Best 4/6 in 1 Screwdriver
scooternut
Pittsburgh, PA
I thought that Enderes looked familiar! Went and checked my box and found that I've inherited one as well. Haven't much used it as 2 of the 4 are worn so the other 2 aren't exactly fresh. Maybe I should try to source new bits.
JR 42
Sunny Seattle
I used to pull hardware off old doors and windows as part of a former job, and went through all the locally available combo screwdrivers I could find made in the US (and Canada). What I recall:
Klein 6 in 1: great grippy handle, decent bits, rubber eventually separated from handle, couldn't bear down on it much after that.
Klein 10 in 1: way too fussy, 99% of what I used a combo screwdriver for only required slotted bits and a P2; the additional slop from the extra layer of bitholders was annoying.
PicQuik: soft bits, always twisted the slotted bits faster than other brands (the earlier, Canadian-made bits, now they're Taiwanese); I carried the screwdriver tip down in the side pocket of Carhartts, and the unbalanced combination of long bits and thick handle meant the PicQuik would fall out of my pocket nearly every time I sat down; open bit storage meant rusty bits.
Craftsman 6 in 1: my favorite - not too shabby, really, decent bits, handle cracked at the retainer on a couple of them after a lot of hard use but warranty was easy.
Still haven't found an Enderes 6 in 1 around here... need to order one someday.
JR
Traule
Have a Mastercraft Maximum, Snap-On and this Wera ratcheting screwdriver
And the Wera is my favourite by a mile..
mikebaker1129
Huffman,TX
What sucked about it ?
I have one that I have not opened or used yet. We're the bits junk or what?
I picked this one up when I was back in Indiana,because it reminded me of a similar Craftsman 5 in 1 I had that was a beast of a tool and was made by Pratt Read. Read somewhere the MF unit sold by Menards was made by Pattern Read also. I am in the HVAC business and use these daily, I must have about 20 or so .i pick them up at fleas and pawn stores all the time.
txdm
The Snap On is nice: #SDDD41
Link: https://store.snapon.com/Reversible...ewdriver-Reversible-Blade-5-pcs--P646029.aspx
However, the Craftsman is cheaper, and you can use the warranty on worn parts for full replacement, the Snap On bits are like $5 or something like that.
Craftsman link: http://www.sears.com/craftsman-6-in-1-screwdriver/p-00941161000P
Those are really nice options. I'm putting that snap-on on my list of Xmas gift ideas.
There are lots of nice "bit drivers" in this thread, but in my experience doing handyman duty with wiring appliances and house/farm electrical, a classic 6-in-1 is a better tool for the attic, laundry closet, basement, well-house etc., especially with the two sizes of nut drivers included. Bit drivers (and their little bits) excel on the bench, for changing batteries, working with fire arms, or installing hard drives, etc.
LumpyMusic
Phoenix Arizona USA
For my usage:
Kliens are too heavy, handle diameter too large for quick spinning, expensive.
Handle must be squarish, not triangularish, not roundish.
Bits must be phillips/phillips on one end, flat/flat on the other end. I don't want LG phillips/LG flat and SM phillips/SM flat.
The nutdriver part of it must include a 5/16. That's the overwhelmingly most found size on hose clamps that I work on. The other one can be anything at all. Just fine if both were 5/16
10 in 1, 11 in 1, etc - I have zero use for square drive. If I need a Torx, I reach for the appropriate tool for that. There's only two, T10 and T15, that are usable in my automobile applications with a handle type driver. Anything larger than that it needs a ratchet driver, not a screwdriver handle. On the rare occasion that I need a Schrader valve tool or a push down tool, I reach for those dedicated tools. I don't need to carry either around with me "just in case". That only makes it more difficult to find a simple #2 phillips when I want it.
Orange Buck Bros are fine for me. Except lately I haven't seen them with the Phil/Phil and Flat/Flat arrangement I like.
