Amazon Warehouse Deals
Crabman
Alexandria, VA/Dameron, MD
So the first image is "full image" of a screenshot showing the Amazon pricing.
The second is a screenshot of what I see when going to post a reply.
The third image is what I saw when I went to attach image one, showing the option of "thumbnail" or "full image"
Hope this helps. I am sure I stumbled into it like the blind squirrel finding the acorn.
Bruce
D
Duker
Livingston, TX
Duker,
I am using a desktop with Windows. I will post a deal to try to illustrate.
Milton 1805 3/8" FNPT P Style Coupler - Box of 5​
Regular $51.43, used very good $18.36
Brice thanks I went back and found that I missed seeing the pic size setting when using insert pic so I that will fix the size issue.
D
Duker
Livingston, TX
D
Duker
Livingston, TX
D
Duker
Livingston, TX
Walter 12E557 Bench Grinding Wheel - Fine Grit 60, 8 in. Finishing Wheel for Bench and Pedestal Grinders. Abrasive Finishing Supplies​
D
Duker
Livingston, TX
Linemaster 531-SWH Hercules Foot Switch, Electrical, Single Pedal, Momentary, Single Stage, Full Aluminum Guard, Orange​
D
Duker
Livingston, TX
D
Duker
Livingston, TX
Coilhose Pneumatics PU14-30B-G Flexcoil Polyurethane Coiled Air Hose, 1/4-Inch ID, 30-Foot Length with (2) 1/4-Inch Reusable Strain Relief MPT Swivel Fittings, Neon Green​
trim
South Carolina
Crosby 1018534 Carbon Steel G-209 Screw Pin Anchor Shackle, Galvanized, 8-1/2 Ton Working Load Limit, 1" Size​
I grabbed the shackle. Thanks Duker!!!
D
Duker
Livingston, TX
Foundation post... maybe.... I am thinking adjustable height grinder stand!
Akron Products P M130 3" Adjustable Steel Mini Columns, Monopost 3' - 3'4", 33 Gauge, 36" Length, 36" Height, Red​
D
Duker
Livingston, TX
Winters PFQ Series Stainless Steel 304 Dual Scale Liquid Filled Pressure Gauge with Brass Internals, 0-10000 psi/kpa,4" Dial Display, +/- 1.5% Accuracy, 1/2" NPT Bottom Mount​
D
Duker
Livingston, TX
Goodwrappers PL200800 Linear Low Density Polyethylene Clear Cast Disposable Hand Stretch Wrap with Plain Core Extensions/Built-in Dispenser, 800' Length x 20" Width x 120 Gauge Thick (Case of 4)​
D
Duker
Livingston, TX
LMT Onsrud 60-127MWSolid Carbide Max Life Compression Spiral Cutting Tool, Inch, Uncoated (Bright) Finish, 30 Degree Helix, 2 Flutes, 3.0000" Overall Length, 0.3750" Cutting Diameter, 0.3750" Shank Diameter​
D
Duker
Livingston, TX
Use for an in/out feed table of a saw or to slide steel onto a plasma table etc..​
Hudson Bearings MBT-1 Drop-in Style Machined Mounted Ball Transfer, Carbon Steel, 1" Diameter, 200 lbs Load Capacity (Case of 10)​
D
Duker
Livingston, TX
Forget Protecting that dining room table... protect that workbench!
Wooden Furniture Table Protector Clear Plastic Wipeable Tablecloth Thick Desk Protective Cover Clear Vinyl Dining Tabletop Protection Pad Easy Clean Polyester Dust Waterproof PVC Cloth 4ft 48 x 84" 86​
Well I ran out of time.... that’s it for today. Have a great weekend!
zeekh
Upstate NY
Thank Duker, I picked up the stretch wrap. Almost grabbed the ball rollers but changed my mind. Not sure if they'd work for my project
