Asphalt Driveway estimate
infiniti007
Hi all, I have been getting some estimates for a driveway rip out and expansion - will end up being about 2300 sq ft going to a garage in the back of my property. I am considering an estimate from one contractor who has proposed to do: 6 inches of crushed stone, followed by 4 inches of 9.5 asphalt. He said he would try to lay the 4 inches of 9.5 in one go. He has definitely been the most cost competitive.
Some of the other estimates I received were noting: 6 inches of modified stone, 2 inches of base (25mm BCBC), followed by 2 inches of topcoat (9.5mm).
Is the base coat necessary? Should I be concerned with only using 4 inches of the 9.5 on top of the crushed stone? Would you have any concerns about laying the 4 inches in one pass?
I am located in southeastern PA if helpful. Thank you so much.
mm08822
I owned a house where i put in an asphalt drive in '91. It was 2" base + top coat. It was smooth as glass and to this day still looks great....no cracks.
The base coat method is the way to go. 10× better than a single top coat. This will give you the longest life.
I
infiniti007
Thanks for the replies so far.
Do you think it’s a cost thing for this contractor? Do they save money by just applying a 4 inch 9.5 coat in one go? Or would it be similar cost for them if I ask for 2 inch base coat, 2 inch 9.5 top coat?
jack stand
Lakes Region Maine
Yeah his costs will be less. The guy doing it the right way will be paving it twice with possibly a day in between for cooling off the base layer that can't be loaded (truck and paver) before it's cool. Like in overnight. 👍
You'll never get the proper compaction on a 4" lift with driveway sized equipment.
mm08822
The labor is 2x for 2 lifts. The base coat also gives them a chance to address any issues before the top coat is applied.
Sumboodie
AK
Driveways here are 2", 1 coat.
Go figure they are poop.
I'd never do asphalt again. Can't even PARK without sinking and leaving divots, never mind using a floor jack.
