mjozefow
On a side note, I just realized in my signature that I put "uncomplete" instead of "incomplete". Baffling....
You ARE from WV.......
That is crazy. I finished painting my Athol a couple of weeks ago about the same color. I was waiting until I got it all back together before I posted anything. I just don't want you thinking I copied you when I get around to posting it!
That one looks great!
Unfortunately, I have a patent on that particular red/black color scheme. If you happen to publish the pictures without written permission, I will be forced to confiscate your vise.
Does anyone know where I can procure the spindle for the above vise?
Or does a spindle from another Athol vise function within the 023 1/2A?
Thank you
JT Moran
Jeff: can you post a few pictures of your Athol showing the spring and pin? i'm guessing that some guys use a piece of pipe and notch it so the spring is pushed back and the pin can be removed.
A bit of copper plumbing pipe usually serves well, and it's easy to cut notches out of the end with a pair of snips, to slip over the pin, with it being copper.
Cheap electrical conduit will also work, as well as PVC tubing. For the notch, I found it easiest to drill a hole thru the side of the conduit (1/4" is a good size) and then cut it straight across the hole. Or maybe a bit to one end of the hole. That leaves a pair of notches large enough to reinstall the cotter pin.
I got the notch pipe made from a piece of PVC. So far, WD-40 and several hits with the BFH have not moved the pin. How much resistance can I expect? The pin is kind of mushrooming.
