Any suggestions for workshop builder in north metro ATL?
Jawn
Stuck in traffic, GA
Running out of options...
I want to build a workshop, but nobody seems interested except the square tube steel building guys, and I'd rather not build that kind. Most either never respond to my initial inquiry, or they ghost me after initial contact.
I had in mind a 24x36x10, but may have to scale it back due to cost. Morton came back with a budget-blowing price for that size. I'd hate to have to scale back, but I may have no choice. I was about sold on a TuffShed stick built, but I asked for customization (taller sidewalls) and never heard anything from them afterwards.
DIY isn't really an option. I built a small shed a few years back, took me forever and a day (kept putting off working on it), thus the wifey will not tolerate me building it when I have many other things I need to be doing.
Lucid Moments
Gainesville, Ga
I can give you the name of the guy who built my home and shop. He is a homebuilder though and mostly works local to me so I can't say if he would be interested or not. Let me know if you want it.
elvee
Atlanta, GA
It's tough to find that kind of builder around here. For the most post you find either tract housing builders or custom home builders. Neither is going to want to build what you want. Every worthwhile GC I know is booked out right now and isn't hurting for work. Material prices are also way up again (even though aluminum and steel are way down). Good luck.
J
Jawn
Ideally, 30k for at least a dry shell with electric service to the panel (still waiting to hear back from the PoCo how much the new drop would be). I can't build the structure myself in a reasonable amount of time but I can take my time on the inside.
I was hoping to get stick built, but if price dictates I may have to go with one of the tubular steel buildings (better than no shop or too small of a shop).
TRWham
East Cobb County, Georgia
That's your problem. I doubt you will be able to find a competent GC for $35 per sq ft. I don't think we could do it for less than $70 just dried in depending on exterior finishes and site-work. No mechanicals at all in that number.
J
Jawn
Well, I haven't started out saying what I have to spend, and I've not heard from anyone to know what price is reasonable so that shouldn't be the reason for silence. I had started looking at this a couple years ago, thought I had an idea what it would cost but apparently not.
J
Jawn
FWIW, tuff shed's configurator shows about 14k to 22k plus concrete depending on options, but that's with 8' side walls. I have been trying to get a price out of them for one with 10' walls but haven't heard back.
Metallitubby
ATL OTP North
I just had Morton build my dried-in shell for $52k
32x30 w/ 12ft lean-to off the back
14ft ceiling
Monolithic slab
Very basic appointments, but very well built. I'm surprised Chad didn't work with you a little bit.
J
Jawn
That would be a great shop, but $52k is not possible for me. He priced me a 24x36 with 10ft walls, it was a good bit more than I had in mind. I am not ruling it out yet though.
General Steel quoted me a good price for a 30x34x11 with insulation, but then I read they have a less than stellar reputation.
I have also gotten a quote from another shed builder for stick build, it isn't too bad for the building itself, but concrete price is still a question mark.
I may have to downsize.
Samh
Canton GA
Cherokee county... more specific in a PM.
I am in Cherokee county as well, in between canton and cartersville.
I am currently building mine and getting ready to run the electrical. Who is your poco? Amicalola EMC or Georgia Power?
Are you against doing the framing and siding yourself? So far, I have only subbed out site prep, concrete, and shingles/roofing. I can give you an idea of how much I spent so far.
J
Jawn
Neither, I am on Sawnee EMC.
As to doing it myself, I would not mind doing some of it but last project I did took way too long. Typical for me, to be honest. So, the wifey insists I get something dry-in and usable, and I can "trick it out" on my own time.
Metallitubby
ATL OTP North
Not to thread hijack, but mine is Amicalola. They've been great to work with thus far, and are pretty excited about my solar project.
socoj2
Running into the same thing in *******.
Mine is about 27.5 by 30 just want the shell for an attached garage ill do everything else myself.
11b30b4
GA
I wish you luck in finding someone to build for you. I live in Snellville and have a ranch with a full basement so my shop is in the basement. However, the next house will need an external shop. If I do anything like fiberglass or painting, even with venting, the whole house smells like chemicals for a day or two. Plus the wife is not happy if I cant sleep and decide to tinker at 3am. Hammering and sanding makes a bit of a racket.
socoj2
I currently am living in a rental in ******* while my house/shop are built. My shop is very similarly sized as well.
Who is doing your build, im almost in cherokee. so im only about 6 miles from ball ground.
Metallitubby
ATL OTP North
Morton built the shop. My house is a Deltec (prefab) being built by Stonecreek.
My rental is right near 20 and Franklin Goldmine (which sounds eerily close to you).
Samh
Canton GA
My neighbor had a company build his a few months ago. I can see about getting their info from them and an approximate cost he paid and its size.
socoj2
Yeah i can almost throw Rocks at you. Maybe if John Smoltz came over. Im at Post and 20.
lilbilly666
Georgia
I don’t have much to contribute as I’m finishing a garage attached to a house, but I’m within peeing distance of the Cherokee line. I’ll be following this thread for sure.
socoj2
Mine is going to be attached as well. since im in an HOA. =/
Damn sounds like we need to do a get together. at who ever has the biggest Garage.
Cobra5150
GA
Small world, I'm 2+ miles east of you off 20. Lots of N GA folks here.
Just across the lake from y'all in Flowery Branch. I went through Ball Ground today and picked up some brats and potato salad at Frankfurt Doner & Grill.
d110pickup
Canton, Ga.
Jawn,
I'm in Hickory Flat and built my shop a few years ago. I've got a build thread on here.
You can probably be your own general contractor. It's a lot of phone calls and leg work but I think it's doable.
Get with me if you want,
Also, PWhittle we're really close, I'm off Sugar Pike.
Mike
J
Jawn
Lots of local peeps coming out of the woodwork here.
That's my problem. Wifey is super sensitive to smells, and it seems the only time I get to tinker is when youngins are asleep. Current "workshop" is directly below bedrooms. Not good.
Thanks, I'd appreciate it.
Jawn,
Mike
Great looking shop. I love the sliding doors on the monitor style building. Looks like plenty of space too.
Metallitubby
ATL OTP North
I am actually at 20 and Post (Derby Downs on Post). My build is near Gibb's Gardens.
Sorry to OP. I'm not trying to hijack. Like someone else said, there's a bunch of us all in one small cluster.
socoj2
LOL neighbors, Im in Marseille.
J
Jawn
No worries about a little threadjack. It's all good.
But back on topic, any recommendations for who to talk to (or who to avoid) for concrete?
matt_i
I would talk to your local concrete mix plant. Just tell them the basics of what you want to do (shop foundation/floor) and ask for a few contact names/numbers.
That's how I went not knowing anyone from anybody. I was pleased with the crew that I eventually hired...in my case it was just flatwork, I had already done my own foundation.
Metallitubby
ATL OTP North
Thomas Concrete has a location on 20 in Ducktown. I'm not sure about dealing with them because my concrete (house and shop) were contractor-led. I know that I can hear their plant first thing in the morning, so I know they are working!
Thomas Concrete ******* West
(770) 887-5077
Samh
Canton GA
GH Concrete did my concrete. Would recommend, they did an awesome job. I'll dig up their number.
d110pickup
Canton, Ga.
One of my buddies used these guys for driveway and concrete, he was happy and pretty damn picky.
D & H Construction , google them.
Their in Atlanta but did his job in East Cobb.
mike
d110pickup
Canton, Ga.
Thanks, If you want to talk shops let me know. I've got lots of "lessons Learned".
Mike
