signcrafter
- Joined
- May 9, 2012
- Messages
- 12,681
I saw a brake drum puller while doing some searching last night that I had never seen before. I saw the kastar one but otc also makes one. http://www.tooldesk.com/automotive/KAS833-Kastar-833-Brake-Drum-and-Rotor-Puller.aspx and http://www.amazon.com/dp/B004CGOGFS/?tag=atomicindus08-20. It's not something that I would use often but it looks like it might be pretty easy to make. I have a pretty big snap on puller and pressure screw that I don't really use much, similar to the one on the right of this board, http://www.gilesmossauction.com/snap on pullers.jpg.
My thought is to get a pice of square tubing the puller frame will fit in. Drill a hole in the middle for the pressure screw. Slide the puller in the tube and then thread the pressure screw in. Then make some type of puller arms. Maybe just some flat stock bent at the ends that will slide over the square tube? This is the one thing I'm not really sure about. If I just use flat stock will it be strong enough or will it just bend back when I try to pull a stuck hub? Or can heat them and quinch them after I bend them to heat treat them to make them stronger?
Here is a video of what I am going to try and make tonight.
<iframe width="420" height="315" src="http://www.youtube.com/embed/5OqYsyJ57cY" frameborder="0" allowfullscreen></iframe>
