillaGreen - L8603FZ​
D
Duker
Livingston, TX
PFERD 61787 Bench Grinding Wheel, Silicon Carbide, 6" Diameter, 3/4" Thick, 1" Arbor Hole, 120 Grit, 4140 Maximum RPM​
