Amazon Warehouse Deals
D
Duker
Livingston, TX
Wisamic LED Work Light for Lathe, CNC Milling Machine, Drilling Machine, Aluminum Alloy, 12W 110V-220V, Flexible Arm, Adjustable Multipurpose Machine Worklight, Long Arm​
D
Duker
Livingston, TX
D
Duker
Livingston, TX
D
Duker
Livingston, TX
D
Duker
Livingston, TX
D
Duker
Livingston, TX
Action Pump QS-1 Pro-Lube Hand Operated Drum Pump, Rotary Action, Max Pressure 10 psi, Max Viscosity 2000 SSU, Inlet Size 3/4 in FNPT, Outlet Size 1/2 in FNPT, for Use On 15 to 55 gal. Drums​
D
Duker
Livingston, TX
D
Duker
Livingston, TX
Reliancer 3-Tier Rolling Welding Cart MIG TIG ARC Plasma Cutter Machine Heavy Duty Welding Welder Cart 350 Lbs Weight Capacity with Tank Storage & 2 Cable Hooks & Safety Chain Plasma Cutting Equipment​
D
Duker
Livingston, TX
D
Duker
Livingston, TX
Wire up the shop for sound!
EWCS 16 AWG 2/C Str CMP Plenum Rated Shielded Sound & Security Cable - 1000 Feet - Made in USA​
D
Duker
Livingston, TX
EVEREADY Led Light Bulbs, E39, 150 Watts Equivalent (90W Led Bulb), 10800 Lumen, 5000K Daylight Color, Non-Dimmable, High Bay Mogul Base Replacement, Great for Gymnasium, Garages, Warehouses - 4 Pack​
well that was a slow and painful learning process on the iPad this morning but it got a little faster as I went along... might have to change this to Sunday evenings and post these from my office.
That’s it for today. Have a great weekend!
Crabman
Alexandria, VA/Dameron, MD
Duker,
Thanks for the posts. It's going to be a bit of a relearning process for sure. I posted some deals last weekend and it is going to take a while to get the hang of it.
Have a great weekend too!
Bruce
Crabman
Ok here is a deal, but also an experiment. Duker's posts were great, but the screenshots were too small for my old eyes to read.
So I am going to try different pictures. This will take us off topic on deals, but hopefully get us on a good track going forward, sorry for the off topic interruption.
So the small picture was uploaded as "thumbnail", the larger as "full image". I can read the big one. Thoughts?
Sunex 57PPK5 5-Piece, Press Punch Kit​
Regular $78.59, used very good $42.18
Screenshot_2021-06-05 Sunex 57PPK5 5-Piece, Press Punch Kit - - Amazon com.pngScreenshot_2021-06-05 Sunex 57PPK5 5-Piece, Press Punch Kit - - Amazon com.png
Crabman
TEKTON 12-3/4 Inch Groove Joint Pliers (2-1/4 in. Jaw) | 37525​
Regular $19.40, used very good $12.37
This is how I posted last week, just the item, not a screenshot of the pricing like Duker does. The prior post does that.
Again big is "full image", small is "thumbnail"
Nick Danger
Albuquerque
On my computer, I can see a bigger picture if I click on the thumbnail. It goes to full size when I click on the "+" symbol at the top right. The full size version is easy to read.
It looks like I don't even need to click on the "+" symbol. Just clicking on the picture enlarges it.
jetrep
I too had to click/ tap on dukers images this morning otherwise numbers on the image were not legible. That first photo you posted worked good or just putting it in text is cool too. I'm just glad the links are fixed!
motorcycle79
wisconsin
there was supposed to be some quotes there but I’m not sure what happened.
I agree with the size. dukers pracrice posts were bigger and better. But I don’t want to complain im happy he is trying to figure out a way to get us deals. I’m happy as long as duker and others keep posting. I would have not had the patience To figure it out.
D
Duker
Livingston, TX
Bruce, how did you get the larger pictures? On my iPad i do a screen shot then the only option I could see was to upload the pic as there was no way to paste the photo and that was the default upload size. When I did the test photos I was using my work computer which is a Windows system and was able to paste straight into the post. I will keep experimenting. Ryan is also checking on his side to see if he can find some ways to simplify the process.
rvieceli
Illinois
The thumbnail size post expands to the whole screen if you click it. then if you click outside the pic it goes back to the original post. 2 extra clicks shouldn't be a big deal'
Ron
