Getting closer......bought some Grade 8 bolts and washers, to make it stand out and look more industrial
I greased the press first and then greased the horizontal gear piece, and slid it into place with help of a soft rubber mallet
I used a bolt, washer and a large SS fender washer on the end to hold it in place
I then greased the ram slightly and mounted the front cover plate.......I don't think I will need the shims that were initially installed with the plate
The center hole takes a brass bolt, that puts slight pressure on the ram? I need to search around and find one.
Just need to wait on the 1144 steel 7/8"x32" lever bar to get here
I really want to try to use gloss black paint and highlight the press markings