Lump
Mark in Indiana
Southern Indiana
Craftsman #41116, 6 in 1 screwdriver. I had to buy one to replace an older 6 in 1 that I misplaced. It's very comfortable to use and made in USA. Best one I've used yet.
Rarified27
Between PA and NJ
A few weeks I picked up the Lenox mentioned above during a sale at Lowe's. Tossed it in the quick-fix belt pouch I use for stuff around the house and it's been great. I was impressed by how sharp the phillips blades were cut.
My only complaint about it and other X in 1's are the restricted access to recessed fasteners.
NoahG
Detroit, MI
I melded a Klein 10 in 1 and 5 in 1, and made myself a 8 in 1. Its got the larger/longer PH2-9/32" in one end of the 5/16" tube, and the other end of the tube has the 1/4" reducer with the PH1-3/16" and SQ1/2 bit. It's almost a Lenox 9 in 1 but I have no daily need for a #3 Square. Its my favorite, however the Milwaukee 11 in 1 and Picquic SixPac Plus aren't close behind.
autonaut
That is a nice tool right there..
Im getting tired of the "snap on this, snap on that".
If anyone feels the same and are looking for a better x in 1 screwdriver Wera has you covered with that one.
SweetD
Rhode Island
I bet the SO ones may fit yours:
Dave
jeffmoss26
Cleveland, Ohio
decableguy2000
Kleins for me. I use a 5in the most, but also have 10 in 1, 11 in 1 and stubby 5 in 1. I like the fact I can order a bunch of other bits as needed. Also Craftsman that is identical to the Klein.
Jeremy
bfm336
St. Louis, MO
Quick note on orange handled ones.
I recently picked up 2 of the HDX ones from Home Depot for $3 each, assembled in USA at least so better than nothing. After ratting around gently in my cars console for a week one of the brittle handles had already cracked from where the metal insert goes into the handle - not good.
Returned those and got the orange handled Taiwan $3 ones from Menards and so far so good.
I'll also mention Menards has the Philips #2 and #1 on the same, smaller side, and the slotted are together on the larger side. I remember an earlier post looking for this.
Jawn
Stuck in traffic, GA
One of the great thing about Picquic is that they come in many different sizes....and colors. Surprise, surprise.... I have orange ones! :bounce: still looking for a regular size stubby to complete the set.
I have the smaller two (Picquic Multique and Teeny Turner), great for my line of work (mostly electronics / computer stuff).
d.mcfarland
Western PA
This would make an awesome test for someone to test fit of brand new screwdrivers into their counterparts.
"Best" is subjective. Best feel, best function, best fit, best value, best color, etc. All the while I think most of us are likely just as concerned with best fastener connection.
bentleyden
klein, greenlee, lenox 10 in 1's are great. i have used them all. other brands are good also like craftsman and milwaukee.
JUNK-MAN
PA
I have a snap on, its great had for a few years now I also have an old one that simply says 4 in1 screwdrivers inc Jamestown NY both are good quality and come in handy alot.
cgv69
Boone Co., KY
What model is that? I really like that it is ratcheting.
I don't know about you guys but I've been so spoiled by ratcheting type bit drivers that I hate any non-ratcheting driver. I only use standard drivers in situations where a bit driver won't fit.
mv213
Dallas, OR (the OTHER "Big D")
There has already been many posted that would be considered higher quality, but I have always been fond of the Stanley version.
The "tri-oval" shape of the handle seems to suit me:
I have an older one like that from about 1980 that I bought new. They called the handles "Workmaster" or something like that. I'll try to post a picture later. Those Workmaster handles were awesome for the day.
This thread is costing me money! I already ordered a Picquic from Firehawk. I might have to get one of those Wera's too.
bonneyman
Desert SW
Snagged two of the old style Enderes multi's today at a pawn shop.
The larger one is missing one of the bits and is nasty, but being old (pre-bankruptcy style) hard-handles and only 50 cents each made it a no brainer.
