signcrafter
- Joined
- May 9, 2012
- Messages
- 12,410
Do they thread into the cast iron flange? They make headless toilet bolts, https://www.doitbest.com/product/40...wyybv1bTNhetZpErAZpXNcCwvol66Qy0aAoZhEALw_wcB. If you can't find them locally you can cut the head off a regular(longer) toilet bolt. Screw it into the cast and then use a nut to tighten it down. This will give you the proper stud. Make sure the threads are good in the cast and that they are going to hold the bolt good and make sure that wasn't the reason it loosened up and started leaking.
As for that spacer it's supposed to be siliconed to the cast. I would rip that out and either just use an extra thick wax ring or if you want/need to reuse that spacer I would take it off and clean everything up good and re silicone it to make sure that wasn't why it was leaking. Personally I would just get a new one, they are cheap.
