JMLangford
First off I got the ole wire wheel fired up and removed the rust....
Then I chucked the bent 3/32" one up in my bench top drill press and gently nudged it back in shape (it had very little run-out when done!)
One down....6 to go.....
After a good wire brushing I blued the upper hex part with Birchwood-Casey Super Blue.....
Then I would polish off the bluing on the face that had the name, part number, and size and also the other face that had the "warning-wear safety goggles".....
I used a Dremel and a 3M plastic wheel to remove the bluing.....
I cleaned up and reshaped the mushroomed striking end on my 1" X 30" belt sander.....(no pics
To keep the rust at bay I wiped them down with a light coat of Outter's gun oil.
)To keep the rust at bay I wiped them down with a light coat of Outter's gun oil.
