Big vise build
R
royce
fairbanks ak
Thanks again all,
Yes, MILLSCOTT came from our last names and the No 13 comes from the jaw width.
Royce
95riosnake
Pittsburgh, PA
I'm utterly floored at the level of quality and skill on show in this project. That name plate really is the cherry on top. This definitely reminds me of the old photos I've seen of the enormous vises in railway maintenance shops, but a much more refined and beautiful design.
Duker
Livingston, TX
I'm a little late to the party...
But, as they say, better late, than never....
YA DUN REEL GUD, BUBBA!!!!
After looking at the size of that behemoth, I had to add a "REEL" to the normal "YDGB"....
Congratulations to both of you...
^^^ A giant second on all of that.....!
This was a fun journey to read and follow along with.... great collaboration by you guys.
Sent from my iPad using Tapatalk Pro
chrisnazzy
Arizona
Keep in mind those railroad vises were 8" to 9" vises. This monster that Royce has created with the help of KMScott has 13" jaws, integrated stand and could outweigh a railroad vise by 1000 lbs. A Prentiss, Hollands or Reed monster vise would like a homeowner's grade house sitting on the tail of this big boy.
trijeff
Northern Cali
yes, but with one of the purposely built RR vise stands the weights are really similar
Sent from my SM-G900T using Tapatalk
95riosnake
Pittsburgh, PA
Oh I know, that's what is so incredible about this project. An 8" vise is considered huge in most settings, and this one definitely dwarfs one. I remember seeing a vise with 10" jaws in person and thought it was pretty crazy, I could only imagine what this one looks like in the flesh. I'm sure even the photos with scale references still don't do it justice!
General Geoff
Allentown, Pennsylvania
That thing is gorgeous, congrats on completing the project. If you do decide to auction it off, I bet it fetches five figures.
Curious, what kind of clamping force does that thing generate with a 200lb gorilla hanging off the end of the handle?
R
royce
fairbanks ak
I do not know the force, it has a 26" handle and a 5 TPI screw.
It held this homemade 600# anvil without much torque on the handle.
Thanks again to all
Royce
NASTYZEN
St-Colomban,Que. Canada
You should have a plaque with your name on it, cause you know it will wind up in a museum some day.:bounce:
Quite the masterpiece indeed . You outdid yourself this time Royce, Just beautiful.
trijeff
Northern Cali
Nasty, the existing nameplate is a combo of Royce's and Kevin's last names
General Geoff
Using this calculator, a rough estimate using 1.75" bolt diameter for the main screw and 200 lbs of gorilla hanging off 24" of handle (knocking 2" off for the spindle) which equals 4800 in-lbs torque, and .16 for lubricated screw coefficient of friction, we get ~17,142 lbs of clamping force, or about 8.5 tons. :beer:
Is that PSI? if so its distributed over the jaw surface. (unless you get a 1X1" jaw extender)
It's still a LOT of pressure!
General Geoff
Nah, that's total pounds regardless of surface area. 13x2" jaws would mean 26 square inches of available surface area, so if you're squeezing something that's flat, square and takes up the entire jaw surface on both sides, that would be ~654 psi.
Conversely, if you squeeze a penny, you get roughly 39,000 psi on the penny.
Your first statement is contrary to your second, which agrees with my comments.
You can't have it both ways, and the first statement is not correct.
I am curious hot the linked page interprets the "clamping force" adn again on what area? The contact area of the bolt head, or the undefined area being clamped? Its not stated.
General Geoff
Nothing contrary in my statements. PSI can vary wildly with the same exact force being applied to different surface areas. Pressure and force are two distinct measurements, with pressure being the ratio of force to area over which it is applied.
A 4,000lb car pushes against the earth with 4,000 pounds of force no matter how much air pressure you have in your tires. You can pump them up to 60psi or let them down to 10psi, but the total force is the same, you're just spreading out the force to a larger surface area.
JZiggy
Atlanta
What an awesome project!! This thread was a blast to read.
Some time back I made a force gauge like this guy: https://www.skylighter.com/blogs/how-to-make-fireworks/arbor-press-force-gauge
It's been fun to put it in various vises, arbor presses, etc. I even fitted a lower psi gauge on it to measure load-displacement curves on bumpstops for 4x4 trucks. I seem to recall that my 6" vises will generate >8000 lbf clamp load. Vises with taller jaws yield a lower clamp load -- the torque has to balance between the top of the slide and the jaws.
To the OP, I'll mail you my gauge if you'll take a measurement for us!!
R
royce
fairbanks ak
JZiggy,
I would be glad to measure it.
When I calculated it, I came up with a number close to what General Geoff got, but that does not factor the friction losses of the slide and the meatball.
It will be interesting to see how much energy is lost to friction.
Any bets?
Thanks to all for the great input
Royce
JZiggy
Atlanta
JZiggy,
Any bets?
Royce
That's exactly why I put needle rollers bearings under the base of the lead screw where it bears against the slide. :bounce:
I'll PM ya
JZiggy
Atlanta
It's just a bunch of Harbor Freight **** anyway so it's OK if he breaks it!
The ram has a 1.690" diameter piston, so the area is 2.243 in^2. Measure the psi clamped, multiply by 2.243 and you get the total force in pounds.
Here it is in the 4.5" Record --> 4260 lb
And the Reed 4C --> 6500 lb
I guess since the gauge only goes to 6000 psi our max load is 13,500 lb. I hope you exceed it!!
ClappedOutBport
Our big Prentiss has I think only a 2 TPI screw on it. So you would need a cheater to really get the sort of pressure it is capable of. Then again, I'd rather not risk the nut.
Firstram
Royce,
All of your projects have all been creative functioning works of art, even the "simple" stands. Cold weather is not to far out which means you'll want to spend more time in the shop. This Vise will be a hard act to follow and I'm not so sure you can turn back now. I'm really looking forward to whats next! Please do keep up the awesome work.
Thanks for raising the bar.
Wes
R
royce
fairbanks ak
Thanks Wes,
Yes, we are seeing a few yellow leaves.
As far as projects go, I have a hundred I should do and a dozen I would like to do.
I will probably lean towards something I would like to do, rather than something I should do.
My discipline has really went in the ******* in the last couple years!!!
Royce
R
royce
fairbanks ak
Allrighty then,
I received JZiggy's ram and gauge today and put the mash on it.
I ran the gauge up to just short of the peg at 5900#.
It was not all I could get, but was getting close.
6000#PSIG calcs to 13,458# total force
13,458# calcs to 414 PSI across the jaw surface.
My thanks to JZiggy for making this happen.
I checked some other vises and will post on the vise thread.
Royce
R
royce
fairbanks ak
Wow, hope those jaws do not crack, I heard they come with a warranty. Works like it should Royce.
That's a warranty I'll bet my bottom dollar never gets applied for!!!
It sure enough works like it should, makes me proud of what we accomplished Kevin, how about you?
Royce
PugetDude
Superstition Mountains, AZ
Royce (and Kevin) Great job on the vise, and the collaboration. :thumbup:
Soooooo.... What's next? :dunno:
PLEASE don't make us go back to the HF vs. SnapOn /Craftsman circling the drain threads...
