Broke……..🤬 (Snap on) Update 8/8/2023
Dakotadadv8
OP I have the same pair of pliers they work well the teeth design helps with the grip.
bb29510
i broke a snap on torque wrench once, the dealer told me, '***** to be you"
firebirdparts
Kingsport, TN
Actually, these are the three fundamental laws of the universe:
  • When you're fixing something, your wife will tell you you're doing it wrong (and too slowly), even though she has no idea of how to do it herself and doesn't know which end of a hammer to use.
  • Your cat will puke in the exact path you take to the bathroom at 2AM, so you get to step in it.
  • Your BIL will ask to borrow some money, and then never pay you back.
Never get involved in a land war in Asia.
CGarage
United States/Switzerland
The front side with the flat fracture is the defect and first part that let go, the rear side with the angled fracture is the post failure break. The initial fracture was also in tension when you attempted to use them, and the second was combination of bending and tensile fracture.
I am retired metallurgical engineer, that metal had a defect. Just exchange for replacement.
Excellent post.
m6z
Missouri
🤣 Well, I'm glad it's not just me..
seber
Deep East Tx.
Snao-on tools are generally tempered harder than most of the competition. You have the result of going just a little too far. I've had screwdrivers do the same on the first screw. The up side is other than the occasional problem you get tools that just don't wear out. Get it replaced and be happy.
purplezr2
Central MN
Somehow I doubt it
Broke a set of snap on needle nose bending to small diameter steel rod. I broke a set of waterpump pliers similar to the above removing a NPT ******. Guessing a forging lap or some other defect. That is what warranty if for.
Bubba Fett
Eastern NC
Well, they have a great warranty, which you paid for. Get them replaced. Besides, they need to be aware of this anyway. Might be a bad batch, or defective steel, flawed hardening process, etc.
Tool companies need to know about defects, or they won't make improvements.
It happens to the best of them.
Used to see similar stuff now and then with brand new tools - fly apart like that on first use. Like the man said, that's what warranties are for.
As an aside, gentlemen, Vampire Tools is running a promo right now..... I'll get something posted in the "hot deal" thread.
tarbellb
Oregon
Nonsense! I heard the Snap-On C shift at the plant got denied their annual bump due to lost sales that HF Knipex clone had caused so they jacked up the heat treat process and are double dipping the handles too!
Jtels85
Dang dude, you would’ve had better luck with a pair of those pot metal Craftsman pliers Lowe’s is peddling.
neophyte
Pennsylvannia
That’s got to be a casting fault?
“FORGING FAULT” !!!!!!!!!!!!!!!!!!!
Pliers,
with a few exceptions,
are usually forged,
not cast.
The exceptions are usually things like crimper dies, and Beryllium Copper and Bronze non-sparking tools.
neophyte
Pennsylvannia
The best guess, is that someone at Snap-On failed to put a batch of pliers thru an annealing oven after the pliers were heat treated and quenched to harden the pliers.
Either that, or for some reason, the tempering step in the heat treating process was cut short leaving the one plier jar two hard and brittle.
If this happened to one pair of pliers, it likely happened to a few hundred other pairs give or take, although I have no clue what the typical heat treat batch size is.
f121
UK
Pliers,
are usually forged,
not cast.
I think we’ve established by now that I don’t know anything about how stuff is made out of metal :ROFLMAO:
What I meant was ‘manufacturing defect’, while I’m no lover of snap on squishy things (pliers, cutters, water pump pliers, etc), I’m pretty sure they shouldn’t snap when you squeeze them.
jgeoffr
I was very disappointed by this thread title. I was expecting information about personal finances because of Snap-On purchases! 😆
Best of luck to OP to get these replaced!
Boogerman
aspen cove hill
All's I'm gonna say I've I've been (ab)using my harbor freight ones for a decade and they haven't broken. And I didn't need to sign my paycheck over to the snap-on guy for 6 weeks.
You need upgrade jobs to MacDonald's. 3 hours there buy those pliers. Maybe the stated (by you) fact that you abuse your tools and use harbor freight contributes to the extremely low income?:unsure::LOL:
At least OP gave us amusement of good discussion. I'm not impressed Snap-on pliers except Talon and diagonal cutters. Only drawer in my box not predominately SO. Proto, Channellock, Klein, Knipex, and many others make top tier pliers that compete and outcompete with Snap-on.
Spud McGee
Holy hell, man. Maybe you need to take a break from the internet for a couple days. It was a joke.
You can tell the fanbois when they start getting defensive and snappy without even understanding the post they are replying to.
rancherbill
Foothills County, Alberta, Canada
I keep hearing reports that Harbor Freight stuff does not break at 10% squeeze on the first use. Apparently they also have advantageous pricing. :giggle::LOL:
I'd say it's a problem in the tempering process. This says to me that they do not have a good current process control. These pliers were not annealed correctly.
